Brake pad mm indicator....what does it mean? - Drive Accord Honda Forums
post #1 of 12 Old 12-15-2007, 10:51 AM Thread Starter
in4mation's Avatar
I just got back from the dealer in which they performed the maintenance interval for my car. On the bottom of the work order, they have the following:
BRAKE PADS GOOD FRONT 8MM REAR 6MM
What does this mean? Does this mean that my rears are wearing faster than the fronts? Also, at what point in MM should I replace the pads?
Thanks!
in4mation is offline
post #2 of 12 Old 12-15-2007, 11:49 AM
Swirl Free
Thanks!
Well you 1st need to know how thick they were to start off with... some front pads are bigger right off the bat.
FYI: My rear pads wear faster than the front.. Crazy
2003 Accord EX I4- Satin Silver Metalic - Sold on 3/14/2011 after 202,000 great miles!
2011 Volvo V50 R-Design - Silver Metallic - Purchased 3/12/2011
2013 Honda Crosstour EXL 4WD - Crystal Black Pearl
MotorCity Honda is offline
post #3 of 12 Old 12-15-2007, 12:18 PM
namegoeshere's Avatar
Mine were at 9mm front and 7 mm rear at the last check-up. That means my rears are wearing a little faster.
I think you should replace them when they're 3mm or less.
namegoeshere is offline
post #4 of 12 Old 12-15-2007, 01:02 PM
Accordlover's Avatar
Send a message via AIM to Accordlover
Or when they click as your brake like mine just started doing!
Accordlover is offline
post #5 of 12 Old 12-15-2007, 03:01 PM
O do u know the buffinman
Inspector1's Avatar
Front pads start at 11mm and rears 9mm..
I believe minimum on both is 1.6mm.
I1
4 Honda family...
08 EXL V6 W/Nav PMM 4Dr @ 115K miles
My daily driver
08 Pilot EX-L Dark Cherry Pearl @ 51K miles
The Mrs. daily driver
The Kids
07 EXL I4 Moroccan Red Pearl 4Dr @ 96K Acquired 6/13
06 EXL I4 Carbon Bronze Pearl 4Dr @ 111K Acquired 3/13
Gone but not forgotten....
02 EXV6 Naples Gold 4Dr
96 VP I4 Heathermist 4Dr
Inspector1 is offline
post #6 of 12 Old 12-15-2007, 08:17 PM
I'd hope they measured the rear pads using the INSIDE pad.
I've never seen one NOT wear the inside pad faster than the outer on the rear discs. If the pads freeze in the carrier, then all bets are off, they usually destroy the pads (stick on) or the outer pad stops working altogether.
Usually, if you go by percentage, the outers will be at about 25 to 30% and the inners near the bottom by the wear indicator are usually at 5% to essentially zero.
On the front brakes, you'll usually see the RF (passenger) wear slightly more than the left.
post #7 of 12 Old 12-20-2007, 11:51 AM
Accord Power
What about noise? What kind of noise will indicate a brake change?
Accord2004 is offline
post #8 of 12 Old 12-20-2007, 12:29 PM
high pitched screech
2002 Accord EXVL Auto Sedan - Nighthawk Black Pearl / Quartz, fog lights, mud guards, wheel locks, trunk tray
1994 Pontiac Grand Am GT Auto Coupe
benjamming is offline
post #9 of 12 Old 12-20-2007, 01:16 PM
Swirl Free
Thanks!
I1
Looking at the above three posts you can conclude that your front and rear pads are actually wearing even and have worn 3mm
Most pads have a metal "squeaker".. once the pads wear to a certain point there is metal to metal contact hence the horrible sound.
post #10 of 12 Old 12-22-2007, 12:57 AM
Used to Drive a Hummer H2
I wonder if you'll need to replace the rotors when the wear indicators start squealing...
I <3 the princess family!
'05 Hummer Accord EX-L 4cyl/auto Navi
The legendary 20 MPG and Below-er
'07 Toyota Camry XLE V6 Navi/Bluetooth/VSC/Smartkey Sky Blue / Ash
greg-ster is offline
post #11 of 12 Old 12-22-2007, 03:54 PM
Squealing is caused by a small piece of metal designed for the purpose of warning when the pads are worn out. So turning the disc is not required just because of the squealing.
2008 Accord Sedan EX-L V-6 w/Navi
Mystic Green Metallic/Black
bbrowncods is offline
post #12 of 12 Old 12-22-2007, 07:32 PM
XLR8's Avatar
Send a message via AIM to XLR8
3mm is correct for replacement. That is where our gauges say RED is at 3mm. Anything above is fine.
2008 VW Jetta 2.5L I5 5-speed Manual
-Tyler
Used to drive: 2004 Honda Accord EX-L V6 Auto
XLR8 is offline
