Need Measurements & Feedback - Concept Project - Drive Accord Honda Forums
  • 1 Post By Lowniss37
  • 1 Post By MrRangerZr1
post #1 of 5 Old 03-19-2017, 10:24 PM Thread Starter
First off, mods please move if the wrong section for this.
Hey all, first time here and I do not own a Honda, thus the need for your help.
Searched a little bit, but couldn't find the information I'm looking for.
Project: Offroad Desert Buggy - 2 seater.
I've been wanting to build a buggy for quite some time and have decided upon using a Honda for the engine since parts tend to be very inexpensive as well as readily available just about wherever you are. This is meant to be quite a bit of a budget build and to learn a lot throughout the whole project. Buggy is intended to be built to Class 10 - Limited Motor racing regulations. Everything will be designed to spec minus the actual engine itself, since Class 10 is limited to a N/A 2500cc 4cyl. Decent power out of a small engine is more expensive than purchasing a larger motor with approx equal power. Not currently built to actually race, although possible in the future with engine swap.
Concept Specifications:
Drivetrain: J30 3.0L v6 w/ factory auto trans.
Chassis: Open tube design with sheetmetal skins.
Suspension: A-arms front & trailing-arms in rear. Single coilover (probably dual rate) with secondary shocks on each corner.
Trackwidth: 72" WMS to WMS
Wheelbase: 112"
Wheels: 5x5.5" steels, probably 15x8"-10"
Tires: Currently have a set of 32"x11.5R15 Yokohama Geolander AT/S takeoffs from my truck. Planning on running 32's or 33's, but will design to fit up to 37's just in case of engine upgrade later on.
Weight: Planning to be sub 3000lbs all said and done.
Plan:
Purchase a used 2000 Honda Accord w/ 3.0L v6 and remove the engine, transmission, wiring harness & ecu, ignition, and cooling system. Rest of the vehicle will probably be parted or scrapped since can't think of anything else useful for the project. Probably keep gear shift and parking brake lever. Rest of the buggy will be custom tube as well as locally sourced parts. Trying to stay as low of a budget as possible as well as making parts easily sourced whenever something breaks.
The help I need from y'all:
-3.0L v6 engine mounting dimensions as well as overall dimensions & approximate weight. Doesn't have to be extremely accurate, just looking for overall space needed for block and frame width.
-Overall Auto Transmission Width & approximate weight.
-Forgive my ignorance, but transmission is chain driven from engine, correct?
-Max CV Angle for the auto trans? (probably around 35-45 degrees)
-Any spools for transmission?
Feedback needed:
Any other preferred Honda engine/transmission that outputs around 175-200bhp. Looking for best power/weight ratio, but cost rules.
I've heard that the auto transmissions don't last a long time behind the 3.0l v6. Any parts that can be swapped in to strengthen the weak points?
Since we all love photos, here's some inspiration for the project:
theblindchicken is offline
post #2 of 5 Old 03-20-2017, 02:54 AM
Lowniss37's Avatar
Here is what you need
https://grandrapids.craigslist.org/ptd/6023388201.html
theblindchicken likes this.
2007 Accord Sedan i4 Alabaster Silver
AMR coil overs / Swift Springs 12k/8k
Weds Sport Tc105n 17x8 +42 square / PSS 225/45
TruHart front upper CA's / UR tower bar
Hardrace rear lateral links /rear upper CA's
PowerGrid adjustable low profile endlinks
DBA T2 slotted front rotors, 6-6 calipers
ShadowSpeed ABS trunk lip / 6000k HID lows
Lowniss37 is offline
post #3 of 5 Old 03-20-2017, 10:52 AM Thread Starter
Originally Posted by Lowniss37 View Post
That's an awesome find! A bit out of my hoping budget, but always an option to upgrade to at a later time!
post #4 of 5 Old 03-20-2017, 11:02 AM
Mechanical Stig
Man, have you been playing too much Forza Horizon 3 lately? Lmao
But on a serious note, really interested to see what you build.
2017 Honda Odyssey TE
2017 Honda Accord EX-L
2014 Honda Civic EX-L
2010 Honda Odyssey EX-L (USDM AF!) VCMuzzler - Catless Downpipe/Pre Cat Deletes - Third Cat Delete - Custom K&N SRI With Cold Air Scoop - TB Coolant Bypass - Thermal Gaskets - BC Coilovers
MrRangerZr1 is offline
post #5 of 5 Old 03-20-2017, 02:55 PM Thread Starter
Hahaha quite possibly! Actual build would be quite a ways out. Definitely still in the concept and overall design plan at the moment.
Will definitely get to 3D modeling it all up as time permits.
