P0171 code - Drive Accord Honda Forums
post #1 of 12 Old 03-22-2010, 05:07 AM Thread Starter
P0171 code
Hi
I have 1999 Honda accord lx 2.3 . I just got a p0171 (fuel system lean ) code. I changed PCV valve cleared code and it can back 3 days later. I read it might be a fuel pressure regulator. Is there anyway to check to make sure what it is .
Thank You
mickey1987 is offline
post #2 of 12 Old 03-22-2010, 05:10 AM
ry05coupe's Avatar
I had the same code after installing a cold air intake. For me it just took cleaning the MAF and resetting the ECU by leaving the battery disconnected for 10 minutes or so. It hasnt been back since.
Latest mod: 35W 3000K Fogs.
2005 Accord Coupe i4
ry05coupe is offline
post #3 of 12 Old 03-22-2010, 06:10 AM Thread Starter
Do you mean " MAP sensor" I cant find a MAF sensor on a 1999 accord 2.3
post #4 of 12 Old 03-22-2010, 07:41 AM
I forget the code but it translated to "fuel system lean" and it was the fuel pressure regulator on a 99 lx I4. There was a tsb for this but warranty didn't cover it since I was WAY over on the warranty. I know it doesn't answer your question completely but wanted to pass along the info.
post #5 of 12 Old 03-22-2010, 11:40 AM Thread Starter
Do you remember what the fix was?
post #6 of 12 Old 03-22-2010, 02:37 PM
ry05coupe's Avatar
My bad I was thinking about my 05, didnt notice the year of yours.
post #7 of 12 Old 03-22-2010, 03:47 PM
Lean codes can be caused by a number of different things.
I'd need to know when it takes place, as in freeze frame data from when the code stored.
I'd also need to know MAP voltage readings at hot idle, fuel trim values at idle, 2500 no load, and steady state 45 mph cruise.
I'd also like to see a graph of the air/fuel sensor readings.
The car must be free of exhaust leaks both near the primary air/fuel sensor, and after the cat within about 18".
post #8 of 12 Old 03-23-2010, 06:34 AM
In my case it was the fuel pressure regulator BUT like Fredsvt said it can be caused by many different things. I took mine to the dealer for the diagnosis and it ran $95 installed.
post #9 of 12 Old 03-30-2010, 07:52 AM Thread Starter
Just wanted to update..
I found a Delphi FP10198 Fuel Injection Pressure Regulator replacement for 23.22 . It took about 10 min to change and no CEL for 5 days now.
Thanks for all the help!!
post #10 of 12 Old 07-15-2010, 06:43 PM
P0171 system too lean bank1
P2A00 OXYGEN SENSOR BANK 1 SENSOR 1
should i replace the o2 sensor first or the fuel pressure regulator or both since the cost is not that high .
maniek is offline
post #11 of 12 Old 07-15-2010, 09:01 PM
In addition where is bank 1 sensor 1 o2 sensor located
maniek is offline
post #12 of 12 Old 07-16-2010, 03:17 PM
B1S1 is the first sensor in the system in a 4 with only two sensors.
On a V6 with more than 2 sensors, it's the rear bank front sensor.
