Air Mix Contorl Motor/Linkage - Drive Accord Honda Forums
post #1 of 5 Old 05-05-2009, 01:47 PM Thread Starter
2004 Accord EX V6 4 door with navi
The AC vents on the drivers side would blow only warm air. Passengers side worked fine. Retrieved a code I using the AC control panel. I is the code for an open in the drivers air mix control motor circuit. Got under the dash and gave a tug on the door linkage and the air mix system started working. Code went away when the system started working. Ran the temperature to max both cold and hot, still working.
Everything fine for a few days and motor stuck in the same position, max hot. Pulled on linkage and started working. Lubed the linkage this time.
When the motor sticks, it sticks in the max hot position. Setting the temperature control on max hot does not drive the motor to this position. Might be because the weather is not cold enough.
Checked with dealer and the motor is a special order item. Evidently it does not fail often.
Anyone ever have this problem?
04 Accord EX V6
00 Toyota 4Runner
Ex Max is offline
post #2 of 5 Old 05-05-2009, 04:05 PM
Can you remove the motor from the case? Ensure the key is off. Feel if the door moves smoothly. If you feel no excessive resistance, the motor is probably binding.
If you have access to grease for plastic parts, you can open up the motor and lube it. It may just have one of the gears dry. But, you may find one stripped out. Don't change the position of the linkage or motor's gears.
post #3 of 5 Old 05-05-2009, 06:32 PM Thread Starter
Must remove the lower dash panel and a panel under the dash to get to the drivers side motor. If I remove the motor I think I will swap the passengers and driver side motor to see if the failure follows the motor. One panel under dash panel to remove to get to the passengers side motor.
Like I said the motor seems to operate fine if it is not stuck in the full heat position.
04 Accord EX V6
00 Toyota 4Runner
Ex Max is offline
post #4 of 5 Old 10-06-2014, 06:51 AM
I have the same issue
I have this same issue in a 2006 exl v6 6mt sedan. Looks like a common problem that is usually, incorrectly, diagnosed as low refrigerant.
James93 is offline
post #5 of 5 Old 10-27-2014, 05:49 PM
I have a 2006 Accord EX with the same issue, how do you fix this issue? The only difference is the driver side blows cold and passenger blows max hot
terrymc. is offline
