02 A/T 2nd Clutch Pressure Switch Location - Drive Accord Honda Forums
post #1 of 15 Old 08-18-2009, 10:08 PM Thread Starter
Hello. New to DA forums. Haven't been able to find this information anywhere. Thanks in advance for your help.
2002 Accord SE 4 Cyl A/T
41,000 miles
2nd Owner
No previous problems
Haven't felt any difference in driving, but Check Engine Light came on recently. The car is running fine, but I haven't been driving it and I need to get the CEL cleared so I can get my car inspected (PA).
Pulled the codes--P1738: Problem in 2nd Clutch Pressure Switch Circuit. No visible problems with any wires running into what I thought was the correct part, so I ordered the part.
It arrived ok, but I have not been able to locate the location of the pressure switch anywhere under my hood. I was incorrect with where I thought it was. I have the service manual which indicates the location on 1 diagram. The diagram is an exploded view, and I'm having difficulty orienting it. If anyone can tell me how to locate this part, or even point me in the right direction (like a photo or better diagram), I'd really appreciate it.
Back-story:
I contacted 3 Honda dealers in the area, including where the car was originally purchased. None would help without having my car looked at by a 'Honda Certified Tech' for about $95 to pull the same codes. They wouldn't even run my VIN to tell me if my car qualified for an extended warranty if it was a tranny problem, despite the low mileage. None of the mechanics would acknowledge there have been numerous problems with the 98-02 Accord trannies.
I found a 4th dealer who would diagnose and order me the proper parts to fix it myself for $86 + parts. Problem is it's about 2 hours away.
The 4th dealer told me the part # for the 2nd Clutch Pressure Switch is 28600-p6h-003. He wanted $70, non-returnable shipped. For $40 shipped, I found a returnable Honda Genuine part online. Figured this was a good place to start. If it doesn't clear the code, I'll return the part and bring it to a dealer.
Thanks!
insceptor is offline
post #2 of 15 Old 08-19-2009, 07:50 AM Thread Starter
Lightbulb Update
I took a picture of where I thought it might be located. Can anyone tell me if this is the correct location before I start disconnecting everything to get to it?
It appears a single, BLUE wire is running to the part. The wire connector attached to the part is black, and connector on the part itself looks green. My connector on the replacement part is also green.
Thanks!
LOCATION???
http://picasaweb.google.com/lh/photo...eat=directlink
NEW PART:
PART DIAGRAM
Switch is #14
http://www.hondapartscheap.com/south...41_ATM0710.gif
post #3 of 15 Old 08-19-2009, 09:54 AM
nehonda's Avatar
As best I can tell from your picture that is the location for the 2nd clutch switch. The wiring diagram I have shows the wire should be blue with a black tracer. As the code states the problem may be more likely to be with the wiring or connector than the switch itself. I would pull the connector, clean it if it looks dirty, hook it back up then clear the code by disconnecting the battery for a few minutes. If the code comes back then I might change the sensor.
The Honda service manual indicates you need to remove the rear motor mount bracket to access that switch.
Good Luck
nehonda is offline
post #4 of 15 Old 08-19-2009, 10:46 AM Thread Starter
Thanks so much! I'll get started as soon as it stops raining. I'll test the wiring before swapping the switch, like you recommended.
I'll let you know how it it goes...
post #5 of 15 Old 08-20-2009, 06:57 AM Thread Starter
Update
That is indeed the correct part location. I actually came in from the top of the engine and removed the upper radiator hose and air intake to access the part. Taking off the radiator hose proved to be the most difficult task. I checked the wiring to the pressure switch, but everything was in order there. No breaks in the wiring or debris in the connector. I installed the new switch last night. This has resolved the issue.
The Check Engine Light has remained off since then. The Maintenance Required light came on, but it has remained off after I reset it by putting the key in the ignition in position II and holding down the Odo Reset button for 10-15 seconds. This likely just has something with me disconnecting the battery.
I will post pictures and more details soon to show others how to resolve this issue.
Thanks again NEHONDA, I would not have attempted to disconnect everything and perform the swap without your confirmation.
post #6 of 15 Old 09-15-2009, 02:08 PM
fanduboz
Hi ,
I have similar problem as insceptor . Appriciate your feedback and Thanks in advance for your help.
48,000 miles
2nd Owner
Recently 'CEL' light turned on and when i pulled the code i got P1739 code. googled for this and it indicates
P1739: Problem in 3rd Clutch Pressure Switch Circuit.
Can you help me how to locate this and how to resolve this problem ?
