2003 V6 How to tell if transmission is about to die? - Drive Accord Honda Forums
post #1 of 26 Old 11-18-2011, 11:03 AM Thread Starter
I have a 2003 Accord V6 Coupe with 168,000 miles. It has been dealership maintained and has had that transmission recall done where they added a piece to lubricate the gears or something.
I have noticed lately when I accelerate or need some power to merge into the next lane, the car will give a sudden jerk and then accelerate. It gives a thud and seems to be happening a little more frequently.
Is this a sign of the transmission dying?
yazyazoo is offline
post #2 of 26 Old 11-18-2011, 11:06 AM
scar_cle's Avatar
03 transmission
Yes, that would be a sign. This is a common problem with those years (in the V6 models) Whatever you do, DONT CHANGE THE FLUID, that will only worsen the problem! You may want to check motor/transmission mounts too, that could be the problem...
scar_cle is offline
post #3 of 26 Old 11-18-2011, 11:20 AM Thread Starter
Why would changing the fluids worsen the problem?
yazyazoo is offline
post #4 of 26 Old 11-18-2011, 11:27 AM
2017 SMR Sport SE 6MT
GolftangoV2's Avatar
Change the transmission fluid. I suggest getting 12 quarts of Honda ATF and do three drain and fills driving a little between each drain and fill. See if that helps. But 168K on the original trans is a pretty good run.
2017 Sport SE 6MT in San Marino Red
2012 Pilot EX-L w/ NAV (family truckster)
https://500px.com/golftango
https://www.instagram.com/golftango/
GolftangoV2 is online now
post #5 of 26 Old 11-18-2011, 11:29 AM
+1 to all, especially to the drain and fill x3.
sodaks2k is offline
post #6 of 26 Old 11-19-2011, 08:00 AM
Pull the atf dipstick...what color is the fluid?
post #7 of 26 Old 11-19-2011, 08:16 AM
2016 Nissan Maxima Platnm
hillstones's Avatar
Sudden jerk and then accelerate, yes, those are the initial signs of failure. Changing the fluid won't stop the failure, it will eventually get worse and start to completely slip out of gear during acceleration between 1st and 2nd gear, and sometimes between 2nd and 3rd. Or, maybe the fluid is dire need of changing, or is low. But what you described is when the transmission begins to fail.
hillstones is offline
post #8 of 26 Old 11-19-2011, 08:33 AM
'03 E39 Sport - 5 Spd
RussianH2O's Avatar
My gf's Mazda 626 has an auto transmission that has been jerking between 1st and 2nd for over 3 years now. Granted its not a honda, i wonder how long you could roll like that.
RussianH2O is offline
post #9 of 26 Old 11-19-2011, 08:44 AM
hillstones's Avatar
Until it stops moving.
post #10 of 26 Old 11-20-2011, 08:49 AM
1. 3X3 DW-1 Drain and Fill (DO NOT FLUSH)
2. Replace Transmission Filter
3. Replace Transmission Pressure Switches
4. Add a Transmission Cooler to extend the life of the oil
5. 1X3 drain and fill every 10-15K miles
DIY and it should run you under 250 to do #1-4
2004 EX V6 5AT Coupe
-Jensens Renegade Window Tint
-Scosche AXIPHA Ipod/AUX Integration
-Enkei J10 Performance Series rims
-Borla Cat-Back Exhaust
-AEM Cold Air Intake
-Full Stage 3 LED conversion
-OEM Spoiler
-Custom Droid Mount
-B&M Transmission Cooler
-TB Coolant Bypass
-Full Length MDX Intake Spacer
-Lightweight Pulley
-ATLP V2 J-Pipe
-Battery Relocation to trunk
-1000W Sound System (custom subwoofer box)
Future Mods:
-TL-S Front & Rear Sway Bars
2 Amigos is offline
post #11 of 26 Old 11-20-2011, 09:09 AM
oh and clean your Transmission Solenoid screens while you are in there.
-OEM Spoiler
-Custom Droid Mount
-TB Coolant Bypass
-Lightweight Pulley
-ATLP V2 J-Pipe
Future Mods:
2 Amigos is offline
post #12 of 26 Old 11-21-2011, 05:49 AM
scar_cle's Avatar
Response to Transmission problem
My 2002 civic had a sililar problem from 80k till i got rid of the car at 152k. I had good luck with NOT changing the fluid. I took it to several transmission shops that all told me not to change the fluid no matter what anyone said, as long as it was clean, and didnt smell burnt They said that changing the fluid, would make it worse(one guy said he sees it all the time with honda transmissions, that someone would get the fluid changed, then within the next week, it would fail...I was happy that the transmission ran as long as it did slipping that way. It was a crapshoot. I learned to drive my car carefully as i knew when it would slip(alot more when cold) At 152k, i noticed it starting to slip really bad between 2nd and 3rd gear(almost redline'ing) so thats when i knew to get rid of it. Just remember a dealer will give you 2000$ + for it if it still runs, but if the tranny is shot, youll be lucky to get 500$ If you really like the car, im sure you can find a transmission shop that would do it for like about 2000$
THe engines in these cars run to 300k no problem as long as you've gotten routene oil changes(and dont floor it at every green light) that wont be a problem! Best of luck!
scar_cle is offline
post #13 of 26 Old 11-21-2011, 06:07 AM
There's some confusion here. I'm sure if you revisited the above conversation the key word was most likely "flush" and not change. DO NOT FLUSH Honda transmissions.
However, a fluid CHANGE will do no harm. Actually it will help with the AT performance and longevity.
post #14 of 26 Old 11-21-2011, 08:31 AM
scar_cle's Avatar
Thx for the clear-up, your excatly right...they said a drain and fill wouldnt cause harm, but the FLUSH ruins em! Thanks for clearing that up! Dont know why i couldnt post that in the 1st place...LOL
scar_cle is offline
post #15 of 26 Old 11-21-2011, 08:22 PM Thread Starter
OK thanks. DO NOT FLUSH. I am afraid to bring it to the dealer. They will definitely tell me it's the transmission and want to replace it rather than try the more consevative approach first.
If I do smooth acceleration it doesn't do the jerk.
yazyazoo is offline
