Accord 3.5 v6 8th oil pan cracked - Drive Accord Honda Forums
 6Likes
post #1 of 18 Old 03-20-2017, 11:10 AM Thread Starter
Ricardo Mendes's Avatar
Looks like it is leaking oil from a very small crack on my oil pan... I believe it is just a matter of taking it out and welding it. I would like to know if it is simple to remove it...by the way, I can store the old oil, right?
Thanks
Accord 2008 3.5 V6 aut leather sunroof 278 hp, 55000 miles
Ricardo Mendes is offline
post #2 of 18 Old 03-20-2017, 11:54 AM
pessimistic optimist
Very simple. First, remove engine from car. Second, remove oil pan from engine. I would do everything in my power to ensure that the pan was in fact cracked before going to all that trouble. Also, I believe that the oil pan is aluminum, which is going to make welding it more difficult, I would replace with new rather than risk having to replace it twice.
Ignore the entire first sentence I typed. I would still go to great lengths to ensure that there was an actual crack before diving into removing the pan. I too have used JB Weld with good results. I fixed a leaking gas tank on my 1940 Cadillac with the stuff, it held up great for several years.
2008 EX sedan 2.4l, 3 pedals
Mods: Weapon R I Throttle, OE style lip spoiler, painted calipers, K&N drop in w/ resonator delete, Redline shift boot & armrest cover, Crosstour cluster, JDM style visors, retrofit headlights (morimoto h1 7.0)
J2 CBE, DIY 9th gen short shifter
Future: springs/struts, TL RSB (in my grubby little hands waiting for mother nature to cooperate)
boring 08 EX is offline
post #3 of 18 Old 03-20-2017, 12:07 PM
You don't need t remove the engine to remove the oil pan on a J series engine. Where did you get that idea?
Ricardo Mendes likes this.
07 V6 AUTO Sedan
t-rd is offline
The Following User Says Thank You to t-rd For This Useful Post:
Ricardo Mendes (03-20-2017)
post #4 of 18 Old 03-20-2017, 12:34 PM
Yea I modded my car again
08 v6/6's Avatar
you should look up JB weld.
I have read some pretty amazing stories of people using it on all sorts of things. Including a cracked engine block leaking coolant.
I would drain the oil out of the car and wait an hour so there is nothing in there. Then sand the crack so its fresh metal and use that JB weld.
For 10$ its worth a shot. Read up on it. I use it all the time on all sort of stuff
97trophy and Ricardo Mendes like this.
08 EX-L V6/6
Performance : Ktuner, Fastline ss clutch line, Fastline powerlinks, P2R thermal gaskets, EBC green stuff, XLR8 ss brake lines, Progress 22mm rsb, HSD coilovers, Blox 15mm rear spacers,
Power : RV6 hfpc, XLR8 V2 j-pipe, Injen cai, Unorthodox stock sized pulley, Magnaflow cbe, tl sh awd tb, j37 manifold
08 v6/6 is offline
The Following User Says Thank You to 08 v6/6 For This Useful Post:
post #5 of 18 Old 03-20-2017, 12:34 PM Thread Starter
OMG... it is not simple to remove the engine... come on ... there should be a easier way...
is it this one?
Jbwr 8265 - Solda Fria J-b Weld Super Cola Epoxi! - R$ 64,99 em Mercado Livre
thanks...
I want to know if it is necessary to remove the front cross member...
Last edited by namegoeshere; 03-20-2017 at 02:45 PM. Reason: merge because we're not SMSing
post #6 of 18 Old 03-20-2017, 01:25 PM
Read this thread: Replacing Oil Pan - AcuraZine - Acura Enthusiast Community
You need to remove the exhaust J-pipe for the pan to drop out. You DO NOT need to remove the engine.
07 V6 AUTO Sedan
t-rd is offline
post #7 of 18 Old 03-20-2017, 01:50 PM Thread Starter
is it really the same procedure for the accord? so... nothing to do with cross member chassi right?
post #8 of 18 Old 03-20-2017, 02:24 PM
Mechanical Stig
WHOA typo?!
2017 Honda Odyssey TE
2017 Honda Accord EX-L
2014 Honda Civic EX-L
2010 Honda Odyssey EX-L (USDM AF!) VCMuzzler - Catless Downpipe/Pre Cat Deletes - Third Cat Delete - Custom K&N SRI With Cold Air Scoop - TB Coolant Bypass - Thermal Gaskets - BC Coilovers
MrRangerZr1 is offline
post #9 of 18 Old 03-20-2017, 06:50 PM
Exact same procedure for the Accord. The entire J series Hondas have about the same procedure.
07 V6 AUTO Sedan
t-rd is offline
Ricardo Mendes (03-21-2017)
post #10 of 18 Old 03-20-2017, 06:55 PM
DIY Kid/Hypermiler
Das Chicken's Avatar
I have used JB weld to patch a crack in the combustion chamber of a small two stroke engine, and it worked! For about 15 minutes.. I also used JB weld to patch a hole in the side of a small four stroke engine, which seems to be holding up so far.
Originally Posted by qman View Post
Ah so you do have a drinking problem. You do not drink enough.
Originally Posted by RickBlaine View Post
The 9th Gen V6 Accord is the "mullet haircut" of the car industry. Bidness in the front, but party in the back when it's "GO TIME".
From a Mercedes-Benz forum: "Drive it like You have to fix it"
2006 Honda Accord EX 6-6 Sedan Tafetta White 146K miles. DIY coroplast undertray, hybrid rear diffuser, Odyssey intake spacer milled down to 1.3".
Das Chicken is offline
post #11 of 18 Old 03-20-2017, 07:00 PM
Try the patch first. If that does not work then replace the pan.
2004 4cyl. EX Sedan automatic 480K
KW2004Accord is offline
The Following User Says Thank You to KW2004Accord For This Useful Post:
post #12 of 18 Old 03-21-2017, 05:56 AM Thread Starter
here it is very expensive the new or a used oil pan... I believe it is about 300 dollars... the best would be to weld the aluminium...i believe they would have to use TIG... anyway i think i will try with that jb weld and then try to really weld the apparatus ...
Thank you all
Strange... is everything the same in on those engines?.... for example once i changed the steering rack in my 2008 accord and i had to remove the cross member chassis. In the other hand in the 2007 accord we don t need to do that...
post #13 of 18 Old 03-21-2017, 06:17 AM
bgw70's Avatar
Thank you all
How did you damage the oil pan?
Did you hit something?
The 2007 Accord is a different model verses the 2008 Accord.
2008 Honda Accord EX-L V6 Navi
2007 Honda Civic Hybrid Navi
2002 Lexus SC430 V8 Hardtop Convertible
2000 Pontiac Firebird Trans Am 5.7L LS1 V8 Convertible
bgw70 is offline
post #14 of 18 Old 03-21-2017, 07:26 AM Thread Starter
that is what i am saying...
well i dont know what happened... it got cracked.. probably i must have hit something...
post #15 of 18 Old 03-22-2017, 05:55 PM
If it is for sure cracked then remove it and bring it to a welder that knows how to weld aluminum. Look up rim repair guys, welding aluminum is easy for someone that welds aluminum. Simple and a forever fix, unless you hit something else lol
TopSniper69 is offline
The Following User Says Thank You to TopSniper69 For This Useful Post:
Ricardo Mendes (Yesterday)
how to., oil pan, removal
