08 headlight adjustment - Page 2 - Drive Accord Honda Forums
post #16 of 22 Old 01-31-2012, 06:51 AM
do these instructions also apply to the 2009 Accord?
BSeery is offline
post #17 of 22 Old 01-31-2012, 07:48 AM
Andylam122's Avatar
same generation. 08-10
2010 EX-L V6 White Diamond Pearl Sedan
LLumar Tints: Front/Back/Rear 35/35/15 | Weathertech Floor Liner Mats Front/Back Row| LED Hyper White Interior & Exterior | Nokya HyperYellow HighBeam/DRLs | 8000k HID Low Beam | 6000k HID Fog Lights | M3 Roof Spoiler | Switchblade Key | Takeda SRI | Invisicord Hardwire Rx65 Blue | PlastiDip Black Front Grille/Window Trim/ Rear Emblem | T20 Hyperflux 18SMD White Reverse/ Turn Signal | UR- Front Upper Strut Tower Bar
Andylam122 is offline
post #18 of 22 Old 01-31-2012, 07:51 AM
Andylam122's Avatar
Originally Posted by woody4364 View Post
Here's a pic of what you should be looking for.
what tools do you need to adjust it? a flat head screw driver or one of those nuts you turn? i can't tell from that picture.
post #19 of 22 Old 01-31-2012, 08:12 AM
You can use either one.
Originally Posted by mikeyd914 View Post
I still cant figure out how to adjust my headlight.
Turn the screw one way to lower the light pattern, and the other way to raise the light pattern.
I dont know where the screw is for the driver side headlight.
Do you know where it is on the passenger side? If you do, it's in the same spot on the drivers side. There may be "cover" of some sort over it on the drivers side though. This thread may help.
http://www.hondaclub.com/forum/accor...djustment.html
And this one.
Headlight Adjustment
sodaks2k is offline
post #20 of 22 Old 01-31-2012, 09:23 PM
Andylam122's Avatar
i still cant figure out how to adjust my headlight. i dont know where the screw is for the driver side headlight. idk why my driver side is higher than my passanger side
I thought only I had that problem haha.
post #21 of 22 Old 11-04-2012, 12:21 PM
Use a screwdriver, not a wrench, and don't remove air filter box
Once I removed the air filter box and could see the adjustment mechanism clearly I realized that it's designed to be adjusted with either a wrench OR a screwdriver. There is a gear-like assembly attached to the head of the bolt, and a slot to insert a screwdriver to engage the gear. Turn the screwdriver and you turn the bolt (and thus raise/lower the headlight beam). Hence the photo showing the screwdriver - duh. If you use a long screwdriver you can reach the slot & gear WITHOUT removing the air filter box.
Good luck,
Eggy
2008 Coupe
Originally Posted by spikeitaudi View Post
I didn't need to remove the airbox. I had a LONG screwdriver to reach down there.
Eggy is offline
post #22 of 22 Old 07-16-2014, 05:32 AM
is this same for 2008 & 2012 accords?
Crxej1 is offline
