2003 Honda Accord TCS Dash Indicator Lights - Drive Accord Honda Forums
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
post #1 of 9 Old 10-02-2009, 05:18 PM Thread Starter
I have a 2003 Honda Accord Coupe V6 automatic. Several months ago I had a problem shifting the car out of Park into any other gear, when I finally got it into gear the TCS Activation indicator and TCS indicators dash lights would come on. I had a local mechanic troubleshoot the problem and he had to replace the brake switch. The problem with the gear shift is fixed but both TCS dash lights still come on. Is there a way to reset these so they do not come on?
kool961 is offline
post #2 of 9 Old 10-03-2009, 09:56 AM
Did the shop scan the ABS system and clear the codes? If they did, they should have performed the TCS neutral position re-learn. The lights won't go out until it is done.
post #3 of 9 Old 10-04-2009, 05:44 PM Thread Starter
I think they scan the system and found one code and cleared it, that appeared to be the one that caused them to replaced the brake switch that was the only one they saw. What is the procedure for performing the TCS neutral position re-learn?
Thanks for the help.
kool961 is offline
post #4 of 9 Old 10-04-2009, 06:27 PM
You'll have to give me until Monday afternoon, to get the procedure out of my manuals.
post #5 of 9 Old 10-05-2009, 05:38 PM
TCS pressure sensor neutral position memorization (normally you need the HDS or a good scan tool) but here's the work around.
jump pins 4 and 9 on the DLC with the key OFF
watch the ABS indicator light area.
Turn the key on, ABS light goes on, then off after 2 seconds.
within 2 seconds, push the TCS off switch
push the button again only AFTER the ABS light comes back on.
The TCS triangle should blink, then the 3 lights should go out together.
remove the jumper between pins 4 and 9 of the DLC.
The Following 3 Users Say Thank You to Fredsvt For This Useful Post:
2i2dk1ny2i3 (06-09-2015), Aviography (12-08-2013), jthornerjr (11-22-2015)
post #6 of 9 Old 06-09-2015, 07:46 PM
wow i'ma give that a try
i went to O Reilly's and they had a Bosch but it wouldn't clear the codes
2003 Accord 4dr EX V6 Graphite Pearl aka Dark Grey
220,000+ on 2nd Transmission
Mods: Driven heavily modded vehicles. "once a modder always a modder"
*G Modifiers Crew Member #2*
2i2dk1ny2i3 is offline
post #7 of 9 Old 06-09-2015, 08:09 PM
tried it the middle ! still stays on
mine was also labeled different...in very small numbers
16 - - - - - - 9
8 - - - - - - 1
post #8 of 9 Old 11-22-2015, 09:15 PM
Sensor reset worked!
Thank you so much for posting this. It took me several trys to get the procedure to work, but it finally took and solved my problem. I replace the failed modulator on our '03 Accord and then was getting the pressure sensor not calibrated error code.
This is the only place I was able to find the procedure. Alldata was useless and I didn't want to go to the dealership just to have the sensor matched to the car.
Thank you!
jthornerjr is offline
post #9 of 9 Old 02-29-2016, 09:42 AM
drzcb7's Avatar
Just worked for me Thanks!
drzcb7 is offline
abs light, abs reset
