2008 Accord door handle removal instructions - Drive Accord Honda Forums
post #1 of 8 Old 10-29-2008, 02:01 PM Thread Starter
am thinking about replacing colored handles w/ chrome.
thanks
'08 Honda Accord EXL I4 w/ nav.
DDM 4500k 35w HIDs w/ Harness
'04 Honda Lawnmower
'00 Honda VFR
2x '09 Honda Eu2000i
VFR pilot is offline
post #2 of 8 Old 11-03-2008, 10:26 AM
thanks
It's a process with many steps and hard to explain. Your best bet is to spend the $125 for the Service Manual and follow the instructions. You could always have the dealer do it as well, but that would likely be even more. To recoup your cost, you should easily be able to sell the Service Manual afterwards.
2008 Taffeta White Sedan EXL-NAV I4
OEM USDM: Interior Illumination, Back-Up Sensor, Body Side Molding, Door Edge Guards, Splash Guards, Bumper Applique, All-Season Floor Mats, Trunk and Lower-Dash Insulators (from V6), Car Cover
OEM Imported: Illuminated Side Step Garnish, Headlight Protectors
Non-OEM: 3M Clear-Bra, V-LEDS LED's
taffwh2008sedan is offline
post #3 of 8 Old 11-03-2008, 12:24 PM
ol' school SQ
EvolNtent's Avatar
It's not bad, remove door panel, cut film back and there is one 10 or 12mm bolt(cant remember) that holds the part of the handle on that doesn't pull out. If you're going to ask how to get door panel off and can't figure it out yourself, you probably shouldn't attempt the handle. If you do though, remove that one bolt and pop the smaller piece off then pull out on the handle and pull it to the rear of the car and it will come out.
EvolNtent is offline
post #4 of 8 Old 11-03-2008, 12:44 PM
MSchu's Avatar
It takes about 10-15 minutes per side once you know what you are doing. It's fairly easy, BUT there are many things to break... best go slowly and follow the manual
MSchu is offline
post #5 of 8 Old 02-14-2009, 06:00 PM
Princess, can you post the animation if there is one of this install?
A320pilot is offline
post #6 of 8 Old 02-23-2009, 11:55 AM
here you go
post #7 of 8 Old 11-10-2014, 07:20 PM
Originally Posted by princess View Post
here you go
From which service manual did you get that pdf? Is it from Haynes, Chilton, or from Honda, etc.?
gogiison2 is offline
post #8 of 8 Old 11-10-2014, 07:44 PM
Honda
The Following User Says Thank You to princess For This Useful Post:
gogiison2 (11-13-2014)
