6-Disc CD Changer stopped working, making clicking sound - Drive Accord Honda Forums
post #1 of 19 Old 04-21-2010, 09:56 AM Thread Starter
Formerly TN03EX
EXLNT V6's Avatar
While on a road trip recently, the factory 6-disc CD changer in my 2003 EX stopped working. It was playing fine, until I put a CD in that it apparently didn't like and would not play it. All it would do is make the clicking sound over and over like it was trying to load the CD.
I ejected the offending CD, and switched back to the CD that I had been listening to prior, and it would not play either. All further attempts to play a CD after this have resulted in the same clicking sound.
Has anyone else had this problem?
2017 Accord EX-L V6 Coupe
Crystal Black Pearl | Ivory < PIC >
Mods:
- splash guards
- door sills
- interior illumination
- X5 Heads up display
- GoSafe 268 dash cam
Previous: 2003 Accord EX | 1997 Accord LX | 1989 Accord LX-i
EXLNT V6 is offline
post #2 of 19 Old 04-21-2010, 11:22 AM
ronK's Avatar
I'm not quite sure if this helps, because my CD player does not work at all in its entirety. I can't even get mine to CD mode. But what you can probably do is maybe reset the radio? I'm not an expert but I would probably try that.
2006 Alabaster Silver EX. 2.4L / AT
ronK is offline
post #3 of 19 Old 04-21-2010, 12:09 PM
Tito's Avatar
I've only had two Honda changers, but they both had the same issue which I resolved in the same manner. Sometimes, the processor gets jammed up while going through its sequence. The jam screws up the sequence and confuses the "brain" of the unit. The best remedy is to locate an operation it can complete, then let it do that until the end.
Start with CD #1 and repeat for all CDs. Expect 30 to 60 seconds for each operation.
Press load/eject. If it ejects a CD, remove it, then wait for the unit to stop cycling. If it wants a CD to be loaded, put one in. Make sure you let the changer come to a complete rest before pressing any other buttons or before performing any other operations.
All you're trying to do is give the changer the sequential command it's waiting for. It's either a Honda thing or a Clarion thing.
- T
2008 Accord EX-L V6
Belize Blue Pearl
Tito is offline
post #4 of 19 Old 04-21-2010, 12:10 PM
paperboy42190's Avatar
disconnect your battery for a few seconds to let it reset and try again.
2007 Acura TL Type-S
paperboy42190 is offline
post #5 of 19 Old 04-22-2010, 07:15 AM Thread Starter
Formerly TN03EX
EXLNT V6's Avatar
Thanks Tito! I think that's what happened. I ejected all of the CDs that were in the changer, powered it down, then started it back up again with a fresh CD and it worked!
Mods:
- splash guards
- door sills
EXLNT V6 is offline
post #6 of 19 Old 04-22-2010, 07:17 AM
lookin' clean
digitalh3lix's Avatar
Send a message via AIM to digitalh3lix
Mine jammed. cds wouldnt come out. I switched to the radio and couldnt get back to the CD menu ever again. I took it all apart, thought I fixed the jam, Never worked again. I was too cheap to buy another cd unit so I just threw in a AUX input.
2013 VW Passat
2007 ASM Accord SE Sedan 5SPD
Mods:Skunk 2 knob, Neuspeed SSK, Eibach Pro-kit, Koni yellows, Modulo front lip, Hybrid Tails, HFP Silverstars, General Exclaim 225/50/17, Hawk brakes pads, 17mm RSB, strut tower,Mini H1 Retro, 6K HID, Acura Legend brake calipers, Depo headlights,Raxles, Syncromesh,Boston Acoustics
1993 Prelude VTEC 5SPD BLACK - SOLD.
digitalh3lix is offline
post #7 of 19 Old 07-31-2010, 07:38 PM
how do you remove a 6 disc changer?
