What should i put Rv6 PCDS or HFPCS - Drive Accord Honda Forums
post #1 of 24 Old 05-13-2017, 09:33 AM Thread Starter
Hello every one...i have takeda intake i wanna get Pre cat delete ..i have honda accord 2013 v6 .for more power i should get PCDs?
Thank you for your help
obitelb3 is offline
post #2 of 24 Old 05-13-2017, 09:52 AM
Your Maintenance Minder
Hello.
2005 Accord EX-L
2-door Coupe
PZEV emission vehicle (!)
4-cylinder, Automatic Transmission
Acura RSX wheels & 215/55R 16 Continental Extreme Contact DWS tires
136k miles (as of May '17)
RickBlaine is offline
post #3 of 24 Old 05-13-2017, 09:57 AM
Kinsume's Avatar
PCDs will give a bit more horsepower and torque over the HFPCs, however it will come at a cost. The increase is fairly minimal, maybe 2 or 3 additional horsepower, however you will certainly have an exhaust smell in your car. On top of that if the state you live in does visual inspections, your car will most certainly fail as you have no cats on it, even if it passes the sniffer test.
I currently run the HFPCs and I have no complaints from them. The installation wasn't too bad but it was time consuming. Front pre-cat took about 1-2 hours while the rear one took around 2-3 hours.
2013 Honda Accord Ex-L v6 Coupe
Takeda Short Ram Intake Stage-2 Wrinkle Black
Rv6 High Flow Pre-Cats
Rv6 J-Pipe
Rv6 Double Resonated Mid-Pipe
Ktuner (Turbogixxer tune in progress, on 3rd tune)
VCM and VSA disabled
Upcoming Mods
Enkei Racing RPF1, Bright Silver 18x7.5, 48mm offset, 17.6 lbs each
Continental ExtremeContact DWS 06, 235/45ZR18, 25 lbs each
Kinsume is offline
post #4 of 24 Old 05-13-2017, 08:34 PM Thread Starter
is it gonna damage my engine ?and what kind of smell from intake?as long i not gonna smell it inside car i okey with that )
obitelb3 is offline
post #5 of 24 Old 05-14-2017, 09:34 AM
Kinsume's Avatar
@obitelb3 As long as they are installed properly, no they won't damage your engine. Your intake will not produce any kind of smell, it is the PCDs that would produce an exhaust smell caused from the removal of the cats. HFPCs do not have any kind of exhaust smell and only have 2-3 horsepower lower than the PCDs.
Rv6 J-Pipe
Upcoming Mods
Kinsume is offline
post #6 of 24 Old 05-15-2017, 03:52 PM Thread Starter
so which one is more louder?your recommend me HFPCs?
obitelb3 is offline
post #7 of 24 Old 05-16-2017, 03:44 PM
Kinsume's Avatar
The PCDs are louder naturally as they completely remove the cats and replace it with straight-pipe. This causes there to be a smell in the car that would typically be removed by the cats. If you can put up with that, and live in a state that does not do visual inspections on cars then you should go that route.
Rv6 J-Pipe
Upcoming Mods
Kinsume is offline
post #8 of 24 Old 05-17-2017, 06:01 AM
Knxwledge's Avatar
Hey man do you still have the stock exhaust in your car? Did the RV6 hfcp, j pipe and mid pipe changed the tone at all? Curious because I'm planning on doing those 3 and wondering if it will change the tone of the stock exhaust
Knxwledge is offline
post #9 of 24 Old 05-17-2017, 12:33 PM
Kinsume's Avatar
@knxwledge Yes it did, pretty significantly I might add. Originally I only had the HFPCs and J-Pipe but there was too much rasp for my liking, mid-pipe got rid of the rasp completely and I love how the car sounds so didn't even bother changing the muffler.
If you're curious I made a quick clip of how she sounds.
Knxwledge and MrRangerZr1 like this.
Rv6 J-Pipe
Upcoming Mods
Kinsume is offline
post #10 of 24 Old 05-17-2017, 03:48 PM
Knxwledge's Avatar
https://www.youtube.com/watch?v=tgAJGs-LbcA
That sounds great. I bet it even sounds nicer in person. Thanks for the clip.
Quick question, does the RV6 J-Pipe retain the 3rd cat?
post #11 of 24 Old 05-17-2017, 05:50 PM
Kinsume's Avatar
It does not, which I'll tell you right now most shops won't touch it because it removes the cat lol. That being said, it is probably the easiest piece of the 3 to install, the mid-pipe was only harder because you need a ratchet and wrench to get those bolts off which is a pain on your own. The pre-cats are probably the most annoying part, just a heads up the rear pre-cat will not come out without a fight once you get it taken apart lol. I had a friend helping me out getting all 3 of them installed, so it wasn't quite as bad. Still took us around 5-6 hours total, but I have no regrets.
Rv6 J-Pipe
Upcoming Mods
Kinsume is offline
post #12 of 24 Old 05-18-2017, 08:37 AM
I have PCDs and if everything else is stock the added sound is minimal but good. It adds a nice subtle growl and is really nice when you get on it. Rasp comes from removing the third cat with PCDs or HFPCs. The mid pipe is designed to remove rasp. There was no added smell inside the car but alil subtle added smell if you go near the exhaust tips after initial start up. A tune will probably address that further because a tune makes more power by leaning out what the factory computer does.
TopSniper69 is offline
post #13 of 24 Old 05-18-2017, 05:38 PM Thread Starter
Topsniper what kind of smell? is it really bad?
obitelb3 is offline
post #14 of 24 Old 05-19-2017, 04:06 AM
On a scale of 1-10 with 10 being the strongest it's maybe a 1 but again only during initial start up and only if you start the car then get out and go to the back of the car.
post #15 of 24 Old 05-19-2017, 03:02 PM
Kinsume's Avatar
That seems inaccurate, sorry.
Rv6 J-Pipe
Upcoming Mods
Kinsume is offline