Car is running fine but do you think my car is on risk ?
ravisonika is offline
post #7 of 15 Old 09-15-2009, 03:15 PM
Insceptor:
Recently becoming familiar with the "BAXA-MAXA-B7XA" 4AT, during my "Continuing Saga..." project, paying close attention to excellent posts, such as yours, pay me and other Gen Six owners very well. This one deserves a "Sticky."
12153 is offline
post #8 of 15 Old 09-15-2009, 06:09 PM
nehonda's Avatar
Originally Posted by ravisonika View Post
Hi ,
48,000 miles
2nd Owner
The 3rd clutch pressure switch is located as shown by the picture in post #2 (but not easy to reach).
If the transmission is shifting normally, the problem may be intermittent and it wont hurt to continue to drive it. If it starts shifting rough or slipping you need to get it fixed asap.
nehonda is offline
post #9 of 15 Old 09-16-2009, 03:00 AM
fanduboz
Location of 3rd clutch pressure switch
thanks nehonda , bit sigh of relief that it is not a too serious problem .
Dont want to get ripped off by honda repair dealer , hence appriciate if you can tell what is the location you are referring to in your response. It seems that below picture is taken for 2nd clutch pressure switch .
Any pic may be of great help . thanks again.
post #10 of 15 Old 09-16-2009, 05:13 AM
fanduboz
Also when i drove today to work , a TICK sound was coming every 3-4 minutes from CFL side .
post #11 of 15 Old 09-16-2009, 03:48 PM
nehonda's Avatar
My bad, I thought you were looking for the same 2nd clutch pressure switch location as the OP, but after rereading your post I realize you are looking for the 3rd clutch switch. It is item 15 on the previous diagram and located near the transmission dipstick - more toward the front of the transmission and toward the passenger side. According to the service manual it has a blue wire with a white tracer. Sorry no pictures.
For what its worth, the service manual states the P1738 & P1739 (2nd & 3rd switch) codes do not trigger a flashing D4 light or the MIL light (check engine). The codes are only stored for readout later. If you had a MIL light it might have been due to something else that was temporary and the trany switch code was just a old stored code.
Hope it helps.
nehonda is offline
post #12 of 15 Old 09-16-2009, 05:10 PM
AC6DN
Bruce Hawkins's Avatar
I think this the interment problem I had it was accompanied with "P??? Pending code"...
Any way if your savvy with the search tool, do a search of me and trany problems, on this web site. Turned out to just be a ghost problem, shows up, and disappears, every 50K miles or so.
Bruce - AC6DN:
Honda Accord, 2001, 2.3L (L4), F23A4, 4D EX - My main car…
Ford Taurus, 1992, 3.8L V6, - Trany prob's
Toyota 4x4 Extra Cab Truck, 2.4L SR5, 22RTE (Turbo) 1987, I still have.
Honda Accord, 1984, 1800cc? L4,
Plymouth Arrow, 1978?, 1800cc?, L4 (POS)
Chevy, Monza, 1976, 350cu, V8, My funnest car, think muscle car, poorly made...
Olds Starfire? 1975, 231cu odd fire, V6,
My first car, 1965 Chevy Impala 283cu V8, (I got during the mid 1980)
Bruce Hawkins is offline
post #13 of 15 Old 09-19-2009, 09:42 AM
fanduboz
thanks nehonda and Bruce Hawkins.
I tried to locate 3rd clutch pressure switch without any success. Can you help me to locate it in the attached picture and pinpoint where to see this switch ? I will try to change it if possible .
Also i tried to reset CEL by taking off fuse of Clock or pressing the reset button but CEL is still on . Car is running fine .
thanks for all your help .
post #14 of 15 Old 09-19-2009, 11:35 AM
nehonda's Avatar
The 3rd clutch switch is not visible in any of the photos in your post. It is below the battery and about 4 inches left (toward passenger side) of the transmission dipstick. There will be one wire connected to it with the previously noted colors. I think you should be able to find it without removing anything else, but it is somewhat hard to see.
Good Luck
nehonda is offline
post #15 of 15 Old 07-25-2011, 04:30 PM
I too had this code read out for the faulty 2nd clutch pressure switch on my Honda Accord 2002 SE. I am thinking of replacing the switch by my self but the problem is that I have searched for the replacement part at rockauto.com, advanceautoparts.com, autozone.com and also googled it but I am unable to find a website that sells it. Could someone please help me find a genuine online store that sells this switch.
Thanks.
ann77 is offline
