Replacing Clutch - What Else? - Drive Accord Honda Forums
post #1 of 23 Old 05-15-2017, 07:05 PM Thread Starter
Straight Drive's Avatar
Hey there! Gettin ready to have a shop replace the clutch on my 06 4 cylinder. What else should I get done at the same time? I'm using an OEM Exedy clutch kit that includes friction-disc, pressure plate and throwout bearing. So far on my list I have the rear main seal, maybe transmission and motor mounts. Maybe the axle seals/axles if bad? Anything else I should do? I am planning on reusing the flywheel if possible.
2006 EX V6-6 Navi Sedan
2005 KTM 200 EXC 2T
Straight Drive is offline
post #2 of 23 Old 05-16-2017, 11:44 AM
Part Hoarder Extrodinaire
CGumina's Avatar
You've pretty much hit all the points I'd suggest. Might be worth your while to have them do the transmission oil if it hasn't been done yet.
Make sure they resurface the flywheel at a machine shop- using a used flywheel without a fresh face for your new clutch to bed into is a huge no-no.
CM7 Accord EX-L | BB6 Prelude | E36 ///M3 | VA WRX Limited
CGumina is offline
post #3 of 23 Old 05-16-2017, 12:14 PM
chris918's Avatar
Might be best to buy a new flywheel
V6 TL-S fsb/rsb
V6 battery upgrade
V6 strut bar
Weathertech floor liners
Tinted windows
New vtec gasket
QSUD 0W20
A01 filter
An interference engine is one which interferes with your wallet if you don't keep a solid timing belt in it. -qman
chris918 is offline
post #4 of 23 Old 05-16-2017, 12:57 PM Thread Starter
Yeah, just talked to shop and they advise replacing the flywheel as well, but they can have it resurfaced. The problem is if I replaced it I would want an OEM dual mass flywheel and I can't find the part number for that. I am only seeing a solid flywheel part number 22100RAA003. If I do find the DMF I know it is going to be costly, probably as much as the labor is going to cost, which is $570. That sounds reasonable right? This is a Honda specialty shop.
Edit: I can't even find an aftermarket DMF.
2005 KTM 200 EXC 2T
post #5 of 23 Old 05-16-2017, 08:44 PM
7th Gear
demonics12's Avatar
Exedy sells a clutch kit with flywheel, it's for an rsx type s I believe.
I would spend a couple extra on a Honda throw out bearing, Exedys tend to make noise.
CGumina likes this.
04 4mt ex-l Satin Silver/Black
K&N drop in, 6-6 front brake conversion with EBC blanks and Green Stuff pads, ADD Tsx shifter base bushings, '11 Tsx wheels, Eibach Pro-Kit, 35% tint, spoiler, fogs, Inspire Zenki headlights, OPT7 led foglight bulbs, led interior bulbs, DC5 exhaust finisher, Kenwood head unit, JBL gto5ez, Digital Designs CC6.5 components, JBL p963s, Digital Designs 510C subwoofer, back up camera
demonics12 is offline
post #6 of 23 Old 05-17-2017, 06:13 AM Thread Starter
That won't be a dual-mass though...
I thought Exedy was OEM? I know it is for the friction disc and pressure plate. Is the Nachi here OEM?
2005 KTM 200 EXC 2T
post #7 of 23 Old 05-17-2017, 06:47 AM
'07 EX-L Navi 6-6 Sedan
MiragePilot's Avatar
Send a message via Yahoo to MiragePilot
Bernardiparts.com lists the OEM flywheel "22100-RCA-006", for $556.43.
'07 EX-L Navi V6 6MT Sedan
MiragePilot is offline
post #8 of 23 Old 05-17-2017, 08:21 AM
7th Gear
demonics12's Avatar
HCK-1001 Is an oem replacement clutch kit, so it should be. I have this kit on my car.
Honda uses Japanese bearings for the TOB, Exedy uses China bearings.
post #9 of 23 Old 05-17-2017, 11:46 AM Thread Starter
That's for the V6. I need one for the inline 4.
Thanks I'll order the Nachi.
Alijah913 likes this.
2005 KTM 200 EXC 2T
post #10 of 23 Old 05-17-2017, 07:31 PM
I was just looking at some Honda parts websites, and I too am only seeing a single mass flywheel for the I4 5MT. Where do you get the idea that these cars should have a DMF?
2006 Accord SE I4 5AT Sedan - Graphite Pearl - 85k mi
derass is offline
post #11 of 23 Old 05-17-2017, 08:42 PM
7th Gear
demonics12's Avatar
Yeah, the exedy bearing in my nissan rattles, same with my buddies miata, which he literally just did. Well worth the extra $35 or so to get the OEM bearing.
post #12 of 23 Old 05-18-2017, 05:53 AM Thread Starter
I am under the impression these cars came from the factory with a DMF. The V6 definitely does. Look at parts 5 and 6 on this diagram.
2005 KTM 200 EXC 2T
post #13 of 23 Old 05-18-2017, 12:10 PM
#5 is a torque converter, and #6 is a flex plate. Those parts are for the automatic transmission. I'm not sure why that website isn't showing their part numbers and description.
Check out this website instead (just a random Honda parts website, not recommending it or anything). It lists the part numbers for #5 - Torque Converter Assembly and #6 - Drive Plate (aka flex plate).
https://www.hondapartsnow.com/parts-...verter-l4.html
derass is offline
post #14 of 23 Old 05-18-2017, 01:13 PM
Honda Buff
They use the same image for multiple options, but not all parts are used in all options. In this example, it shows the parts between the transmission and the engine for both manuals and automatics, but only shows part numbers for the parts that are applicable to the model selected. You'll notice in the second linked image, only the automatic parts are labeled.
BTW, the V6 definitely uses a dual mass flywheel. But I haven't taken an I4 apart, so I can't say what they use for certain.
Joe
'06 Accord Coupe EX-L V6-6MT - Alabaster Silver Metallic (Progress thread)
'14 Civic LX-CVT Sedan
'06 CR-V EX-AT - Nighthawk Black Pearl
Previous Hondas
'83 Accord Hatchback
'96 Civic Coupe EX I4-5MT - Milano Red (Love this color)
'98 Accord Sedan EX I4-5MT - Taffeta White
'01 Accord Sedan EX I4-5MT - Naples Gold Metallic
"Pro tip: If your headlights light up the seats and back of the driver's head in the car in front of you, you need to aim your headlights downward."
- enne
jfuredy is offline
post #15 of 23 Old 05-18-2017, 02:16 PM
[QUOTE=Straight Drive;5828705]That's for the V6. I need one for the inline 4.
My mistake! I saw the V6-6 in your signature and thought that was the car being discussed. Forgot your OP said 4-cyl.
