Trans fluid changed - car still jerks when coasting to stop - Drive Accord Honda Forums
post #1 of 24 Old 03-29-2011, 06:50 AM Thread Starter
Hi guys,
Recently aquired an automatic 2005 V6 with 89k. I noticed that when coasting to a stop, the downshift is felt pretty well. I changed the fluid, which was very dark and had a bunch of gunk on the magnet. Did a 4x drain and fill, but the car still jerks when coasting. No issues so far with upshifting, but Im worried and dont want to be looking at having to replace the trans. Anyone have any advice?
Thanks
liquidskin is offline
post #2 of 24 Old 03-29-2011, 08:38 AM
Try some LubeGuard Red. It's the only supplement that one of the guru's on here recommends for them.
post #3 of 24 Old 03-29-2011, 09:16 AM Thread Starter
An easy, cheap solution.. I like it! Is it possible this could really cure the symptom?
post #4 of 24 Old 03-29-2011, 09:34 AM
It's possible but certainly not a guarantee. You can find the stuff on Amazon. Worth a shot!
post #5 of 24 Old 03-29-2011, 12:26 PM
If the LubeGuard Red doesn't work, look into replacing your 3rd and 4th gear pressure switches and using a trans fluid without friction modifiers (FM) like Redline Racing ATF. From my understanding, Honda's Z1 fluid has FM to make shifts smoother but ends up killing the trans later on.
http://tl.acurazine.com/forums/showthread.php?t=729149
http://tl.acurazine.com/forums/showthread.php?t=807045
nuron is offline
post #6 of 24 Old 03-29-2011, 01:22 PM
Originally Posted by I hate cars
Switches will cure the bump into gear. Fluid will cure a 1-2 shudder.
Originally Posted by dc5k20z1
the 3rd and 4th switches right?
Yes sir. When you go from park or neutral to drive, the transmission engages 3rd gear and then first gear. This reduces that jerk you feel when shifting into gear. When the switch values start to change, the trans stays in 3rd too long and you can feel the double bump of it going from 3rd to 1st. Normally it's so quick you don't feel it.
Originally Posted by VQPower37
IHC, just wondering why does the tranny shift first to 3 then to 1?
3rd has less leverage on the wheels so when you go from no load (park) to third and it applies power to the wheels, you don't get a jerk. Once the power is applied it can go down to first and you don't feel it. Same thing if you started off in third in a manual, you would have no acceleration but you also wouldn't have to worry about it snapping your head back.
Interesting. Mine has been doing the same thing (06 V6 Accord), and was fearing the trans was starting to go. Has anyone ever changed the 3rd & 4th gear switches on a 7th Gen V6 accord?
Grohe is offline
post #7 of 24 Old 03-29-2011, 05:04 PM
thisaznboi88's Avatar
Do the redline ATF. I just help my roommate change out 9qt 3 x3 this weekend. Best 100 bucks he ever spent.
Peace Out SuckA!!!!
thisaznboi88 is offline
post #8 of 24 Old 03-29-2011, 06:26 PM
out of control
07AccordEx-L's Avatar
You might have that confused with grade logic control. When I coasted to stops in my AT accord, it did the same. Grade logic control is engine braking for you when you coast.
2006 Accord Coupe V6 6MT w/Navigation
Previous:2007 Accord i4 5AT
My 7th Gen V6 6 Speed Build
http://www.driveaccord.net/forums/sh...344#post967344
07AccordEx-L is offline
post #9 of 24 Old 03-29-2011, 06:47 PM
Hi guys,
Thanks
Your tranny is a ticking time bomb. I should know, I have a 2006 V6. I would try the new Honda DW1 ATF fluid first before jumping to non-honda fluid like the Redline. I got DW1 fluid on mine by way of blown tranny and it softened up those rough downshifts.
Ilovemy06VtecV6 is offline
post #10 of 24 Old 03-29-2011, 06:53 PM
out of control
Honda transmission fluids have proven to be incompetent for smooth shifting. I've experienced redline on my buddy's MT and it shifts like butter. No notchiness whatsoever. It won't hurt his transmission to use redline. And If i'm right, Honda transmission fluids are just rebadges like the oil too.
post #11 of 24 Old 03-29-2011, 07:06 PM
Redline D4 is the only way to go....
rszappa1 is offline
post #12 of 24 Old 03-29-2011, 09:54 PM
paperboy42190's Avatar
i use redline racing type F fluid. but redline D4 is good too.
2007 Acura TL Type-S
paperboy42190 is offline
post #13 of 24 Old 03-29-2011, 10:00 PM
Ilovemyvtx's Avatar
I'm just going to add a +1 to honda fluid is trash...lol I would use a good synthetic like they are recommending.
Her name is Nikki and she runs like a banshee: 07 4dr Ex-L V6 6mt - Bronze
Gm Syncromesh Fm, TL-S sway bars, Ingalls torque damper, Stage 1 exhaust mod, Intake resonator delete, short shifter, RV-6 V3 j-pipe, RV-6 V3 PCD's, P&P intake runners, semi-ported/polished intake plenum with custom throttle body spacer, TL-S trans mount, 06 TL 5 spoke rims
Ilovemyvtx is offline
post #14 of 24 Old 03-30-2011, 05:34 AM Thread Starter
Any way to prove whether this is what's doing it? All that's apparent to me is that once the MPH goes down, the tachometer jumps for a second and then I feel the jerk.
Wish I knew that redline was the way to go before doing the Z1 flush, doh.
post #15 of 24 Old 03-30-2011, 07:12 AM
devi0us's Avatar
Mines has been doing this for about a year too. When the tranny shifts from 2 to 1, there's a harsh kick or jerk that can be felt.
I've changed the transmission fluid 5 times with Z1 since buying the car in late 08 at 38,000 miles. It hasn't helped, so I'm going to switch to Redline D4 later this Spring.
There have been other threads about this in the past.
Harsh downshift in 06 EX V6 at low speed
That thread basically said the jerkiness is indication of wear/transmission failure and that the best we can do is slow it down.
2003 Honda Accord EX-L I4 Auto 120,XXX Miles
Morimoto Mini H1 Retro 4300K | USA Spec PA15-HON2
devi0us is offline
