Which Oil Is Best? - Page 3 - Drive Accord Honda Forums
post #31 of 62 Old 05-26-2009, 06:42 AM
I do my own oil changes for about $35 using M1 & M1 Filter. In my case synthetic oil increases my MPG about 1.5 mpg to 2 = 25 to 35 miles per tank of gas. The extra cost for synthetic pays for itself 2 times over in the end. I think more people should factor this in when calculating cost of synth vs conv. oil. Even if paying someone to do the oil change you come out ahead.
BigAnt1969 is offline
post #32 of 62 Old 05-26-2009, 08:07 AM
05Honda: I went back and re-read your initial post to be sure I'd focus on your priorities. If I understand you correctly, you've tried two synthetic oils, Pennzoil Platinium ("PP") and Mobil 1 ("M1"), and you've considered using Amsoil but decided again it because it's not particularly easy to find. You also were put off by the fact that M1 appeared (to you) to thicken over time. You liked PP, on the other hand, because it didn't discolor.
You didn't say whether you change your own oil, but I have the impression you don't. And I also have the impression you want to minimize the number of oil changes you have to pay for.
Based on your priorities, PP is best for you. But, as this thread should make clear, if you change one or more of your priorities, the "best oil" will also change. For example, Castrol's "Edge" is an excellent synthetic oil, but it's expensive and in the United States it's only available in two weights, 5w-30 and 10w-30. I wouldn't hesitate to use it because I know it will provide additional protection against premature camshaft wear, but you said you wanted a 5w-20. Similarly, M1's Extended Performance claims it will provide protection for 15,000 miles. It almost certainly would discolor over time, which concerns you, but its use would allow you to minimize your oil changes. However, any of these three (or Valvoline's synthetic, "Synpower" -- which will soon offer a 300k mile engine warranty) are outstanding products and each will meet all of Honda's maintenance requirements.
Mechanic is offline
post #33 of 62 Old 05-28-2009, 10:27 PM
Doing a used oil analysis (UOA) will help you get a fact-based understanding of what's happening with the engine. Terry Dyson (www.dysonanalysis.com) is excellent and very knowledgeable about Hondas. Fuel dilution is a common issue with Honda engines, something to be aware of.
STSinNYC is offline
post #34 of 62 Old 06-03-2009, 05:36 AM
NHBP AV6 6SPD coupe
sy272004's Avatar
Send a message via AIM to sy272004 Send a message via Yahoo to sy272004 Send a message via Skype™ to sy272004
Originally Posted by Fredsvt View Post
What does the owner's manual say as far as viscosity goes, is it 0w20 or 5w20?
Stick with an oil that is approved by either Honda or Ford if it's 5w20, the ones that are approved are tested at a double time temperature test.
dont get me wrong i love honda, but, saying use whever they recomend sometimes cant be taken seriously, only reason honda or others use 5W-20 is to elevate their fuel economy raitings to government. its "thinner" then 5W-30 therefore engine doesn waste just a little effort to work in that oil therefore little better fuel economy, in long run 5W20 is not as good for engine as 5W-30
i use amsoil and their filter and change every 5k
Mobil is like microsoft, they are huge company and do whatever they want
2004 NHBP Honda Accord V6 6SPD 2dr
sy272004 is offline
post #35 of 62 Old 06-03-2009, 06:15 AM
sjlee's Avatar
There's no proof that using 5W-20 oil will shorten the life of your engine compared to using 5W-30. In fact, most 5W-30 oils will shear down to 5W-20, while 5W-20 oils keep their viscosity.
Many people have done used oil analysis on 5W-20 (including myself) and found that the wear isn't any different than using 5W-30.
