exclamation mark light - Drive Accord Honda Forums
post #1 of 38 Old 04-26-2009, 11:11 AM Thread Starter
kha
hey all, owners manual is in the office, and im curious now. a light with a exclamation mark in a triangle came up when i was driving home last night. what are some of the reasons it comes on?
kha is offline
post #2 of 38 Old 04-26-2009, 11:17 AM
traction control you can turn it off or sometimes if your driving recklessly it turns on because its trying to keep traction
2004 White Coupe I4 6Mt
84,xxx Miles
Aem CAI
Tints
Tein Lowering Springs
18" White Axis Halo
-Blue Muteki Lug
-Blue Enkei Valves
Oem Front Lip
Depo Blackhousing Headlights
-6000k HID LB
6Mt Swap
-Act Stage 2 Clutch
-Act Racing Flywheel
Not Installed:
Depo Blackhousing Fogs
-3000k HID Fogs
-Lamin-x Yellow Film
Future Mods:
DC Header 4-2-1
Custom HKS Hi-P Exhaust
Eclipse Navi
Neuspeed Short Shifter
Joe818 is offline
post #3 of 38 Old 04-26-2009, 11:24 AM Thread Starter
kha
LOL
thats actually really funny if its true, it came on after i was "parked" with my girlfriend in front of her house after picked her drunk ass up from the bar
kha is offline
post #4 of 38 Old 04-26-2009, 11:31 AM
2016 Nissan Maxima Platnm
hillstones's Avatar
When the traction control system is in use, it will flash the triangle. If it comes on steady, it can indicate that the brake switch has gone bad. Honda replaced mine free of charge. Apparently that has been known to fail. So if it comes on randomly (steady light) while driving or stopped, take it to the dealer to have checked out.
hillstones is offline
post #5 of 38 Old 04-27-2009, 07:40 AM Thread Starter
kha
it was on steady on the ride home. but it went away the next morning. im going to assume it was what the second poster said.
kha is offline
post #6 of 38 Old 04-27-2009, 08:26 AM
Accordriver's Avatar
If it stays on that indicates a problem. Under normal use it will simply flash when it engages.
-03 Honda Accord EX V6
-Debadged-17mm sway bar-UR crank pulley-AEM CAI
Accordriver is offline
post #7 of 38 Old 04-27-2009, 08:41 AM
hillstones's Avatar
As Accordriver said, you have a problem. It is not supposed to stay on steady while driving. Most likely it is the brake switch failure. If it is the brake switch, you may not have any brake lights when it is on. My light was also intermittent. Some days it did not come on, other days is was on steady.
post #8 of 38 Old 04-27-2009, 10:49 AM
V6 Slingshot Engaged!!
taylour's Avatar
It will come on steady until you restart the car if you "accidentally" pressed the VSA button next to the sunroof control (that turns the vsa off). Pressing it again will turn it back on, turning the light off. VSA is always on unless you press the button and when it's off the light will appear.
2005 Honda Accord SE-V6 Coupe AT, Graphite Pearl, 35% Tint, Soundgate HONDAUX3, Homelink, Metal Trim Kit, TL Switchblade Key. Sold
2010 Genesis Coupe 3.8 Track, White Sold
2012 4Runner Trail NAV KDSS, Black Sold
2006 Pontiac Solstice (First 1000)
taylour is offline
post #9 of 38 Old 04-27-2009, 01:14 PM
namegoeshere's Avatar
Some say it's because V1etxb0iz626 really likes that icon.
namegoeshere is offline
post #10 of 38 Old 04-27-2009, 03:21 PM
hillstones's Avatar
Incorrect. You can turn it on and off with the TCS Off button; however, when you manually turn it off, it will show the triangle and the word OFF next to it. If the triangle appears on by itself, there is a fault in the system. It can be the TCS system itself, or the brake switch. The triangle will flash when the TCS system is operating to compensate for loss of traction.
VSA is something entirely different than TCS. The Accord V6 has TCS, Traction Control System. VSA is Vehicle Stability System.
post #11 of 38 Old 04-27-2009, 07:46 PM
03Accord EX-L's Avatar
if I turn mine off there is no word "off" next to mine so IDK what your talking about
Looking to make a nice car even nicer....
2003 Accord EX-L AV6
03Accord EX-L is offline
post #12 of 38 Old 04-27-2009, 07:49 PM Thread Starter
kha
k guys so maybe i did hit it on accident with my knee or something. but i have no idea if TCS if on off off when the light appears. maybe i should launch the car and spin the wheels a bit to determine if TCS is on? if it is on the light is not static, but flashes then it is ON and there is NO problems? is my logic correct?
kha is offline
post #13 of 38 Old 04-27-2009, 07:51 PM
Keepin' It R-E-A-L...!!!
Osiris_x11's Avatar
Arrow
lolz...
2008 Honda Accord LX-L Polished Metal Metallic Type-Q
{a few Honda/Acura vehicles in the past/present/future}
Osiris_x11 is offline
post #14 of 38 Old 04-27-2009, 07:52 PM
push the button if the light comes on its off....if the light goes off then TCS is on....light and TCS are opposites...is the lights on TCS is off...if the lights off then TCS is on
post #15 of 38 Old 04-27-2009, 08:00 PM
Rule Enforcer
stevencrosbie's Avatar
Send a message via AIM to stevencrosbie
-Steve (Moderator)
2015 Ram 2500 Crew Cab 6.7 Cummins Longhorn
2012 VW Golf TDI 4dr Tech Package 6MT
Forum Rules and Regulations
Originally Posted by Markus View Post
Here's a hint - if you don't want to be judged by what you write on an internet forum then don't write on an internet forum.
stevencrosbie is offline
