4000 RPM rev limiter - Drive Accord Honda Forums
post #1 of 14 Old 07-22-2010, 11:43 AM Thread Starter
It seems like my 2000 se 4 speed AT is pinging off the rev limiter at 4000 rpm. everything is fine untill 4000, then it goes into jerky mode that is not happy. it happens anytime at 4000.
i read that it is possibly a vtec problem? does my model even have vtec? the transmission was just replaced.
voxmeus is offline
post #2 of 14 Old 07-22-2010, 01:29 PM
check your engine oil levels.
aloe is offline
post #3 of 14 Old 07-22-2010, 01:50 PM
Accordriver's Avatar
Most likely a vtec problem, as said earlier check your oil level. Do you have a check engine light?
-03 Honda Accord EX V6
-Debadged-17mm sway bar-UR crank pulley-AEM CAI
Accordriver is offline
post #4 of 14 Old 07-22-2010, 02:22 PM
Ramon's Avatar
Definitely sounds like your car has been running in limp mode to protect itself from a problem that it has detected. Can you get to a shop that can pull the trouble codes for you to help identify what caused it? In the meantime, go easy on the car until you get the problem resolved.
Current: 2016 Accord Sedan V6 Touring (Modern Steel Metallic)
Mods/Additions: Window Tint (20% rear/35% rear doors), Gorilla locks, Trunk Cargo Tray, LED upgrades (in progress...)
Previous Cars: 2006 Accord Sedan EX V6 6MT Navi, 2000 Accord Coupe EX V6, 1992 Integra GS-R, 1990 Integra GS, 1986 Integra LS, and a couple of 1972 Mazda RX-2's
Ramon is offline
post #5 of 14 Old 07-23-2010, 06:43 AM
One of these two. I'm going to go with VTEC solenoid.
sodaks2k is offline
post #6 of 14 Old 07-23-2010, 07:20 AM
TUBHMOOBVAJ's Avatar
Have you done a timing belt change recently? If so probably the timing isn't correct otherwise it's probably your v-tec.
1999 Honda Accord LX 4-Cyl
15' OEM 2002 SE rims
Yokohoma all season tires
AEM SRI
Apexi WS2 catback exhaust
Red and clear tail lights
Chrome Headlights without amber
DDM Tuning 55W 6000K low bean
Nokya Hyper Yellow 2500K high bean
01-03 Honda Civic foglights w/DIY OEM Fog switch
TUBHMOOBVAJ is offline
post #7 of 14 Old 07-23-2010, 08:17 AM
Aviography's Avatar
You may experience similar issue if the timing belt had jumped a tooth on the cam pully.
__________________
DA Moderator Team
Aviography is offline
post #8 of 14 Old 08-02-2010, 09:34 AM
Aspiring Tuner
AccordLXMaster's Avatar
just had the same problem yesterday...until i turn it off and start it back up
265k and Running
Tons of Upgrades Currently in Progress...[3/31/16]
98 LX
ENGINE MODS
-Spectre CAI
-Flowmaster 40 Series
-NGK G-Power Plugs
-4-2-1 Header
-CherryBomb GlassPack Resonator
-JDM F23A Swapped
COSMETIC MODS
-Double 5% Tint
-Twin Halo Projectors
-Bright White LED Turn Signals
-DDM Tuning 6000k 35w
SUSPENSION MODS
-Megan Strut Bar
AccordLXMaster is offline
post #9 of 14 Old 08-17-2010, 02:09 PM Thread Starter
so i finally had time to look under the hood and see what's going on:
the check engine light is on. the oil level seems fine. i dont know when or if the timing belt has ever been changed.
i looked at the vtec solenoid and saw that there was some caked black oily residue gunk near the soleniod. i had to wipe down various parts of the engine to find where the oil was coming from (it must be an old problem). i felt right underneath where the vtec solenoid attaches to the engine and felt fresh hot-ish oil. (still warm from the ride home).
so, there seems to be oil leaking from the solenoid. what does this mean?
would a bad seal cause the check engine light to come on? do i need to replace the whole thing or just a seal? is this something to have a professional repair, or can i replace the seal/solenoid myself?
should i stop driving this car to work or will it be ok? (15 mile highway commute each way)
thank you all for the input!
voxmeus is offline
post #10 of 14 Old 08-17-2010, 03:13 PM
Aviography's Avatar
Remove the VTEC solenoid, there's likely a mesh screen on the oil input, it may hav been clogged over time and not activating, which may have triggered the CEL.
Clean the mesh, reinstall, disconnect battery, reconnect battery, and see if engine feels normal and if the CEL comes back.
__________________
DA Moderator Team
post #11 of 14 Old 08-17-2010, 04:12 PM
Aspiring Tuner
seriously??? thats all you have to do? mines been bad for like almost 2 years
265k and Running
98 LX
ENGINE MODS
-Spectre CAI
-NGK G-Power Plugs
-4-2-1 Header
-JDM F23A Swapped
COSMETIC MODS
-Double 5% Tint
SUSPENSION MODS
-Megan Strut Bar
post #12 of 14 Old 08-17-2010, 05:15 PM
CDsDontBurn's Avatar
so, you haven't been able to vtec your car for 2yrs already?!
2000 2dr. v6 Accord, "Dirty Girl": Greddy MX Exhaust | K&N Drop-in Filter | Magnaflow Hi-Flow CAT | Eibach Pro Springs | KYB-GR2 Shocks | Eibach Sway Bars | Stereo stuff
'97 Thunderbird, "Pearl": L/R 2.5in Magnaflow Hi-Flow CATs | PI Intake | PI Cams
'13 Taurus, "The Bull": 3.5L Goodness
CDsDontBurn is offline
post #13 of 14 Old 08-17-2010, 07:17 PM
Aspiring Tuner
it works....it only messes up id say about once a month..or once every other month
265k and Running
98 LX
ENGINE MODS
-Spectre CAI
-NGK G-Power Plugs
-4-2-1 Header
-JDM F23A Swapped
COSMETIC MODS
-Double 5% Tint
SUSPENSION MODS
-Megan Strut Bar
post #14 of 14 Old 03-18-2011, 11:40 AM
Second gear slammer!
redaccordcoupe's Avatar
VTACKKKKKK i love my vtec poppin accord
99' Ex-l coupe v6 *black current pearl. R.I.P.
00' ex coupe 5spd. *san marino red
86' hatchback lx-i 5spd *silver metallic (toy)
91 Prelude Si B20A5 frankenproject!!!
04 Accord Coupe 6-6 Satin Silver Metallic (daily)
"when i fill my tank i go to stop and shop,to the rice aisle, pour in that uncle bens white rice. SON! the stuffs better than 110k"
redaccordcoupe is offline
