Coolant Q - Drive Accord Honda Forums
 5Likes
post #1 of 42 Old 06-12-2016, 09:31 AM Thread Starter
qman's Avatar
Coolant Q
I searched on coolant but found the word is used far too often to help me find what I want.
The new owner sticky has a page in it that says to use e Honda All Season Antifreeze/Coolant Type 2. It also says that failure to use it can cause damage to the engine.
I thought I read a post here a while back that listed other coolants that can be used in our cars. Can anyone helpa bruthu out?
qman is offline
post #2 of 42 Old 06-12-2016, 10:12 AM
mtts60's Avatar
Maybe they can be, but why bother? Honda's coolant is ~$25 a gallon and that's good for 5 years. $50 (because you need 1.5 gallons) divided by however many miles you accumulate in 5 years = not worth worrying about. Just get it.
enne likes this.
mtts60 is offline
post #3 of 42 Old 06-12-2016, 11:58 AM
Drew03Accord's Avatar
Originally Posted by qman View Post
IThe new owner sticky has a page in it that says to use e Honda All Season Antifreeze/Coolant Type 2. It also says that failure to use it can cause damage to the engine.
I translate that as failure to use it and using the wrong type of coolant instead.
Example: Using Dex-Cool.
Here is the thread you are looking for.
what intervals to replace coolant and timing belt
bobbo likes this.
Drew03Accord is offline
post #4 of 42 Old 06-12-2016, 12:01 PM
BRWNFLSH now
I'm recalling a post from Drew03accord recently about the Walmart stuff having the same ingredients.
92 EX Sedan auto (RBM) - sold after 12 years (140k miles)
16 EX I4 CVT with sensing (KCM) - 7000 miles so far
BLCKFLSH is online now
post #5 of 42 Old 06-12-2016, 12:46 PM
For as little that you have to change it.... just use OEM....
rszappa1 is offline
post #6 of 42 Old 06-12-2016, 02:51 PM
I won't argue with that. The difference is around 40 bucks per coolant change. I have multiple vehicles I own and also work on, so it works out better for me.
A gallon of Supertech concentrate Is about ten bucks and it yields two when you add the distilled water. My only gripe is the Honda Kool-Aid that leads you to think their coolant has special properties or does more, when the ingredients are the same.
Supertech
Honda
[/QUOTE]
post #7 of 42 Old 06-12-2016, 03:52 PM
chris918's Avatar
yeah just use OEM
V6 TL-S fsb/rsb
V6 battery upgrade
V6 strut bar
Weathertech floor liners
Tinted windows
New vtec gasket
QSUD 0W20
A01 filter
An interference engine is one which interferes with your wallet if you don't keep a solid timing belt in it. -qman
chris918 is offline
post #8 of 42 Old 06-12-2016, 06:35 PM
WDHewson's Avatar
For passenger cars, my guess is that all coolants are pretty well alike and must have similar compatibilities with a wide range of metals, elastomers, gaskets, and surface treatments.
I've had the normal old Prestone product in countless cars since 1977. Never a problem, and not even a thermostat renewal.
But I think coolants for commercial Diesel engines can be substantially different.
WDHewson is offline
post #9 of 42 Old 06-13-2016, 03:06 AM
I am using Prestone. Used it for years and never had issues. Also, when the Honda guy did my timing belt replacement, that's the type of coolant he put in it. He's got no issues with it, and he's probably the best Honda tech around here. Used to work for Honda as well.
2005 Honda Accord V6 LX - 168k
salcuta is offline
post #10 of 42 Old 06-13-2016, 04:06 AM
I used to use Prestone until they changed the formulation. I believe it has silicates now.
post #11 of 42 Old 06-13-2016, 05:52 AM
Your Maintenance Minder
My own contribution to this thread is "to be skeptical". Don't just ASSume that because it is from Prestone, or Peak, or the brainiacs at General Motors, or even the good people of Toyota- that you should blindly trust it.
DexCool is a good example of a fluid that has wreaked havoc on thousands of cars because people did not use it as intended. Even Toyota had a huge problem with their red coolant crystallizing and ruining water pumps (my cousin's 2006 Camry Hybrid with 40,000 miles).
There is an old, excellent, and confusing as heck thread on Bob Is the Oil Guy that has a discussion amongst adults: Toyota red or pink | Cooling System Fluids & Additives | Bob Is The Oil Guy
The short version is: Don't mix brands and "types" of coolants. And don't ASSume that because product X is more expensive, that you are getting a better product, nor that it will be better for your exact car. I've had friends add GM's DexCool into their non-GM cars to "top off" while on a road trip, because it was very expensive and they thought they were buying better quality. Big mistake that reveals itself about 8 months later when the water pump stops working.
RickBlaine is offline
post #12 of 42 Old 06-13-2016, 06:00 AM
Runnin' in the 90s
enne's Avatar
I use Pentofrost A3 Blue. Remind me before I leave work today to check the jug I have in the trunk to see what the ingredients are; I can't seem to find an ingredients list for that specific kind online at the moment. Pretty sure it's exactly the same. Silicate-free, which is what I specifically looked for, thanks to the fine advice on DA I got it at AutoZone.
Selene, 1999 Honda Accord LX Sedan, 2.3L F23A4, 136K, liquid wrapped jet black
Harlock, 1998 Chevy Camaro Coupe, 3.8L 3800-II, 120K, sebring silver
Dana, 2002 Chevy Cavalier LS Sedan, 2.2 L 2200, 134K, sandrift metallic
enne is online now
post #13 of 42 Old 06-13-2016, 08:00 AM
Bob's your UNCLE ...
bobbo's Avatar
Canadian Tire - "Motomaster" brand for the win !!
Betty White (progress thread) -'07 K24/AT SE CM5
P&P ’08 TSX IM|P&P OEM Injector Base|’08 TSX TB|HPS short ram intake w/ K&N|wrapped headers
6-6 strut tower brace|Megan Racing strut tower brace|TL-S FSB|TL-S RSB
HDR grills|JDM emblems|HFP front lip|Inspire fogs|Mugen side sills|OEM deck-lid spoiler|OEM Hybrid tails|17"x7" EP-R5 (HFP) rims
ELM 327 Bluetooth|USA Spec BT-35 HON|Kicker CS65's|Kicker CS693's|LED interior bulbs
bobbo is offline
post #14 of 42 Old 06-13-2016, 08:43 AM Thread Starter
qman's Avatar
Supertech
Honda
[/QUOTE]
The thread you put in about them being the same is what I was looking for. I've been using SuperTech for years and years in every car I own and last thing I wanted to do was go buy cash wasting Honda stuff. World's bigges CB (cheap bstrd) here.
It's why I tried the cheapo motor mounts first. It's in my DNA.
qman is offline
post #15 of 42 Old 06-13-2016, 11:05 AM
easymike's Avatar
check the jug
Current vehicle:
2014 Honda Accord LX 6MT 85K
easy mods and changes:
*55W HID lowbeam 5000K (Innovited upgrade kit)
*Interior trunk handle
*Trunk cargo net
*All weather floor mats from College Hills Honda
*LED "strip" bulb
*LED reverse bulb
*Gutter Guards behind lower grille
Previous vehicles:
2001 Chevy Prizm 3AT (given away, it was a terrible car...)
1995 Honda Accord DX 5MT (wrecked at 240K)
1989 Honda Civic LX 4AT (wrecked at 180K)
1988 GMC Sierra 1500 5MT (sold at 80K)
easymike is offline
