2008 Headlights Flickering (I4 Models Only) - Page 3 - Drive Accord Honda Forums
post #31 of 48 Old 05-07-2008, 05:44 AM
Cell Phone Doc
turbodave's Avatar
Originally Posted by jang859 View Post
here's the crazy thing i noticed about auto mode, it automatically keeps on cabin recyled air.
why does it do that, what benefit is this? i'm afraid to use it now, i thought cabin recycled is not as fresh so not as healthy, and should only be used if you are driving through some dusty/smoggy area or something?
am I wrong? on the flipside is cabin recycled better to use when using AC?
It uses that cabin recirc. mode when it has to get a hot interior cooled down the quickest. LIke mine, when the car's been sitting out in the sun at work all day. When I first fire it up and head for home it's on cabin recirc. but as the cabin temp gets closer to the desired set temp it automatically turns cabin recirc. off and goes to normal.
TurboDave
EWCS(SW) USN (ret.) (1965-1988)
Sevierville, TN
Email Us---My Photo Gallery
12 Lincoln MKT, EcoBoost twin turbo 3.5V6, Crystal Champagne Metallic
86 Buick Grand National (for go)
87 Buick Grand National (for show)
01 Ford Excursion 7.3PSD (for tow)
turbodave is offline
post #32 of 48 Old 05-07-2008, 03:43 PM
Originally Posted by BrockPSU View Post
Mike - Try this out tonight when it gets dark. Turn your vehicle on and have the headlights on. Put your climate control on AUTO. Turn on one of the map lights above the rearview mirror. Every 17 seconds you will hear the compressor ctycling and you should notice the interior light and the headlights dimming.
Okay - I put on the dome lights while operating the climate control and, yes, I did notice that the interior light did slighly dim when the compressor cycling started. Wonder why it it affects the dome lights, headlights, but not the instrument lighting?
mike.
Wife: 2008 Honda Accord/EX-L/Basque Red Pearl - I4
Mine: 2011 Mercedes Benz/C-Class - Sport/Steel Grey
native.texan is offline
post #33 of 48 Old 05-08-2008, 08:18 AM Thread Starter
mike.
Don't know Mike, but I'm really glad the instrument lights don't dim, that could be real bad! I think of the dimming as a "wink"
BrockPSU is offline
post #34 of 48 Old 05-08-2008, 08:36 AM
Accordriver's Avatar
mike.
The reason the lights dim is because the compressor puts resistance on the motor, and in turn slows down the alternator. The ECM should bump up the rpm to compensate, but starting the compressor will almost always cause the lights to dim. The reason your gauges don't dim is because they have circuitry to keep constant current flowing, that way the "motors" driving the needles are not affected.
-03 Honda Accord EX V6
-Debadged-17mm sway bar-UR crank pulley-AEM CAI
Accordriver is offline
post #35 of 48 Old 05-08-2008, 09:24 AM
Send a message via AIM to bruceleroy
i havent even noticed this on the car yet. Ill check it out again later today
Do you guys know if this still happens if you have HIDs installed and LED lights installed for the interiors?
bruceleroy is offline
post #36 of 48 Old 05-08-2008, 09:31 AM
This happens on my EX 4cyl model randomly
I can be driving on the freeway and it randomly occurs, i notified my honda dealer and he didn't know anything about it.
I can have all my settings normal and all sudden flicker.
hatsumomo is offline
post #37 of 48 Old 05-08-2008, 09:57 AM
Folks this flickering of the headlights has been going on since the 7th gens came out in 2003 that I'm aware of. Now the dome light flicker I haven't heard of before but the rest is old news. Don't worry yourself silly over nothing. Yes, mine does it too and I don't like it but that's just the way it is. I hope someone figures out a workaround but so far it's just considered the nature of the beast and continues in the 8th gen.
post #38 of 48 Old 05-08-2008, 01:45 PM Thread Starter
You would think that if people have been complaining about this since 2003 they would have fixed it 4 years ago, but it is stil a problem in a brand new car. It's kind of dissapointing, but other than this, I am extremely happy about my car!
BrockPSU is offline
post #39 of 48 Old 05-08-2008, 02:24 PM
Demonik's Avatar
Send a message via AIM to Demonik
the only fix is to rig up a relay harness for your headlights...thats the major thing everyone hates....so if you make your headlights draw power straight from the battery...it will be fine
Code:
'08 Honda Accord LX-S // Nighthawk Black Pearl // Black Interior
CURRENT MODS
     6000k 55 watt HID kit // Interior and Exterior LED conversion
     25/15/15 tint // Autozone grille mod
Demonik is offline
post #40 of 48 Old 05-09-2008, 04:23 AM Thread Starter
How would you suggest doing that, and would it fix the interior light issue also?
BrockPSU is offline
post #41 of 48 Old 05-09-2008, 04:35 AM
Don't be so sure about that unless you tested and the light voltage was below battery 12.7v. The "running" voltage is like 14.5-15v all regulated electronically by charging system.
I bet what happens if you ran some tests the voltage does like 14.5>13.x and you see the flicker until alternator regulator kicks in to readjust it (stabilize it)
I haven't check honda's but most cars draw power right from a main distribution power block/fuse that comes right off the positive of battery.
I personally am not bothered by the split second drop, I never notice it much while driving .
Ed
2008 Accord LX, Alabaster Silver Metallic
gone 1985 XR4Ti
gone 1974 Opel Manta rally
Edaccord08 is offline
post #42 of 48 Old 05-09-2008, 04:58 AM
Me too. No big deal. In fact, had others not raised the issue, I may have never noticed it.
mike.
post #43 of 48 Old 05-09-2008, 12:48 PM Thread Starter
So any idea on wiring the relay?
BrockPSU is offline
post #44 of 48 Old 05-09-2008, 01:38 PM
Demonik's Avatar
get a weather proof (weather resistant) relay and good wire and go at it....thats about all i can say, its not a hard thing, just make sure not to cross polarities
Code:
CURRENT MODS
Demonik is offline
post #45 of 48 Old 05-10-2008, 07:35 PM
Lurker
Same problem here but i`m not concerned about it, yet..
Insane08 is offline
