03 Accord A/C fuse location - Drive Accord Honda Forums
post #1 of 6 Old 05-25-2006, 05:46 PM Thread Starter
Luisr's Avatar
Hi there! This is my first message here. I came to this board looking for a bit of help.
I have a 2003 Accord DX Sedan and today the A/C stopped working. No cooling at all. Blower and all indicator lights inside work but the compressor does not appear to be kicking in. I suspect this is an electrical problem such as a blown fuse. However I have not found any blown fuse but I don't know which is the A/C compressor fuse at all. I looked at the fuse box in the kick panel inside but I don't know if any of them belongs to the A/C. None of the labels tells me it is for the A/C.
I then looked at the fuse box in the engine compartment and found what appears to be a relay with a snow flake icon in the cover which I guess is for the A/C. Since I have no way of knowing if it is bad I just exchanged it with the two other relays of the same type found there and tried to see if the A/C started working again but it didn't.
I still think it is an electrical problem. Where is the fuse for the A/C compressor?
Thanks for any help.
Luisr is offline
post #2 of 6 Old 05-26-2006, 12:20 PM
Welcome. The A/C has a self diagnostic system if you have the testing equiptment. A dealer could likely tell you pretty quickly.
How to Retrieve a DTC
The audio-HVAC display panel has a self-diagnostic function for heating, ventilation, and air conditioning system. To run the self-diagnostic function, do the following:
Turn the ignition switch OFF.
Turn the fan switch OFF.
Set the temperature control dial on Max Cool, then push the mode control button to select Vent.
Turn the ignition switch ON (II).
Press and hold the recirculation control button.
While holding the button down, press the rear window defogger button five times within 10 seconds. The recirculation indicator blinks two times, then the self-diagnostic will begin.
If there is any problem in the system after self-diagnostic is finished, the recirculation indicator will blink Diagnostic Trouble Code (DTC) 1 through 6. If there are any problems in the evaporator temperature sensor circuit, the A/C indicator will blink DTC 7 or 8.
If no DTC's are found, the indicator will not blink.
The fuse is #30 under the hood.
Most likely cause is that your freon is too low.
post #3 of 6 Old 05-27-2006, 08:40 AM Thread Starter
Luisr's Avatar
Thanks for the information. I have already taken my car to the shop because with summer just starting the heat down here in the tropics is almost unbearable in the road.
Anyway the problem was not electric at all but just a little pebble that hit the condenser coil hard enough to cause damage and the refrigerant leaked. The guy at the shop found out when they performed a pressure test to the system.
Also found from them which fuse it is. It is labeled MG Clutch. Who knew!!
I will print your instructions about reading the diagnostic code just in case I need it in the future. I don't have diagnostic equipment. I am just a normal driver who happens to love his Accord. I was wondering the other day if there is such a way to read the diagnostic codes that cause the check engine light to come up without using any equipment. I used to have another car where you could ground some wire and by turning the ignition switch a couple of times to the ON position the check engine light would blink with a pattern indicating the diagnostic code.
This board is amazing. I will keep coming regularly.
Luisr is offline
post #4 of 6 Old 05-27-2006, 08:57 AM
BenjiBoy650's Avatar
Someone should try this on their 7th gen Accord and see if it works. I've done it on mine, works like a charm.
http://filtsai.com/accord/engine_codes/index.php
BenjiBoy650 is offline
post #5 of 6 Old 05-27-2006, 01:48 PM Thread Starter
Luisr's Avatar
I tried Princess' suggestion after I got back my car from the shop and it works. Only thing is that there is no "Vent" button in my car (DX). Looking through the manual, there is no Vent button in any of the different A/C systems that came with the 03 Accord. Anyhow, I just skipped that step and it worked. No code (as expected after service) was given but the recirculation control light did blink twice.
Haven't tried BenjiBoy's suggestion but did find the service plug under the dash.
Luisr is offline
post #6 of 6 Old 06-22-2016, 08:38 AM
Hobie's Avatar
Diagnostic Test Question
I ran the suggest test and the re circulation light did not blink, but it came on once and the A/C indicator did not come one.
I can't find the number 30 fuse, I only have numbers up to 23. Where is the fuse 30 for the AC compressor?
I think the problem may be the compressor as the AC went out fast, not a gradual loss of cooling. Also, when the car is idling I can not hear the compressor kicking in when I turn on the AC. I don't hear the engine change pitch, or any discernible noise.
Thanks, Jim
Hobie is offline
