Front VTEC Assembly Replacement? - Drive Accord Honda Forums
post #1 of 9 Old 03-20-2017, 08:27 AM Thread Starter
Mechanical Stig
Hey guys,
I don't know if I should post this in the 8th gen section or the off topic section but I have a 2010 Honda odyssey (before you smash your keyboard, the odyssey has almost the same V6 as the accord) and the front VTEC assembly is leaking like MAD. My alternator is covered with oil and my lower splash shield is drenched with oil. I don't see any gaskets on the estore and it looks like I have to buy the whole VTEC assembly to fix the leak. #10 in this diagram: Honda online store : 2010 odyssey front cylinder head (3) parts
1) Do I have to take off the front valve cover to replace the VTEC assembly?
2) It looks like the VTEC assembly is installed with hondabond from factory, is there a gasket after all or do you just put it on with hondabond?
3) Can someone find the shop manual instructions for the front VTEC assembly?
Thanks
2017 Honda Odyssey TE - VCMuzzler - OEM Footwell LED Mod - Rear LED Reflectors -
2017 Honda Accord EX-L
2014 Honda Civic EX-L
2010 Honda Odyssey EX-L (USDM AF!) VCMuzzler - Catless Downpipe/Pre Cat Deletes - Third Cat Delete - Custom K&N SRI With Cold Air Scoop - TB Coolant Bypass - Thermal Gaskets - BC Coilovers - Dyno Tuned
MrRangerZr1 is offline
post #2 of 9 Old 03-20-2017, 12:08 PM
Metal Metalic's Avatar
Are you talking about the activation solinoid that controls oil to activate the pins for VCM function. That can leak as it delivers oil to the shafts.
Metal Metalic is offline
post #3 of 9 Old 03-20-2017, 12:53 PM
VTEC just kicked in.
Maybe this video can help. It's for the I4, though.
'08 EX-L V6 Sedan
  • P2R Intake Manifold Spacer
  • Intake Resonator Delete
  • VCMTuner
  • JL 8W1 <=> Kicker CX300.1
  • Alpine KTP-445U
WILLYumD is offline
post #4 of 9 Old 03-20-2017, 02:06 PM Thread Starter
Mechanical Stig
The oil pressure switch? No not that.
post #5 of 9 Old 03-20-2017, 02:20 PM Thread Starter
Mechanical Stig
Here is the VTEC assembly. The leak is right below the dipstick, there is not oil in the picture because I just cleaned it. It looks like the dipstick is leaking but its not.
Mods can you please merge this picture in my first post.
post #6 of 9 Old 03-20-2017, 05:47 PM Thread Starter
Mechanical Stig
Originally Posted by bgw70 View Post
The link did not work...please check it.
Works now but that seems to be a different part, not related to mine.
post #7 of 9 Old 03-20-2017, 10:24 PM
Sorry about that video! Here's what I found from a cursory search through the 08-09 V6 Supplementary Service Manual.
'08 EX-L V6 Sedan
  • VCMTuner
  • Alpine KTP-445U
WILLYumD is offline
post #8 of 9 Old 03-21-2017, 03:21 AM Thread Starter
Mechanical Stig
I found out that its called the front rocker arm oil control valve but I just need to find out how to replace it. If it requires me to remove the rocker arms or some other internal things then I'll have to let someone else do it...
Not a problem! You didn't find anything else?
Anyone with any advice? Kind of stuck over here, no one seemed to replaced this assembly and can't tell exactly what to do.
post #9 of 9 Old 04-02-2017, 04:29 PM Thread Starter
Mechanical Stig
FIX:
Front VTEC Assembly Oil Leak Fix DIY