2007 Honda Accord EX-L V6 AT 4DR (Alabaster Silver Metallic) - splash guards, wheel locks, OEM foglights, GROM adapter
2005 Honda Pilot EX-L (Desert Rock Metallic) - splash guards, wheel locks, crossbars, side steps, towing package
1995 Yamaha FZR600 - sold
2001 Chevrolet Cavalier LS sedan (silver) - sold
1996 Acura Integra GS-R sedan (Black Currant Pearl) - sold
1995 Suzuki Katana 600 (teal) - totalled; sold
1984 Chevrolet Celebrity (brown) - first car; sold
sjlee is offline
post #36 of 62 Old 06-03-2009, 06:42 AM
lebomb's Avatar
I asked this question to my mechanic.................certified by Honda. He has done hundreds of oil changes...........in his opinion, just follow the manufacturers guidelines when it comes to the oil and change intervals. He said OEM 5w-20 changed every 3K-5K miles if fine. He services an Acura NSX that a doctor owns...............the Dr. keeps up with all his maintenance and changes his oil with OEM every 3k-5k miles..........this NSX has almost 250K miles on it without a single engine problem. I think Im going with what my mechanic recommends.
2014 Accord Sport CVT
Champagne Frost Pearl
Kicker 300watt Amp
Kicker CompR 12/ Ported Box
SON OF THUNDER
lebomb is offline
post #37 of 62 Old 06-03-2009, 09:29 AM
You are correct, sir, there is no "proof" that 5W-20 oil will "shorten engine life," but there is a growing body of evidence on various websites -- (see, e.g., honda-tech.com; ephatch.com; search "camshaft galling") -- which would cause a reasonable person to question whether 5W-20 conventional oil provides adequate protection against shear and camshaft pitting/galling in high-mileage k20 engines.
On the other hand, we know that Honda still recommends the use of 5W-30 weight oil in all its higher performance engines (and 10W-30 in the case of the S2000) and, further, that Honda recommends 5W-30 weight synthetic oil (Mobil 1) in its turbocharged engines. Consequently, it's reasonable to conclude that 5W-30 weight oil provides more protection against extremes of heat and shear than 5W-20 weight oil in a k20 engine.
Mechanic is offline
post #38 of 62 Old 06-03-2009, 12:10 PM
sjlee's Avatar
Have you seen anything on these websites that show a similar result with the J30 engine?
sjlee is offline
post #39 of 62 Old 06-03-2009, 01:41 PM
tebow's Avatar
my mechanic said that 5w-30 is better for the engine than 5w-20, so thats why I use 5w-30. but i dont think it makes a big difference.
tebow is offline
post #40 of 62 Old 06-03-2009, 02:32 PM
Originally Posted by psyshack View Post
Fred hit the nail on the head. The Motorcraft oil is fantastic and cheap! I run it in my Ranger. One year or 10k miles. And seeing that I don't drive the MZ3 as much as I use to. I will be switching it to the MC 5w-20 oil. The HCHII will spend its life on M1 0w-20 at 10k mile oci. The Accord spent its life on M1 0w/5w-20 depending on the season. I should have just ran the MC in it and saved a few bucks.
My own belief is run a good air filter and a good oil filter and the oil will take care of it's self over all. Even the cheapest of oils seem to be better than the best oils of 20 years ago. Syn excluded of course.
MC is great in Hondas and its not some fad that oh Honda guys like putting oil with a Ford label in their cars for some odd reason, MC really runs great in Hondas. In my V6, it was night and day how the car ran with MC and any other oil. However recently, Valvoline Max life came into the picture(my local market) and I tried it and am smitten. I get the same great mileage but I like to think I get better protection since this oil is purported to have GRP IV oil in it!(10-20%) Anywho, I would not be averse to trying M1 0w-20 either as it has also been purported to contain GRP IV due to better ingredients. Better ingredients, Better Oil 5w/0w 20!
J30A5Refined is offline
post #41 of 62 Old 06-03-2009, 02:50 PM
DeeAgeaux's Avatar
Because a company is huge does not mean they are evil or "do whatever they want."
Does GM "want" to go into bankruptcy and have shareholder value wiped out? It was the largest corporation in the world for many years.
Becuase Amsoil is small does not make them a Saint or Luke Skywalker fighting the Evil Empire.
Buying products from a multi-level markerter is annoying though.
Why can't I just walk into an auto parts store or racing shop and buy Amsoil?
Amway Herbal Life Amsoil good grief it is annnoying.
