Passenger Window motor not going up but goes down - Drive Accord Honda Forums
post #1 of 11 Old 01-05-2010, 12:08 PM Thread Starter
Stong07's Avatar
I have a 2008 honda accord coupe 4 cyl.
I Recently had my car broken into and my stuff stolen... They shattered my passenger window and left a nice scratch under the window. I got a new glass from a small glass shop nearby. installed the glass to find out the window will only go DOWN but not UP. i tried taking the ground off the car battery and reconnecting it. in addition, the driver side master switch for the passenger window does not work. To see if it was the motor, i took two wires and jumped the motor with a 12volt drill battery. Well its not the motor. The motor goes up and down when i jump it with the battery. When i plug the normal wires back into the motor and try it again still doesnt go up. I heard someone say that the new cars have chips for almost everything in a car and that i might need to reset my window chip. I took it to a small body shop to see if they could figure it out. They said it was the switch that was the problem. but if it was the switch wouldnt the driver side passenger window switch be fine ? and plus the switch is operational when pulling the window down , its just the getting up is the problem. 2 hours of tinkering and they said it was the switch. Whats your guys opinion and does anyone have SOLUTIONS??? very much appreciated
Stong07 is offline
post #2 of 11 Old 01-05-2010, 12:58 PM
I really have no added info but if window goes down, most of the time the motor is good and the switch is bad .
Reason for this is in most cars the motor is 2 wire, what makes it go up or down is simply reversal of polarity of both wires .
If car came to me in the shop first I would check is voltages from switch to motor in both up an down positions.
Ed
2008 Accord LX, Alabaster Silver Metallic
gone 1985 XR4Ti
gone 1974 Opel Manta rally
Edaccord08 is offline
post #3 of 11 Old 01-05-2010, 02:04 PM
I would check the programming then check the relay. Both switch's run through that the control unit and relay. I would expect the programing to be messed up after the window was replaced.
I found this thread with reset information and would try this first.
I also have read some information about windows not going all the way up or all the way down. I think it was in the Honda tech news and the fix was the same to the following information.
power window control unit reset
Originally Posted by TonyWare View Post
Hope this helps (copied from the 08 manual, but still I think the same mechanism) :
Do each bullet in step 4 within 5 seconds of each other. The front passenger's power window must be reset from the front passenger's power window switch.
1. Turn the ignition switch to ON (II).
2. Move the power window all the way down by using the power window DOWN switch.
3. Open the driver's door.
4. Do the following three times before going to step 5:
 * Turn the ignition switch to LOCK (0).
 * Push and hold the power window DOWN switch.
 * Turn the ignition switch ON (II).
 * Release the power window DOWN switch.
5. Confirm that AUTO UP no longer works. If AUTO UP still works, go back to step 1.
6. Move the power window all the way down using the power window DOWN switch.
7. Pull up and hold the power window UP switch until the power window is all the way up, then continue to hold the switch for 1 second.
8. Confirm that the power window control unit is reset by using the power window AUTO UP and AUTO DOWN function.
If the power window still does not work in AUTO, repeat the procedure several times, paying close attention to the 5 second time limit between steps.
msurerus is offline
post #4 of 11 Old 01-05-2010, 08:35 PM
I'd be willing to bet it has something to do w/ the anti-pinch safety feature that keeps the windows from squashing anything in the way when they close. If there is too much resistance (physical, not electrical) when the window is closing, this feature reverses the motor and rolls the window down. All it would take is for the new glass to be slightly out of its proper path, and rubbing too hard on the felts, track etc. to provide the added resistance to make this kick in. You may need to take your car in to a dealer and have them adjust the new glass. Hope this helps.
mi08coupe is offline
post #5 of 11 Old 01-09-2010, 09:41 PM Thread Starter
Stong07's Avatar
thanks for the advise guys. ive tried the mannual programming . i found that same step by step solution on google. but it didnt work for me . i guess it is the switch
Stong07 is offline
post #6 of 11 Old 01-10-2010, 06:18 AM
meallen125's Avatar
mines is doing the same thing...but its the driver side window
--2013 Accord Touring Modern Steel
Mods:
20% tints all around
--2008 Accord i4 NHB Coupe EX-L w/ Navi (TOTALED JUNE 27TH, 2013)
Mods:
19x8.5 5Zigen Gravis I Wheels
20% tints sides and rear
Deck Lid spoiler
3M Roof Spoiler
Takeda Short Ram Intake
Chrome Door Handles
6000K 35w HIDs in lows
3000k 35w HIDs in fogs
Debadged
Future Mods:
Coilovers/Springs
Dual Magnaflow Mufflers
HFP Kit
meallen125 is offline
post #7 of 11 Old 01-10-2010, 06:54 AM
searich07's Avatar
Maybe take to dealer for service, Regards
Richard
'09 Accord Coupe Ex L-Nav (190hp) I4
- Alabaster Silver Metallic/ Zaino finish / Black Leather Interior
-Weathertech trunk, front
-3M clear bra, pillars, roof, rear deck
OEM:
- side molding
- fog lamps
- Auto dim mirror
HONDA Accords:
'99 Sedan EXL V6
76 K miles - 6th Gen (97-02) 3.0L V6 SOHC VTEC (200 hp)
'92 Coupe I4
127 K miles – 4th Gen (90-93) 1992 facelift I4 2.2L (125 hp)
'85 Sedan LX 4dr I4
98 K miles – 2nd Gen (82-85) 1985 refresh i4 1.8L (86 hp)
searich07 is offline
post #8 of 11 Old 01-10-2010, 09:40 PM
Honda Guido 0809
HondaGuido08c's Avatar
Send a message via AIM to HondaGuido08c
Damn and i had my car smashed into on the passenger side too..but they didnt take anything. cuz i clean out my car every day o.O
- HondaGuido08c -
* 20% Tints All Around
* 35% Tinted Taillights
* 8K HID Kit
* JDM Stage 2 Yellow Fogs
* JDM Stage 2 High Beams
* Customized Red Calipers
* K&N Typhoon 69 Series SRI (Intake)
* Upgraded Trunk & License Plate Lights
* Interior Blue Lighting + Underlighting
Future Mods:
19" or 20" Black Rims
Falken Tires
Future Car in Progress:
Nothing Catching My Eye
Member of NYC ALIVE
HondaGuido08c is offline
post #9 of 11 Old 01-10-2010, 09:49 PM Thread Starter
Stong07's Avatar
Richard
i got a few things i dont want honda seein in my car lol..
Stong07 is offline
post #10 of 11 Old 01-10-2010, 09:50 PM Thread Starter
Stong07's Avatar
def let me know how your situation goes..
Stong07 is offline
post #11 of 11 Old 01-10-2010, 09:51 PM Thread Starter
Stong07's Avatar
sucks man. i feel your pain. they took my gps and ipod. left my $300 radar tho. you know they weren't too smart. But did your window give you any problems after ?
Stong07 is offline
wndow switch chip motor
