20 Amp fuse replaced with 30 Amp - Drive Accord Honda Forums
post #1 of 12 Old 12-13-2005, 10:27 AM Thread Starter
Hi:
Well I solved the problem I had with my brake lights and my gear being stuck in park. Saturday night my car alarm kept going off and then Sunday morning is when my brakes lights and gear would not shift out of park. SInce then I have relaized that my horn and brake lights are hooked to the same wire. Well I took out the 20 amp fuse and it was blown, and everytime I put a new 20 amp in, it would blow. Then I put a thirty amp in and now I can shift gears and my break lights work. Will this 30 amp fuse cause me a problem with the car in any way. I am sure that there is still some type of problem because I should not have had to use a 30 amp fuse. Let me know if anyone has any suggestions. Thanks!
Rochhie is offline
post #2 of 12 Old 12-13-2005, 10:35 AM
Blast from the past!
EXLNavi's Avatar
Send a message via MSN to EXLNavi
If the wire is designed to handle 20 amps, it will probably not be happy and get hot if more than 20 amps is passed through it.
Nothing probably will happen right now, but something definitely isn't right. The worst I can see happening is over the time the terminals will get hot and cooking the plastic they're attached to. Other than that, wire insulation can get hot and melt and probably start a fire.
'04 EX-L i4 5AT with Navi
If your mother still drives you to school,.... you ain't no gangster. PULL YOUR PANTS UP!
EXLNavi is offline
post #3 of 12 Old 12-13-2005, 11:05 AM
psyshack's Avatar
very bad. find the problem before smoke and fire show you where its at... not good to over fuse a blowing fuse.
09 HCHII,w/Navi,I4,CVT Crap,Atomic Blue/Beige,70k Miles (Dull/MPG/Quite Civic)
07 Mazda3 S Touring,I4,5MT,Purple/Charcoal,80k Miles (Civic What?)
00 Ranger Ext,XLT,I4,5MT,White/Gray,200k Miles (Thinks it's a F-150)
X, 05 Accord EX Sedan,I4,5AT,Red/Gray,89k Miles (My Fav. Accord Gen)
X, 06 Civic EX Sedan,w/Navi,I4,5MT,Silver/Gray,44k Miles (No Better Than GM Junk)
Can you save a gal. here and there then blow a half gallon playing with the tach? It can be done!
psyshack is offline
post #4 of 12 Old 12-13-2005, 12:17 PM
39.1 going on 40mpg!
SSMV6's Avatar
Sounds like there's a short somewhere (door switches, brakes light or ignition wires). Putting a 30A fuse in place of a 20A fuse is very bad! You're just gave your car an invitation to a firery death! If you can't find out what it is with the 20A fuse in place, take it in!
SSMV6 is offline
post #5 of 12 Old 12-13-2005, 03:38 PM
Very Bad Idea. Problems can arise as previously stated. Mainly, fires can start very easily when improper fuses are used. Secondly, if you do have a problem, forget your warranty. It's void if you use higher amp fuses (and they find out).
Did you have an aftermarket alarm? If you do and that's causing the problem, bring it back and have them rewire it correctly. The power wire for the alarm is usually taken off the ignition harness. You should never have to up the amperage of a fuse.
2004 Mercedes Benz- SL 500R- Silver (Wife's Toy)
2003 BMW M5 - Carbon Black (My Toy)
2005 Accord EX V-6 with Navi, Deep Green Pearl
2003 BMW 325i - Sapphire Black
1998 Accord EX V-6, Nighthawk Black Pearl
dragoncoach is offline
post #6 of 12 Old 12-13-2005, 05:54 PM
K20A3 > F22A1
magitekkn's Avatar
Even though lots of others have said this, allow me to join in and say:
Bad Idea
As one of my professors at Tech used to say: "Fuses are there to protect the wires, not you."
Replacing a 20A fuse with a 30A one will most likely result in a fire.
The Fleet:
07 Accord SE (Royal Blue Pearl) - 13 mi
04 RSX (Nighthawk Black Pearl) - 37,000 mi
Recent Departures:
93 Accord LX (Arcadia Green Pearl) - 224,000 mi
"Bye my little green car, I'll miss you!!!"
magitekkn is offline
post #7 of 12 Old 12-13-2005, 06:38 PM
It's a very good idea to keep with your original post.
2002 Accord EXVL Auto Sedan - Nighthawk Black Pearl / Quartz, fog lights, mud guards, wheel locks, trunk tray
1994 Pontiac Grand Am GT Auto Coupe
benjamming is offline
post #8 of 12 Old 12-15-2005, 05:18 AM Thread Starter
Cool 30 amp fuse
My alarm was going off Saturday night and SUnday morning my horn did not work anymore and my car was stuck in park. I now have the 20 amp fuse back in the car, but I had the person who installed the alarm disonnect it from my horn. NOw everytime I blow my horn, I blow the fuse.
Rochhie is offline
post #9 of 12 Old 12-15-2005, 05:52 AM Thread Starter
Took out 30 AMP fuse
Took out the 30 AMP fuse. Went to the shop where my alarm was installed. Had them disconnect the alarm from my horn, and now I can shift out of park without using key. But now even though my alarm is disconnected from my horn, everytime I blow my horn I short out my fuse. What could it be? Do you think I shorted out the horn and now I new a new horn? IN the meantime I do not have a horn to blow.
Rochhie is offline
post #10 of 12 Old 12-15-2005, 06:57 AM
Well,
It's guaranteed that you have a short, and it sounds like it's somewhere between your steering column, and your horns (obviously)...
How did they tie the alarm into your Horn system?? Did they go to a fuse block, or did they use the vampire style connectors to tap into the wire??
JT
GodAmLXi is offline
post #11 of 12 Old 12-15-2005, 08:44 AM
If the horn circuit was working fine when you took it in and not after the alarm install, bring it back to the shop and give them a chance to find the problem. Have the shop disconnect the control module itself, not just the horn. Very easy to unplug it. If you exhaust that avenue, tell them you will bring it to the dealer and have them fix it and give the bill to them to pay. If you think the horn itself is bad, unplug it and hit the horn button. If it still blows, there is a short in the wiring. If it doesn't, the problem is the horn itself.
post #12 of 12 Old 12-27-2005, 09:38 PM
Honda Nation
You need to have the people who installed your alarm trouble shoot this.... sounds like they messed something up. Tell them even if they have to remove the entire security system box, siren, any relays they installed, and put all your factory wiring back the way it was to troubleshoot and THEN reinstall everything, they need to do that, and you shouldn't have to pay them a dime.
May 2009 - Present: 2009 Accord V6 6 MT coupe w/o nav, Alabaster Silver
Dec. 1999 - May 2010: 2000 Prelude 5 MT, sold with 220,000 miles and still running great - gone, but not forgotten
fastball is offline
