03 2.4 auto Accord EX thermostat replacement - Drive Accord Honda Forums
post #1 of 4 Old 02-16-2011, 11:43 PM Thread Starter
Hi -I'm new to the forum-
I just ordered a new OEM thermostat for my 03 Accord 2.4l EX 4dr; my gas mileage is averaging about 24 mpg highway - replaced both oxygen sensors- (DENSO)- I have 106,000 miles and my temp reading after 1/2 hour drive is 1/4 less than the middle temperature reading - lower hose is cold - i am assuming I have a open thermostat-any instructions on how to bleed the system once the thermostat is replaced and can I get any old radiator fluid (Prestone) from Advance Auto Parts? or what kind does Honda Use. Any feedback will be appreciated.
Sincerely,
Tee
TeesEX03 is offline
post #2 of 4 Old 02-17-2011, 05:31 PM
accordslacker's Avatar
haven't changed coolant or a thermostat on my accord yet. But, USE HONDA COOLANT!!!!!!! the "one coolant works on any car" thing is totally bogus. Use parts store coolant and you will probably be going back for a waterpump in the near future.
'03 4cyl 5mt NHBP LX sedan
tsx IM, AEM shorty intake, 225/45-17s nexens on black Apec rims,17mm TL rear swaybar, Ingalls Stiffy
accordslacker is offline
post #3 of 4 Old 02-17-2011, 08:45 PM
my wheels do work...
05AV6's Avatar
UHm, this may be the poorest advice ever. I've run Prestone green 50/50 in my motor which is built, andnever had an issue with it. Just make sure you change your coolant regularly.
http://i277.photobucket.com/albums/k...6/IMGP1081.jpg
"Modifying a car becomes an addiction when the cost of the modifications is greater than the cost of the car new" - apparently, I have a major addiction :X
05AV6 is offline
post #4 of 4 Old 02-18-2011, 12:09 AM
DeeAgeaux's Avatar
This may be the poorest advice ever.
Just because your has not crapped out yet does not mean you should use Prestone.
Use Honda coolant or Zerex Asian Vehicle coolant.
03 Sedan I-4 LX 5AT 110k Miles
Enkei RP03 SBC 17X8 48MM offset
General Exclaim 225/50 R 17
Neuspeed Upper Strut Tie-Bar
TL Rear Sway Bar
Suntek Tint 20% F 5% Rear
Magnefine ATF
Pennzoil Platinum 5w-20 10k OCI
Motul 5.1
DeeAgeaux is offline
