Problems with cruise control on 2003 Honda Accord LX? - Drive Accord Honda Forums
post #1 of 18 Old 06-12-2009, 11:36 AM Thread Starter
The cruise control is not working in my Accord. The Cruise Main light comes on when I push the Cruise button. The Cruise Control light comes on when I hit the set button. The cruise control does not maintain the speed. I don't believe it is a problem with the brake switch. When I apply brakes, the Cruise Control light goes out.
What should I look for next?
Thanks,
Steve
stevew is offline
post #2 of 18 Old 06-12-2009, 11:46 AM
ROLO "THE HULK" NY
MRROLO150's Avatar
Send a message via AIM to MRROLO150 Send a message via Yahoo to MRROLO150
How fast are you going when you try and use the CC?
RoLO
"THE HULK"
FLCM Squad # 8
Miami Area Subsquad Leader
http://i274.photobucket.com/albums/j...EWAVATAR-2.jpg
MRROLO150 is offline
post #3 of 18 Old 06-12-2009, 12:05 PM Thread Starter
I have tried it at various speeds on the way to work, between 30 and 65. The lights come on but it won't hold a speed. Someone had mentioned the brake switch but when I hit the brakes the Cruise Control light goes out.
Steve
stevew is offline
post #4 of 18 Old 08-14-2010, 09:09 AM
Michael
I'm going to bump this questions because I have the same exact issue.
I read else where
Q: Problems with cruise control on 2003 Honda Accord LX?
The cruise control is not working in my Accord. The Cruise Main light comes on when I push the Cruise button. The Cruise Control light comes on when I hit the set button. The cruise control does not maintain the speed. I don't believe it is a problem with the brake switch. When I apply brakes, the Cruise Control light goes out. What should I look for next?
A: It may be the case that vacuum or electronic actuator (the part that moves the throttle to maintain the speed) isnt working. If it is vacuum powered, there may just be a leak in the line to it, or it may have failed. If you have a moment, it may be best to ask over at driveaccord.net
so I checked here, but this is the most i have found
dilligaf5353 is offline
post #5 of 18 Old 08-14-2010, 12:27 PM
2016 Nissan Maxima Platnm
hillstones's Avatar
Steve
Just because you press the brake and it turns off the cruise doesn't mean your brake switch is problem free. When the brake switch starts to fail, it is typically intermittent. If your vehicle has TCS/VSA, the warning lights will generally appear while you are driving when the switch is not functioning. If it is not the brake switch, then take the car to the dealer so they can check the rest of the cruise control system.
hillstones is offline
post #6 of 18 Old 08-31-2010, 09:24 PM
I also have the same exact problem. I had cruise control working from when I bought my accord in 2003 and it worked fine until this month. I had been completing a road trip from the great plains to the east coast. I was using cruise control about 95% of the road trip. On the 7th day of the trip, the cruise control stopped working. Both the cruise main and cruise control light stay on, but the speed is not maintained. At first I thought due to the hilly/mountainous terrain, the cruise control might not work as the manual says. However, I've tried this again on flat lands at speeds greater than 60 mph, and the cruise control just won't work.
If the fuse is blown, what would be the indication of this? Should the 2 cruise control lights still light up? Thank you.
Edit: Just checked the brake light and horn, both are working fine.
vistadude is offline
post #7 of 18 Old 09-13-2011, 05:12 AM
puresoundz's Avatar
Looks like no one ever figured this one out. I too have had this issue for some time. My 03 Accord LX is manual, but same thing. Light comes on, but throttle wont hold... I was hoping there was some sort of disconnected switch/connection but I don't know enough... maybe one day...
puresoundz is offline
post #8 of 18 Old 09-14-2011, 05:05 PM
GenXer's Avatar
I had to fix mine recently. The first thing to check on a cruise control is the switch on your brake pedal. Those sometimes go bad.
