Get rid of the Accord V6 - Drive Accord Honda Forums
post #1 of 66 Old 04-10-2014, 09:30 AM Thread Starter
Get rid of the Accord V6, and make it a turbocharged i4 for better fuel economy. BMW did it with 328i, why not Honda?
A common myth is that Honda mechanics believe that turbocharging an engine decreases its overall life expectancy, so that's why Honda probably sticks to naturally aspirated engines which are supposedly more reliable. But how true is this?
enchantedsky is offline
post #2 of 66 Old 04-10-2014, 11:01 AM
Because turbo will always lug, therefore V6 is better
2012 Accord EX-L coupe 6-6
vlad777 is offline
post #3 of 66 Old 04-10-2014, 02:49 PM
03-SSM-AV6-6MT
ChrisQ80's Avatar
Look at Honda's reliability compared to other brands. Smart people won't own a BMW out of warranty, unless money is no object.
Personally I'd rather have a powerful N/A car built than a turbo. I think an engine should make all of it's power all of the time. I like N/A.
2003 Accord V6 6MT
OEM kit/spoiler/fogs. 35% tint. Custom 3.5inch CAI, 3.7 Intake mani and TB, coolant bypass, RV6 Jpipe, 2.5 custom cat back to 2.5 Magnaflows, TL ECU tuned on Hondata Flashpro, Ingals tq dampner, JDM DC5-R 6mt shift knob, TL-S rear sway bar, H&R sport with Koni adjustbl. Black housed hdlights, Akoi LED 9006 and H1 bulbs gloss blk roof. Enkei RPF1 17x8 wheels with Michelin Pilot Super sport 235/45/17 tires. 245whp 220wtq
2015 Honda Civic LX 5MT (daily)
ChrisQ80 is offline
The Following User Says Thank You to ChrisQ80 For This Useful Post:
pauly (04-14-2014)
post #4 of 66 Old 04-10-2014, 05:30 PM
Kamdog's Avatar
Because Honda doesn't have too. There are no 400+ HP cars for Honda to average in to their mix.
Kamdog is offline
post #5 of 66 Old 04-10-2014, 06:31 PM
V6 sounds better.
squid42 is offline
post #6 of 66 Old 04-11-2014, 07:17 AM
"Lag" not "lug"?
2013 Accord Sedan EX-L Nav., Basque Red Pearl;81,000+ miles.
2004 Odyssey EX-L, Havasu Blue Metallic, 245,000 miles
1998 Accord LX Sedan 5-speed, Heather Mist Metallic; went to live with my youngest son. Died Jan. 2015 with 246,000+, (right front axle broke).
HondaBob is offline
post #7 of 66 Old 04-12-2014, 04:50 AM
Baldeagle's Avatar
I just came from a GTI (turbo I4) and regularly drive a good friendís 2013 BMW 528i. The power delivery of Hondaís 3.5-liter V6 is far superior to BOTH engines. It has much better throttle response and a more linear power delivery.
The primary benefit I read about turbocharged engines is better fuel economy but Iím not sure if that is true. I averaged about 29 mpg in my GTI and about 27 mpg in my 6-6. (I donít know the actual mpg for the 528i but I am sure it is less.) The problem with the GTI and all other turbo charged cars I know is that it requires premium fuel and my 6-6 runs on regular. When you factor in the lower cost of fuel, the overall fuel cost was the same in both cars. But my 6-6 is larger (+350 lbs) and faster (almost one full second to 60 mph.) To me this proves a turbo I4 has no efficiency advantage over a good V6.
Also turbocharged engines are complicated and HOT. They are good for short bursts of power but not something you can confidently drive hard for sustained time. Go up a steep mountain pass for a half hour under boost and youíll risk cooking something. No problem in a V6.
I suppose I am not so much pro-V6 as much as I am anti-turbo. If the car is smaller and canít fit a ďfatĒ V6 in the engine bay, Iíd much rather have a N/A bigger I4 than a smaller turbo-4. Compare two similarly sized vehicles like a VW CC (200 hp) to an Accord Sport 6MT (189 hp). Both cars are 6.6 seconds to 60 mph but the Sport gets 5-6 mpg better fuel economy on the highway on regular fuel. The 2.4-liter I4 costs less, is more reliable, runs cooler, gets better fuel economy and does not suffer from turbo lag. It has pretty much the same superior attributes as the V6 but on a slightly smaller scale. I really donít see the benefits of a turbo-4.
Baldeagle is online now
The Following 3 Users Say Thank You to Baldeagle For This Useful Post:
CDsDontBurn (07-13-2014), HKphooey (04-19-2014), pauly (04-14-2014)
post #8 of 66 Old 04-12-2014, 05:26 AM
ezshift5's Avatar
FWIW: My 6M routinely - highway (not city) calcs upper 30's MPG in 6th gear circa 2150 RPM. No turbo (just a fuel efficient, reliable V-6 - 139,000 on the original plugs)
Try that with a turbo.
ez
2005 Accord EX V-6 Coupe 6M
Taff. White;cargo net;7-24-05
'13 VW JETTA SPTWGN TDI 6M
Build date:03/12/2013 NO NAV
ZERO SUNROOF:CANDY WHITE
1982 VW Rab. Diesel Pickup 5M
Mojave Beige/ac/bedliner/alloys
(sold to restoration outfit)
ezshift5 is offline
post #9 of 66 Old 04-12-2014, 07:10 AM
Flyboy's Avatar
Many European countries tax automobiles on the displacement size of the engine. Turbo charging is the only way to get more power without increasing the displacement. Why would anyone want the extra complexity and cost rather than just make a bigger engine? Turbo chargers operate at very high RPM which produce lots of heat and higher pressures which means higher maintenance costs. Some of the extra components are the turbocharger, a waste gate, controller, inter-cooler and associated control parts.
