04 2.4 coupe shudder/vibration just under 40mph - Drive Accord Honda Forums
post #1 of 18 Old 10-05-2010, 06:19 PM Thread Starter
have a shudder/vibration just under 40mph. does not matter how fast or slow you drive. tires are not the issue. any ideas?
jeepjimmy is offline
post #2 of 18 Old 10-06-2010, 05:22 AM
I had a similar problem when driving at part throttle right around 40 mph. Automatic trans. fluid needed to be changed.
Ben
2003 LX I4 Sedan (Eternal Blue Pearl)
- DC Sports Intake
- TSX rear sway
Other Cars:
2006 Nissan Murano
1987 Porsche 944 Turbo
87944turbo is offline
post #3 of 18 Old 10-06-2010, 06:01 AM
accordslacker's Avatar
need more info on ur car. auto/ manual, mileage?
Just a guess at this point would be cv axles (not the cv joint, but the axle itself). Could be bad ball joints or struts as well though.
'03 4cyl 5mt NHBP LX sedan
tsx IM, AEM shorty intake, 225/45-17s nexens on black Apec rims,17mm TL rear swaybar, Ingalls Stiffy
accordslacker is offline
post #4 of 18 Old 10-06-2010, 11:37 AM
erfan9's Avatar
I have the same problem, right around 60km/h which i assume is 40 mph, i feel a smart vibration, My car is manual 2005,and its got 65,000 miles
2003 Acura RSX Type S 6MT SOLD
2005 Honda Accord Coupe 5 MT Totaled
2011 Honda Accord Coupe EX 4 Cyl 5MT
  • Takeda SRI
  • Fog lights
erfan9 is offline
post #5 of 18 Old 10-06-2010, 03:48 PM
Same here - 100k miles
2005 Accord Coupe I4 5MT
- Fujita CAI, TSX IM, AV6 Strut Bar, TL 17mm Rear Sway
rufusvonstorm is offline
post #6 of 18 Old 10-06-2010, 03:54 PM
paperboy42190's Avatar
but doesnt changing the axle change the cv joint too?
2007 Acura TL Type-S
paperboy42190 is offline
post #7 of 18 Old 10-06-2010, 04:12 PM Thread Starter
-sorry. its a automatic, trans fluid is orig, has just under 100,000 miles on it.
post #8 of 18 Old 10-06-2010, 06:06 PM
CarlR33's Avatar
um, probably should change fluid more often......
CarlR33 is offline
post #9 of 18 Old 10-07-2010, 06:21 AM
It does. Just stating that the weak point and cause of the vibration is the shaft itself, not the cv joint.
post #10 of 18 Old 10-07-2010, 12:48 PM
So, if I'm getting some front-end vibration should I look at replacing the axles sooner than later? 100k on the car, I guess it could be alignment but I don't think so...
Will it eventually shred the whole trans if I let it keep going?
And could I replace these myself if I have the time or not a good idea for a novice mechanic? TY
post #11 of 18 Old 10-09-2010, 05:51 AM
Optimus Prime's Avatar
I'm interested in the answer to this also ...
Optimus Prime is offline
post #12 of 18 Old 10-10-2010, 06:55 AM
erfan9's Avatar
Same here, can somebody please let us know
  • Takeda SRI
  • Fog lights
erfan9 is offline
post #13 of 18 Old 10-10-2010, 08:30 PM
replacing the cv axles is not all that hard if you are mechanically inclined. there is a write up on this site for it.
EDIT: here's a link. It is for full transmission removal, but it'll get you headed in the right direction.
05 l4 mt
post #14 of 18 Old 10-12-2010, 01:47 PM
you might want to check your wheel bearings. they say one way to check it is to jack it up and shake/wobble the wheel in any direction for play. another sign that your bearing is out is to cruise at 40mph or whenever you hear the nosie/vibration and slighty pull to the left or right to see if that noise goes away.if it does then you have a bad wheel bearing. same thing happened to my civic. goodluck!
smykhaisouk is offline
post #15 of 18 Old 10-13-2010, 11:11 PM
Thank you!