How do I remove my 6 disc changer from my 2002 honda accord? It stopped working and I need to take it out I just cant figure out how to take the dash apart. Please help......
jayhaylie is offline
post #8 of 19 Old 07-31-2010, 11:48 PM
2016 Nissan Maxima Platnm
hillstones's Avatar
You are in the wrong forum if you have a 2002 Accord. Try the 6th Gen forum. If no help there, use google. On the 6th Gen Accord, I think all you do is pull the trim from around the stereo, but search for the correct answer.
hillstones is offline
post #9 of 19 Old 08-01-2010, 02:15 AM
+1
i've taken apart the 6th gen radio before. not that hard, a few 2-3 screws around the trim and a few clips
post #10 of 19 Old 08-02-2010, 09:42 AM
Send a message via Skype™ to David G. Stern
Unhappy Cd Changer Jammed
OK,I am the proud owner of a 2003 Honda Accord EX-L that was my Mom's. I slid a Chicago CD into the 6 CD Changer, and enjoyed listening. However, when I tried to eject it, it would not come out. Just lots of grinding noises. Tried changing to other CD's. No luck. Don't know if it is software confused, as others have mentioned, or if one of the CD's is warped and jammed (this 106 degree summer is frying everything.) Any help on how to remove the unit from the dask would be greatly appreciated.
David G. Stern is offline
post #11 of 19 Old 08-02-2010, 02:28 PM
hillstones's Avatar
I guess your stereo really enjoys Chicago since it won't let you have it back. Disconnect the battery for awhile and re-connect it. Make sure you have your theft code handy to re-enter. Cutting off the power will cause the mechanism to reset and you might be able to eject the CDs. Press and hold the Eject button until it beeps and this will cause all CDs to be ejected. If this doesn't work, then your changer is pretty much dead like so many others. You can replace the CD/Tuner core by contacting OEMCarAudio on eBay.
post #12 of 19 Old 08-04-2010, 08:16 PM
Coldspeed
MetaEnder's Avatar
Figured I'd bump this thread a little with my own problem-
My vehicle:
>2003 Accord coupe EX
>Stock OEM navigation unit w/ 6 disc CD changer
My 6 disc changer is throwing the ERR / ERROR code at me and no longer functioning as of last night. Laaaaammmmeeee.
I've done some reading here and there and come up with these conclusions:
1. There may be a TSB out for the '03 changers? (TSB 03-017?)
2. I might be able to just replace the CD changer / tuner module.
3. I can attach a external CD changer and hook that to my AUX input and just never use my indash CD player again.
Note: I have already attempted a quick fix by resetting the unit via pulling the fuse, as well as disconnecting the battery.
Then there's this possibility:
I can replace/upgrade my stock navigation head unit and navigation disc tray (in trunk / navigation DVD with an '06-'07 set up.
Question:
If I were to go with upgrading my entire navigational unit would I just need to replace the head unit, navigation tray/DVD? (I wouldn't use XM other than for an IPOD so I wouldn't install the antenna.)
Would I have to do any other harness wiring or anything, or should it be a straight swap of upgraded parts since I already have a navigation unit installed?
Anyway, don't mean to threadjack, but at least I'm keeping it alive. Any input would be great! For now I'll just listen to the sound of my car.
12/06-04/08 '93 Sentra SE cpe
08/07-02/10 '98 Accord EX-V6 cpe
07/08-05/09 '91 Festiva
3/10-Current '03 Accord EXNV-V6 cpe
MetaEnder is offline
post #13 of 19 Old 08-06-2010, 10:49 PM
Coldspeed
MetaEnder's Avatar
So since my changer is kaput I'm ordering a USA spec dealy-doodad.
Should I order a new cd changer from this OEMCARAUDIO guy on Ebay while I'm at it? Since I have to pull out the navi unit to get to the AUX port I figured maybe I could attempt to swap out the changer.
Any input would be great.
post #14 of 19 Old 08-07-2010, 05:10 AM
Jeff's Avatar
Send a message via Skype™ to Jeff
I've noticed the same problem as the OP with my car. I haven't used my CD changer for awhile though, because I have an AUX input. It's a rarity if the CD changer starts playing the CD that I want... if it doesn't, it'll just spit the disc out.
2007 Honda Accord EX-L i4 Sedan
Jeff is offline
post #15 of 19 Old 08-08-2010, 09:51 AM
hillstones's Avatar
If you are pulling the head unit to install the iPod kit, then I would definitely contact OEMCarAudio on eBay and replace the CD/Tuner core at the same time. You don't want to do the same installation twice. Easier to do it all at one time. Since you don't have XM, I would get the Dice Electronics Silverline iPod kit, much more reliable than the USASpec.
