TCS & Engine light went on & D4 blinking...what happend?? - Drive Accord Honda Forums
post #1 of 15 Old 04-14-2010, 11:31 AM Thread Starter
prowler220x's Avatar
So today I'm driving down the street and all of a sudden my TCS & Check Engine lights turn on and my D4 lights starts blinking. I pull over, turn the car off then back on and the TCS light is off the the D4 is now solid like it should but the Check Engine light is still on.
Before I go out and get the engine light checked out for the code to find out what it's reading, has anyone experienced this before? What happend??
prowler220x is offline
post #2 of 15 Old 04-14-2010, 11:43 AM
cajun's Avatar
Is it shifting okay? What color is your ATF and is it at the correct level? Hope I'm wrong, but your trans might be giving you an early warning.
2010 PMM Accord LX-P, TSX rear sway, GG lower grille, 35% tint, 50K+
2006 Toyo Sienna LE, 100K+
2002 Accord SE (sold), TL rear sway and upper strut bars
cajun is offline
post #3 of 15 Old 04-14-2010, 11:49 AM Thread Starter
I've only had the car for about a month and haven't noticed any changes in the shifting since I purchased it. The ATF fluid is a reddish color and it's at the correct level.
post #4 of 15 Old 04-14-2010, 02:10 PM
Aspiring Tuner
AccordLXMaster's Avatar
blinking d4 light.....is a VSS(vehicle speed sensor)
EDIT: also indicates problems with the tranny....sorry
265k and Running
Tons of Upgrades Currently in Progress...[3/31/16]
98 LX
ENGINE MODS
-Spectre CAI
-Flowmaster 40 Series
-NGK G-Power Plugs
-4-2-1 Header
-CherryBomb GlassPack Resonator
-JDM F23A Swapped
COSMETIC MODS
-Double 5% Tint
-Twin Halo Projectors
-Bright White LED Turn Signals
-DDM Tuning 6000k 35w
SUSPENSION MODS
-Megan Strut Bar
AccordLXMaster is offline
post #5 of 15 Old 04-14-2010, 02:53 PM Thread Starter
I guess replace it with one of these & then see how it goes?
http://www.partstrain.com/ShopByDepa...r/HONDA/ACCORD
Anyone experience what I mentioned in the first post?
post #6 of 15 Old 04-15-2010, 09:32 AM
cajun's Avatar
See how it goes? Pull your CEL code before you start replacing parts.
cajun is offline
post #7 of 15 Old 04-15-2010, 09:56 AM Thread Starter
Of course, I'm getting that checked today before I order any parts
post #8 of 15 Old 04-15-2010, 10:29 AM
In one place & one accord
ShortTom's Avatar
Accord to the Honda OwnerLink extended transmission warranty statement:
" These characteristics are not normal; if you experience any of them, call your Honda dealer.
* While driving, the D4 indicator on the instrument panel flashes.
* An abnormally loud noise from the transmission.
* Extremely slow or delayed gear engagement, upshifts, or downshifts.
* Abnormal gear slippage during upshifts or downshifts.
* Erratic or excessively harsh shifting.
* Automatic transmission fluid (ATF) leaks.
In the next few weeks, owners of potentially affected vehicles will be sent a copy of this letter along with reimbursement instructions in case they previously paid to have the transmission repaired or replaced.
It's important to maintain your vehicle's transmission according to the maintenance schedule in your owner's manual. Not maintaining the transmission properly can void the warranty coverage.
Thank you for your understanding and cooperation in this matter.
Sincerely,
AMERICAN HONDA MOTOR CO., INC.
Honda Automobile Division "
I guess that's mainly no helpful other than indicating it's not a normal scenario. What year and mileage is on your Honda? I spoke to a Honda tech the other day that said even if your vehicle's out of warranty Honda will "work with you" on a transmission replacement. The extended warranty I'm talking about is for 98-01 models and covers 7 years/100,000 miles, whichever comes first so you're def out of warranty. Unless there's another tranny recall on later models.
2001 Naples Gold Metallic Accord EX V6 Coupe that I want to look EXACTLY like goldnknight22's.
ShortTom is offline
post #9 of 15 Old 04-15-2010, 11:10 AM Thread Starter
It's got around 107,300 miles on it. It shifts pretty smoothly and the tranny's not making any loud noises.
1st to 2nd gear doesn't happen as quick as it did on previous car's I've owned unless I push down a bit harder on the gas pedal but I'm assuming that's because of the transmission and not an indicator of a problem
I'll know more after I get the CEL code
post #10 of 15 Old 04-15-2010, 11:46 AM
Aspiring Tuner
yeah just pull the code...
265k and Running
98 LX
ENGINE MODS
-Spectre CAI
-NGK G-Power Plugs
-4-2-1 Header
-JDM F23A Swapped
COSMETIC MODS
-Double 5% Tint
SUSPENSION MODS
-Megan Strut Bar
post #11 of 15 Old 04-16-2010, 12:46 PM Thread Starter
Got the code read:
PO780 - Shift Malfunction
They turned the light off and said if it goes back on then it's really a problem. Anyone deal with this? The car still shift and sounds pretty smooth so I'm hoping if maybe replacing the fluid and the filter in the tranny will keep this problem at bay.
post #12 of 15 Old 04-16-2010, 01:13 PM
CDsDontBurn's Avatar
i did. but my transmission was already a gonner at the time. a few days after this started happening to me and i got that code, i took my car to a shop to have the tranny rebuilt.
you say yours is shifting fine, so maybe it just happened once or twice. keep an eye on it to see if it comes back. on my car when it happened, it was slipping a lot between all 3 gear changes: 1st to 2nd, 2nd to 3rd, 3rd to 4th.
2000 2dr. v6 Accord, "Dirty Girl": Greddy MX Exhaust | K&N Drop-in Filter | Magnaflow Hi-Flow CAT | Eibach Pro Springs | KYB-GR2 Shocks | Eibach Sway Bars | Stereo stuff
'97 Thunderbird, "Pearl": L/R 2.5in Magnaflow Hi-Flow CATs | PI Intake | PI Cams
'13 Taurus, "The Bull": 3.5L Goodness
CDsDontBurn is offline
post #13 of 15 Old 04-16-2010, 09:50 PM
ShortTom's Avatar
Lightbulb
Got the code read:
Sure couldn't hurt. I'm like CDs you pretty much have to wait and she what does.
ShortTom is offline
post #14 of 15 Old 10-22-2015, 09:40 AM
Having this problem
Sincerely,
So what is the solution to this?
Simmons is offline
post #15 of 15 Old 10-22-2015, 04:25 PM
Replace / Rebuild the transmission is the solution.
