To me it was as unHonda like as can be. at 78000 miles my Accord started using a quart every 1000 miles.
I thought it has to be a plugged egr - pvc - emission tube - torn vacuum line.
Then I read about all these other poor slobs getting their 2.4 Accord motors getting rebuild by Honda that used
a quart every 600 miles. I spoke to the Honda Dealer, a quart every 1000 is not covered by extended warrenty..Plus. They would need the car 3 days to test etc etc.
I am not a quitter. I came to the conclusion after hours online, that the piston rings get cruded up and stop spinning.
since I would use a quart 1000-1200 miles , i figured i have one stuck oil ring. Not to be confused with the compression rings. The bigger oil burners have 2 pistons with stuck oil rings.
How to cure ?
Pathetically Simple and cheap.
I pulled the plugs, put a shot glass of marvel Mystery Oil in each Cly. let sit for 18 hours ( most guys on the web suggest 2-3 days). Then I watched it. the oil didnt seem to move on the stick for 600 miles. I changed the oil, this time
leaving out a pint of oil and putting Marvel in with the Valvoline 100% Synthetic ( always used Mobil One until now ).
I am thrilled to report after 700 miles , the oil is top of the full mark. I keep thinking all these engine rebuilds were needlessly done wihen
it is just a stuck ring or two.
How to cure ?
