200,000 Mile mark - Drive Accord Honda Forums
post #1 of 13 Old 03-12-2012, 06:06 AM Thread Starter
cotton617's Avatar
200,000 Mile mark
I bought a 2003 Accord V6 EX just about a year ago with 184,000. I'm just about to 200,000 now and I was wondering what should I be doing for preventative maintenance. I have all the car's maintenance records; it got a timing belt / water pump done at about 100,000.
So I have about $1,000 to work with; I'm thinking about doing the timing belt water pump kit again, I've also got all new EBC brake pads and two new EBC rotors for the front that I'm going to be installing soon. What else is important right now? Spark plugs? Tranny fluid? Suspension?
Also where is a good place to get the timing belt water pump kit?
What are you guys using for engine oil? Do I really need to use the Honda Genuine? Just to play it safe I've been using Honda Genuine in combination with the Lucas Oil Stabilizer. I also use the Lucas Upper Cylinder stuff with every fill-up.
Thanks
cotton617 is offline
post #2 of 13 Old 03-12-2012, 06:29 AM
dont deviate
htekken's Avatar
tranny fluid for sure, timing belt, water pump, seals in that area, spark plugs, spark plug wires, distributor cap and rotor. possibly your power steering belt, a/c belt. fuel filter? check your air filter of course. brake pads just if they need to be replaced.
i bought all my parts for a major tune up from hondapartsunlimited
/94EX CD7 G77M/DZ-D1/JDM S2K HID/18RH-C5/WW-T/(gone)
/07SE CM5 NH700M/17V6-6/OEM LIP/Decklid/Hybrid LED/TSX HID/
/02IS BD1 B01B 8N8/TRD/SD/
htekken is offline
post #3 of 13 Old 03-13-2012, 02:30 PM
02-SE
96accordcoupe's Avatar
You should have posted this in the 7th gen section. Hopefully they move it. But you shouldn't use the lucas upper cylinder lube every fill up, you should use it every oil change.
2002 Honda Accord SE Coupe 2.3 I-4 VTEC (DD)
Taffeta White 134,xxx Miles
1992 Lexus SC400 83,xxx miles *My Toy*
Past Car:
1996 Honda accord coupe LX! 106,xxx miles
*Totaled as of 3-31-10 Dumb People!*
http://www.driveaccord.net/forums/sh...ad.php?t=45234[/SIZE]
96accordcoupe is offline
post #4 of 13 Old 03-13-2012, 02:38 PM
9 yrs & ~22K miles/yr...impressive!
Burn any oil?
Any sludge/varnish under the oil cap or on the dipstick?
Original precats?
gwiffer is offline
post #5 of 13 Old 03-13-2012, 02:43 PM
Make that BluFlsh
There are no plug wires, distributor, rotor or fuel filter on this car. There is an A/C (cabin) filter though incase the OP didn't know. I use Mobil 1 oil, and if it hasn't been done the brake fluid should also be flushed every 3 years.
92 EX Sedan auto - sold after 12 years (140k miles)
03 EX V6 Sedan auto - traded in after 13 years (135k miles)
16 EX I4 CVT with sensing - just getting started
BLCKFLSH is online now
post #6 of 13 Old 03-13-2012, 04:24 PM
2006 I4 MT
http://www.handa-accessories.com/accmaint03.html
Timing Belt Kit- V6 models only
Genuine Factory Honda Accord timing belt kit.
Includes the most common parts needed for a timing belt replacement.
Kit includes the following items: Timing Belt, Water Pump, Valve Cover Gasket Kit and applicable Drive Belt.
Fits Years 2003-2005
Retail $306.03
Discount Price $229.52
I ordered a bunch of stuff from them this morning before going to work. They shipped it out before lunch. Too bad they don't sell more parts.
2006 Accord LX Coupe I4 MT (sold)
2006accord4 is offline
post #7 of 13 Old 03-13-2012, 04:50 PM
CarlR33's Avatar
Welcome to the club. I am at 206k with my I4, 5sp.
CarlR33 is offline
post #8 of 13 Old 03-13-2012, 07:50 PM
dont deviate
htekken's Avatar
did not know this. thx for the info.
htekken is offline
post #9 of 13 Old 03-19-2012, 08:21 AM
I'm at 154,000. No major repairs done. Oil pan gasket and crankshaft seal were leaking so I had them replaced. Using Mobil 1 High mileage oil now.
05 EX I4
buster is offline
post #10 of 13 Old 03-19-2012, 09:27 AM
ezshift5's Avatar
Are you still on your first (original) set of factory Iridium plugs, hombre?
tks, ez.......
2005 Accord EX V-6 Coupe 6M
Taff. White;cargo net;7-24-05
'13 VW JETTA SPTWGN TDI 6M
Build date:03/12/2013 NO NAV
ZERO SUNROOF:CANDY WHITE
1982 VW Rab. Diesel Pickup 5M
Mojave Beige/ac/bedliner/alloys
(sold to restoration outfit)
ezshift5 is offline
post #11 of 13 Old 03-19-2012, 11:22 AM
06' 6-6 Sedan
2005 6mt's Avatar
tks, ez.......
ez just replace them and erase one thing from your list of worries man lol. I dont pretend to know your financial situation but it'll feel good for under 200$ and 70$ if you do it yourself
2006 EX V6 6MT Sedan Carbon Bronze Pearl / Ivory
2005 EX I-4 5AT Sedan Redondo Red Pearl / Black
1996 Harley-Davidson FXD
2005 6mt is offline
post #12 of 13 Old 03-19-2012, 03:44 PM
ezshift5's Avatar
Appreciate the guidance/advice. I take it you've replaced those plugs long before 154,000 miles...............
ez........
ezshift5 is offline
post #13 of 13 Old 03-25-2012, 11:11 AM
Found out the VTC o-ring and timing chain case were also leaking. All resealed. Mobil 1 HM back in the engine.
05 EX I4
buster is offline