My problem was a less common one. The "set" switch literally stopped working. When I would push it in the switch didn't have a solid "click". It would not stay pushed in, if that makes sense. If I held it in the cruise would work, but as soon as I took my finger off of the switch it would un-set.The good news is it's easy to remove, but the bad news is you have to remove the airbag unit to get to the wire connector. That's a dumb one on Honda's part.
04' Accord LX sedan - I4, 5MT, satin silver metallic
K&N drop-in filter / deleted resonator & DIY intake Ceramic coated stainless D.C. Sports 4-2-1 header
Random Tech. converter "modified"
TSX intake mani / "Ported" injector base
Throttle body coolant bypass
Powerslot front rotors / Skunk2 upper arms
20mm rear sway, 27mm front sway / '06 EX wheels
Megan EZ Street coilovers / Ingalls rear camber kit
6 speed tower strut bar
Comptech short shifter / Stainless TWM shift knob
GenXer is offline
post #9 of 18 Old 06-21-2012, 05:32 PM
Cruise light works, button won't stay "clicked on"
I think I have the same problem.
When I push in cruise, the light comes on, when I let go of the button, the light goes off. I can hear two little clicking noises. But the cruise won't set.
I'm going to check tomorrow whether this is the brake problem, but if not, did getting a new cruise unit work for you? Thanks.
sweatpantking is offline
post #10 of 18 Old 08-27-2012, 05:34 PM
Same exact problem 2005 Accord 4cyl.
What fuse even controls it? My brake lights work, horn works, cruise control lights work just don't maintain the speed.
BlakMagic is offline
post #11 of 18 Old 02-24-2013, 07:54 AM
I have the exact same problem as the first post. 2003 Accord LX 4-cyl. Both the cruise main and 'cruise set' lights work but it doesn't hold speed.
Did anyone ever figure out the solution to this?
jollyfish is offline
post #12 of 18 Old 02-24-2013, 01:46 PM
400k, how much longer?
stiller fan's Avatar
i actually have a related problem, but not exactly like the OP is describing....
during the summer, i noticed that if the interior is too hot, either the cruise control won't work at all, or it'll start working, then cancel itself out. the only solution to this problem is to cool down the interior with the a/c in order for it to start working all the time.
problem first noted in july 2012 while driving in mississippi.
2007 Honda Accord LX Coupe 2.4 MT (400k+ miles)
prior vehicles:
stiller fan is offline
post #13 of 18 Old 03-04-2013, 10:38 AM
2003 Honda Accord 4 Cyl
I had this problem and it was the brake pedal switch. Thanks for the advice.
tattery202 is offline
post #14 of 18 Old 04-20-2013, 05:11 PM
From the symptoms described above (lights work as expected, but doesn't hold speed) it sounds like you have the classic failure of the plastic pulley on the throttle body, same as I did. The pulley plastic ages from heat and becomes brittle. Eventually a portion of it cracks away, the portion that keeps the cable end (small barrel shaped bit of metal clamped to the end of the cable) in place. I could slip the cable end back in place but it would (very) quickly just fall back out of the slot every time since the plastic retaining portion is what broke away.
After a bit of head scratching, I realized that there was enough of the pulley remaining to hold the cable end in place IF tension was held on the cable - it is adjustable and normally somewhat slack when cruise is off. Just tweak the two adjustment nuts to JUST apply slight tension when the engine is off. The way the system is designed, it does not appear to cause any problems. Mine has been holding for two weeks now with daily use of the cruise. I expect eventually this too will fail, but in the meantime I'm enjoying my cruise again!!
Geopeg is offline
post #15 of 18 Old 10-09-2013, 06:57 AM
I love my 2003 Honda Accord but my cruise control has quit working. One day it worked and the next day it stopped. I click the cruise button and the light comes on but as soon as I remove my hand from the button the light goes off. Could it be a fuse?
If so, which one? I looked in my book and it doesn't even mention which fuse goes to the cruise control. Any suggestions??
Robin is offline