Honda obviously knows how to make turbo chargers because they build world class racing engines but turbochargers don't belong on passenger cars.
2013 Accord Coupe EX-L San Marino Red
2015 CR-V EX Urban Titanium Metallic
2007 Fit Sport Silver 65,000 miles and going strong.
Previous Honda: 2000 Accord Coupe, 1994 Accord Wagon Red, 1988 Prelude White 5 speed manual, 1981 Accord 4 Door Ivory 5 speed manual
Previous Cars before Honda: 73 Mazda RX2 manual, 63 VW Bug manual, 63 Alfa Romeo 2600 Spyder manual, 70 Toyota Crown manual, 59 Vauxhall Victor manual (worst car ever produced, a pre Yugo, Yugo)
Flyboy is offline
post #10 of 66 Old 04-12-2014, 07:15 AM
Dan
Dan's Avatar
Honda makes some of the best engines in the world. The V6 won some awards. but it does suck gas.
3.0-AT (7th Generation)
Notchback-stroker 410- 527 RWHP on nitrous
Dan is offline
post #11 of 66 Old 04-12-2014, 07:47 AM
Baldeagle's Avatar
I disagree. It does not suck gas. If you put a turbocharged I4 in your car that provided the same level of performance it would deliver essentially the same fuel economy but on more expensive premium fuel.
post #12 of 66 Old 04-12-2014, 08:05 AM
Makes me wonder when Honda will do direct injection in the V6ens.
squid42 is offline
post #13 of 66 Old 04-12-2014, 08:56 AM
Elvira
Miker's Avatar
Actually that lag is only present with high-pressure turbos. If they would use a low-pressure turbo there would not be any lag in the application of boost.
Volvo used low-pressure turbos on their engines in 2000 (I have one) and the power application is smooth. If you are unfamiliar with low vs high pressure turbos, the low is virtually always "on" therefore you don't have any lag before it starts boosting. You would think "always" being on would hurt the longevity, but there isn't any more degradation as far as I have read or experienced myself.
Longevity depends on how you care for it. Good quality oil, mainly sythetic, and good change intervals will keep the turbo from coking up. The intercooler is simple enough to be left alone. I NEVER performed the turbo cooldown after a drive EVER and nothing detrimental happened to the turbo. They are fairly simple machines.
As opposed to our 6's or the DI I4's here those turbo'd engines DO need 93+ if you really want to get full power out of the engine. That higher compression from all that air really does need that octane. It'll run on 87 but why would you? Let's not turn this into another octane thing though, just concurring that there's your extra cost with a turbo.
As far as extra heat during full out running up hills, long range drives, etc. I can't speak to that. This was a daily driver. Although when I was on another forum for Volvo, there was very little talk about poorly operating turbo's or massive numbers of failures because of a turbo cooking itself. So that extra cost might be caused by how really hard you run it.
Compared to the 3.5 6 in my car now, I get comparatively the same MPG. 33 for the turbo 1.9l I4 5 speed auto(160 hp) and 31 for the 3.5l V6 (278+ hp) 6 speed auto. MPG done old fashioned way and I did say comparatively the same considering the output numbers on both engines and size of engine.
Actually I have more concern about the VCM on this engine causing problems vs a turbo. BUT it's all how you take care of it. If a turbo goes bad it's purely a plug 'n play fix. Not cheap, but easy (kinda like my last GF). VCM goes bad, well I'm not gonna think about that but as far as I can see the mechanics of VCM don't appear to fail. The application of same might screw around with other systems and parts like plugs possibly fouling.
My .03 anyway.
Mike
2013 EX-L V6/6A (no nav) sedan CBP
"vita est brevis, vado pro V6" - Me
"Speak only when you feel that your words are better than your silence." - Anonymous
Please help improve the DA search function add tags to your/others posts and threads. Anyone can add tags to any thread. TIA
Miker is online now
post #14 of 66 Old 04-12-2014, 09:35 AM
CVT
dparky's Avatar
small displacement turbos dont always mean better fuel economy. with smaller engines you gotta rev them out to get some power, which doesnt translate to meeting EPA estimates. with a larger displacement v6, you dont have to rev them out to get the power, especially since honda enhanced the powerband for the 9th gen.
im quite sure that the v6 in the 9th gen is more efficient than the turbo i4 in the midsize segment anyway..
2013 White Orchid Pearl Accord Sport
35%/30% Llumar Ceramic Tint
Debadged
3M Gloss Black Roof, B Pillars & Random Chrome Bits
19mm TL RSB
Gloss Black Roof Spoiler
ExLed Interior Kit & License Plate Light 5000k
OEM V6 Headlights with 4G TL Retrofit
Full Modulo Replica Lip Kit
VMR 19x9.5 +45 Squared
255/35 Continental DWS06
Tein Street Advance
dparky is offline
post #15 of 66 Old 04-12-2014, 09:43 AM
CVT
dparky's Avatar
with a v6 you get a flatter power band and throttle response, especially for the 9th gen v6's. also you gotta take into consideration that with a smaller displacement engines you gotta rev them out to hit full boost. whereas with a v6 you dont have to rev quite as high.
the v6 is as efficient if not more efficient than the 2 liter turbos offered by hyundai/kia/ford. i'll take N/A over a F/I anyday, when it offers the same performance and efficiency.
Debadged
19mm TL RSB
Tein Street Advance
dparky is offline