03 Sedan I-4 LX 5AT 110k Miles
Enkei RP03 SBC 17X8 48MM offset
General Exclaim 225/50 R 17
Neuspeed Upper Strut Tie-Bar
TL Rear Sway Bar
Suntek Tint 20% F 5% Rear
Magnefine ATF
Pennzoil Platinum 5w-20 10k OCI
Motul 5.1
DeeAgeaux is offline
post #42 of 62 Old 06-03-2009, 06:28 PM
reframmellator's Avatar
5 Qts Advanced Fuel Economy Mobil 1 + Mobil 1 Filter $19.99 at Advance after $10 MIR
The Advance Auto Parts Stores here are running a special - 5 qts Mobil 1 plus a Mobil 1 filter for $29.99 - about $18 off list.
Be sure to buy the Advanced Fuel Economy version (fluorescent green cap, 0W-XX weights) and get the $10 MIR rebate form here
http://www.mobiloil.com/USA-English/...romotions.aspx
after taking a lame-o fuel economy challenge (save up to $231 in fuel costs annually by DRIVING LESS).
"Communication isn't what you say. It's what they hear." - Red Auerbach
2015 EX-L V6, Modern Steel/Black
2007 SE I4 5AT, Cool Blue, 77k
Also in the family:
2009 TSX, navy, auto
2015 Hyundai Santa Fe Ltd
2015 Crosstour V6, black
2013 Civic EX, gray
2014 Honda HRX217 (2)
Departed:
2004 EX I4 5MT, Desert Mist, 175,552
2001 Accord EX I4 5MT, Satin Silver, oil slick at 86K
1999 EX-LV, Heather Mist, 146,567
1994 Accord LX I4 5 MT ABS, Malachite Green, 285k
reframmellator is offline
post #43 of 62 Old 06-04-2009, 05:34 AM
cajun's Avatar
How exactly was it night and day? I switched to MC a few oil changes ago, but other than possibly a slight improvement in mpg's I see no diff at all from when I was using Castrol dino.
2010 PMM Accord LX-P, TSX rear sway, GG lower grille, 35% tint, 50K+
2006 Toyo Sienna LE, 100K+
2002 Accord SE (sold), TL rear sway and upper strut bars
cajun is offline
post #44 of 62 Old 06-04-2009, 06:16 AM
I didn't notice any difference either after I switched to MC 5w20 from the dealer's dino. I did get a uoa done after 4800 miles with excellent results. The iron reading was a 3 while the univ. avg is a 7.
Like you said there was a slight improvement in mpg. The only other thing I noticed is when checking the oil level with the MC the residual oil on the paper towel seemed to soak in and spread thru a small area of the paper towel at a much faster rate than the dealer dino. The dino oil just seemed to sit on the paper towel versus the MC. Just thought that was kind of interesting.
post #45 of 62 Old 07-14-2009, 11:49 PM
AC6DN
Bruce Hawkins's Avatar
Originally Posted by RTexasF View Post
The oil that's best is the one that's changed on a timely basis. There is no answer to your question. Which car is best, which ice cream is best, which state is best, which planet is best? The list can go on ad nauseum. Go to bobistheoilguy and read to learn. By the way.........which senior diapers are best? Read and learn then make your own decision.
California, not Texas, hahahaha...
Currently, I'm going out to 7500-8000 on Valvoline or Castrol synthetic oil (5W-20), and an AmsOil 25K filter (I go to, 3 x 8K = 24K miles). I have purchased an oil analysis kit, to test my oil. Well see what it shows (I'll post the results hear). On my Honda (2001) the recommendation is out to 7500 miles, and a new filter every other time. My WAG is I'm OK...
Bruce - AC6DN:
Honda Accord, 2001, 2.3L (L4), F23A4, 4D EX - My main car…
Ford Taurus, 1992, 3.8L V6, - Trany prob's
Toyota 4x4 Extra Cab Truck, 2.4L SR5, 22RTE (Turbo) 1987, I still have.
Honda Accord, 1984, 1800cc? L4,
Plymouth Arrow, 1978?, 1800cc?, L4 (POS)
Chevy, Monza, 1976, 350cu, V8, My funnest car, think muscle car, poorly made...
Olds Starfire? 1975, 231cu odd fire, V6,
My first car, 1965 Chevy Impala 283cu V8, (I got during the mid 1980)
Bruce Hawkins is offline
