Remote Start Problem - Drive Accord Honda Forums
post #1 of 25 Old 02-08-2016, 09:43 PM Thread Starter
Hi, I'm a new owner of a 2016 Accord with a question about the remote start. It seem as though if I've used the remote, for locking or unlocking, (or accidentally pushed one of those buttons) then the remote start function stops working for 10 minutes or so. Any advice on this would be much appreciated.
Thank you
Tholley is offline
post #2 of 25 Old 02-09-2016, 06:49 AM
Go Mountaineers !
TomFromMo's Avatar
Took me a while to get the hang of how it works. Try this. Lock doors with remote. Doesn't matter if they are already locked. Just click the lock button so you see the light in the drivers mirror flash. Then push and hold the start button until you see the mirror light flash again. Then release. It should start within a couple of seconds.
TomFromMo is offline
post #3 of 25 Old 02-09-2016, 07:41 AM Thread Starter
That's what I've been doing but it only works occasionally - like every few days
Tholley is offline
post #4 of 25 Old 02-09-2016, 06:14 PM
Concordant's Avatar
Be sure to press and hold the engine start within 5 seconds of pressing the door lock.
Are you getting any confirmation of the engine start request?
The flashing light sequence should be as follows;
1 flash - door lock
1 flash - engine start press and hold
3 flashes - engine start
3 flashes - engine start confirmation
If this does not work be certain to always start with the door lock press.
Concordant is offline
The Following User Says Thank You to Concordant For This Useful Post:
CheezyPoofs (03-23-2016)
post #5 of 25 Old 02-09-2016, 07:46 PM Thread Starter
Thanks for the info. I always press lock first and always get a flash. However, the engine only starts about 10% of the time (with pressing and holding the hold button). Both key fobs have the same problem. When it does start, I get the flash sequence you mentioned. The salesman mentioned that the remote start is very finicky and I should double press lock before pressing hold. Unfortunately that only works occasionally as well. As it stands, this feature is completely unreliable. If no one else has experienced this, mine must be defective. But given the dealer's comments I suspect it is a widespread problem and an inferior product. Any comments appreciated.
Tholley is offline
post #6 of 25 Old 02-10-2016, 06:18 PM
Concordant's Avatar
Unfortunately, it sounds like another trip to the dealer is in order.
I have only used it less than a dozen times but it never has failed.
I would also make sure it's actually locking each and every time just to be sure it's not something inherent in remote reception.
Good luck and let us know how it works out.
2016 Accord Touring Coupe
Deep Blue Opal Metallic
post #7 of 25 Old 03-02-2016, 05:25 AM
Unhappy 2016 Touring - I got the same remote start problem
I got the same remote start problem as 'Tholley'. I bought the 2016 Touring 3 days back and I thought I must have been doing something incorrectly, but it seems like a problem with the remote. I'm trying this from a short range - 25 feet or so.
The door lock signal (single flash) comes all the time, but many a times the ignition does not kick-in when pressing-holding the engine button on the transmitter. It just never does. I have to leave it that way and try some time later, and randomly it may work or not.
If this was a transmitter battery issue, then most likely the door-lock signal would not come either. Another trip to the dealer
geisler is offline
post #8 of 25 Old 03-02-2016, 09:07 AM
MrBill
billmugan's Avatar
Mine only works if I am standing right next to the car.
However, I don't really need the feature so it is no big deal :-)
MrBill,
2016 Accord 2D EXLN SEN Coupe
billmugan is offline
post #9 of 25 Old 03-22-2016, 07:45 AM
Hi,
I'm facing the same problem, I accord 2016 EX is not even a week old. Remote works occasionally. I took it to the dealer it worked fine there, so the dealer says he cannot fix it unless there is a REAL issue. But, when I tried next day, it failed. Please let me know the best solutions to this.
Thanks.
yesnikhil is offline
post #10 of 25 Old 03-23-2016, 04:56 PM
Some of you might try holding the fob against your chin when you're using it. Your body will act like an antenna, and maybe that'll help a bit.
CheezyPoofs is offline
post #11 of 25 Old 04-08-2016, 01:02 AM
Thanks a lot- was so tensed after buying a new car- the remote start was not working which I didn't check at the dealership... found this page and found that I was doing it wrong...
Now I can sleep better
arunodoysaha is offline
post #12 of 25 Old 04-08-2016, 06:53 PM
Always time to play!!
Tym2play's Avatar
Also note that the car will only run for 10 minutes after it has started unless it has been set again while the car is running!!
2016 Honda Accord Sport 6MT
Obsidian Blue Pearl
Sport Grille
3M 30% tint
Rv6 downpipe
LED Interior light conversion
2016 Honda Accord Sport CVT
Crystal Black Pearl
3M 30% tint
IG: sp33d_fit_freak
Tym2play is offline
post #13 of 25 Old 04-19-2016, 02:06 PM
I have the same problem. I lock the car first and then try to restart the car by pressing the button but it doesn't work most of the time. Can someone tell me how it was fixed?
sdsurfer is offline
post #14 of 25 Old 05-23-2016, 07:10 PM
Mine does not work either.
tvdang7 is offline
post #15 of 25 Old 06-08-2016, 07:53 PM
dlm
Go into Vehicle Setting and toogle remote start setting off and then back on. Should fix the problem.
dlm is offline
