Changed the Vtec gasket again today - Drive Accord Honda Forums
 13Likes
post #1 of 18 Old 03-09-2017, 02:40 PM Thread Starter
chris918's Avatar
Well since I still had a slight leak after replacing the Vtec gasket like 2 years ago, I took a risk and opened it up again. When I did it the first time, I used an inch pound wrench from the top and I couldn't get a feel for how evenly the bolts were tightened and I thought I may have stripped a thread. Since the leak was only very slight I should have left it alone but I had to give it another try.
This time I did it from underneath while I had the oil filter off. The bolts had almost seized in place and were very difficult to get loose with the 1/4" ratchet I was using.
Upon reinstall, I sprayed everything with brake clean and used new bolts from Honda. I tightened one bolt, which loosened the other two, and kept slightly tightening them until they all were what I thought was tight. We'll see if it stays dry now.
V6 TL-S fsb/rsb
V6 battery upgrade
V6 strut bar
Weathertech floor liners
Tinted windows
New vtec gasket
QSUD 0W20
A01 filter
An interference engine is one which interferes with your wallet if you don't keep a solid timing belt in it. -qman
chris918 is online now
post #2 of 18 Old 03-09-2017, 02:48 PM
Roll Tide!
jimijam's Avatar
In before @salcuta asks if you did the V6 Vtec gasket mod.
Did you do it right this time? Good call on new bolts.
You cannot count this as meticulously maintaining your accord because you were repairing your screw up.
Aviography, bobbo and spiritof76 like this.
2007 V6 AT Sedan
jimijam is offline
post #3 of 18 Old 03-09-2017, 02:55 PM Thread Starter
chris918's Avatar
I think so. It helped a lot doing it from underneath. The old bolts seemed fine but they were like $1 a piece so I just ordered them with the new gasket.
V6 TL-S fsb/rsb
V6 battery upgrade
V6 strut bar
Tinted windows
New vtec gasket
QSUD 0W20
A01 filter
post #4 of 18 Old 03-09-2017, 03:10 PM
Nah nah nah, the V6 dipstick is a priority now. I'm still waiting on that.
2005 Honda Accord V6 LX - 169k
1988 Lada
salcuta is online now
post #5 of 18 Old 03-09-2017, 04:31 PM Thread Starter
chris918's Avatar
No V6 mods to the engine, don't want to blow a plug or anything.....
V6 TL-S fsb/rsb
V6 battery upgrade
V6 strut bar
Tinted windows
New vtec gasket
QSUD 0W20
A01 filter
post #6 of 18 Old 03-09-2017, 05:08 PM
Aviography's Avatar
No kidding, you might blow that #5 plug!!
jimijam and Das Chicken like this.
__________________
DA Moderator Team
Aviography is offline
post #7 of 18 Old 03-10-2017, 03:49 AM
We like to live dangerously. Makes life more fun, ya know!
1988 Lada
post #8 of 18 Old 03-10-2017, 04:13 AM
Drew03Accord's Avatar
When I did it the first time, I used an inch pound wrench from the top and I couldn't get a feel for how evenly the bolts were tightened.
Sure you did.
Aviography, t-rd, jimijam and 1 others like this.
My toughest oil thread:
Update your sig with your ride here (10 post minimum req):
Drew03Accord is offline
post #9 of 18 Old 03-10-2017, 11:14 AM Thread Starter
chris918's Avatar
Originally Posted by Drew03Accord View Post
Sure you did.
I really did, but as you know doing it from the top side it's hard to feel if it's going to over tighten or not. This time, underneath, I used a very short 1/4" ratchet which gave me a lot better indication of how tight I was tightening it.
V6 TL-S fsb/rsb
V6 battery upgrade
V6 strut bar
Tinted windows
New vtec gasket
QSUD 0W20
A01 filter
post #10 of 18 Old 03-10-2017, 12:48 PM
If you pinched the gasket, then the solenoid lift up at a specific edge. For something that small torque the corners in 3 steps.
07 V6 AUTO Sedan
t-rd is offline
post #11 of 18 Old 03-19-2017, 12:47 PM
Edited to instead update the thread instarted regarding this issue.
2007 EX-L Sedan I4 Auto
195,600 mi
ryanw2427 is offline
post #12 of 18 Old 03-20-2017, 07:24 AM
Part Hoarder Extrodinaire
CGumina's Avatar
I bet you bent the shit out of your VTEC solenoid by overtightening it; it leaked again because it wasn't making a good seal around the new gasket. You'd better pull it apart again and just replace it, otherwise you risk the car coming onto VTEC too soon and bending the valves in the head.
Since your in there, you could probably swap the single I4 VTEC solenoid for two V6 VTEC solenoids for double the VTEC and horsepower, but you'll probably blow the trans from not doing fluid changes regularly enough.
CM7 Accord EX-L | BB6 Prelude | E36 ///M3 | VA WRX Limited
CGumina is offline
The Following User Says Thank You to CGumina For This Useful Post:
Das Chicken (03-23-2017)
post #13 of 18 Old 03-20-2017, 07:45 AM
Once you strip things, it's better to do by feel. You wouldn't know for sure if the it's the bolt, or the hole threads. I wouldn't have gone back with a torque wrench at that point, at least not blindly waiting for a click.
post #14 of 18 Old 03-20-2017, 08:53 AM
qman's Avatar
The bolts can't be stripped. They're steel and the head is aluminum. The aluminum would get trashed without even so much as scratching a bolt.
qman is online now
post #15 of 18 Old 03-20-2017, 08:55 AM
qman's Avatar
How is it this thread didn't get the ole (BOWEL MOVEMENT) treatment that typically follows this kind of language?
MrRangerZr1 likes this.
qman is online now
