Compartment below radio...door won't stay shut - Drive Accord Honda Forums
post #1 of 15 Old 07-24-2009, 06:12 PM Thread Starter
I drive a 2007 Accord. The compartment below the radio has a push release door. Unfortunately, something slipped behind the door and would not allow it to open. We forced the door open, now it will not "click" shut. I attempted to fix the door, but cannot get to the inner workings. Is there a way I can take the entire compartment out and fix the door?
Thanks in advance!
gobux is offline
post #2 of 15 Old 07-25-2009, 06:12 AM
2016 Nissan Maxima Platnm
hillstones's Avatar
Yes, follow steps 1-6. You can use a wire coat hanger to substitute for the Hook Tool.
http://www.collegehillshonda.com/ins...unkchanger.pdf
hillstones is offline
post #3 of 15 Old 07-25-2009, 01:34 PM Thread Starter
Excellent! Thanks a million...I will be giving it a try today/tomorrow!
gobux is offline
post #4 of 15 Old 07-29-2009, 07:00 PM
Question Need Help
Thanks for sharing the link hillstones.
I too have the same issue. But am stuck at the first step itself (Step 3 in document).
Car (2007 Honda XLE) is A/T and the 2 front clips of the trim ring are popping out easily, but the remaining 4 are giving no headway. Any suggestions?
Thanks !
lekhak is offline
post #5 of 15 Old 07-30-2009, 07:51 AM
Thanks !
Work your fingers in the gap between the trim and the shifter, the clips should eventually pop out. If not, try getting a flat metal putty tool or other spatchula that you can can use to pry without damaging the trim.
04 Accord EX V6 Coupe
king4477 is offline
post #6 of 15 Old 07-30-2009, 07:54 AM
ry05coupe's Avatar
Here is another like that I used when removing the aftermarket HU to put the cubby back in. Just has real pictures
http://www.beaufordbuddy.com/ipod_install_1.htm
Latest mod: 35W 3000K Fogs.
2005 Accord Coupe i4
ry05coupe is offline
The Following User Says Thank You to ry05coupe For This Useful Post:
cbst09 (01-17-2017)
post #7 of 15 Old 07-30-2009, 08:39 AM
CarlR33's Avatar
Thanks !
Open the accessory plug lid (hold open since it is spring loaded) and the coin pocket lid and work your fingers along the front of that shifter trim ring. Should come right up.
CarlR33 is offline
post #8 of 15 Old 08-02-2009, 09:41 AM
FuPeg's Avatar
Thanks for the posts, everyone. I was going to ask this question, but this thread answered it all. Fixed the door in my wife's Accord following the pictures. Apparently there was a little white arm that came loose and would not allow the door hinge to snap open and shut. When my wife inquired at the dealership, they said the compartment would need to be replaced at $140 for the part alone. I'm sure their labor would have been another $150 or so. It pays to do a little research and DIY.
FuPeg
06 EX V6 6MT
06 EX V6 auto
12 A5
15 MDX
FuPeg is offline
The Following User Says Thank You to FuPeg For This Useful Post:
cbst09 (01-17-2017)
post #9 of 15 Old 08-02-2009, 09:03 PM
AznAccord08's Avatar
I had the same problem when I brought home my 7th gen. The spring on the left side of the door is loose. Take apart the center console, remove the lower console and reattach the spring.
2004 Honda Accord LX-i4 Sedan
Mod list can be found here:
http://www.driveaccord.net/forums/sh...ad.php?t=29439
Custom mod:
http://www.driveaccord.net/forums/sh...ad.php?t=36855
DIY - 7th Gen I4 Drive Belt Replacement
http://www.driveaccord.net/forums/sh...d.php?p=624170
AznAccord08 is offline
The Following User Says Thank You to AznAccord08 For This Useful Post:
cbst09 (01-17-2017)
post #10 of 15 Old 02-08-2010, 08:30 PM
03 Accord EX
Thanks in advance!
So I am having the sort of same problem different step. My just locked shut and we can't get it to open. At this point I just need to get it open so I can get my registration ASAP (God forbid I get stopped by the police) and second I need my garage opener. It is winter. What is causing it to stay shut? A spring? On which side (trend?)?
I noticed a few posts on it. Although all seemed to be from people who kind of messed it up or broke it upon trying to get it done. If I can use a hanger to open it where exactly are the hinges/springs?
1accord is offline
post #11 of 15 Old 02-08-2010, 09:24 PM
paperboy42190's Avatar
Thanks !
honda xle? o.O
2007 Acura TL Type-S
paperboy42190 is offline
post #12 of 15 Old 02-09-2010, 04:07 AM
Carpe Diem
ikethegreat's Avatar
Mine locked shut on me once. I took it to the dealer to get it opened and of course they had to break it to open it. They wanted to charge an outrageous price to replace it so I just used a strip of Velcro to keep it shut. Can't see it at all when it's closed.
ikethegreat is offline
post #13 of 15 Old 02-09-2010, 07:57 AM
03 Accord EX
Mine stuck on me once and I opened it after pressing for a few days. Was open for months then someone closed it. Now I just need to get it open once without breaking it so then maybe I can fix it as people have posted. However, I need to get my registration out of there right away.
1accord is offline
post #14 of 15 Old 10-15-2016, 05:22 PM
To get the CD storage compartment out you have to remove the shift lever trim & the "ashtray". There's a good video on the internet about fixing the Honda radio that shows how to do this & remove the CD storage unit. Once you have it out, on the left side you will see a heavy horizontal wire that is actually part of a spring hidden under the pivot point for the lid. If you unhook this wire from the plastic hook that holds it in place it will go vertical. In this position the door can be moved open or closed manually. I had the same problem as you (after fixing my radio). I couldn't figure out how the mechanism was supposed to work so I came up with the above solution.
cranksrus is offline
The Following User Says Thank You to cranksrus For This Useful Post:
cbst09 (01-17-2017)
post #15 of 15 Old 10-15-2016, 05:41 PM
Drew03Accord's Avatar
Thanks for sharing. It's sure that after six years, he'll be happy to finally have your solution.
Drew03Accord is online now
