1998 Accord Key Chip Problem - Drive Accord Honda Forums
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
post #1 of 12 Old 01-11-2012, 11:52 AM Thread Starter
Hey guys I own a 1998 Honda Accord LX, with built in alarm. The key has a chip to start the car as well. When I insert the key into the ignition, a green key display flashes on my dashboard. Recently, when I am driving, the car will shut off on me and the steering wheel locks up real quick, since it is power steer. When I try to start the car again, the green flashing key wont appear on my dashboard and won't start the car. The only way the car will start again is if I just wait it out. I stay in the car for about 5-10mins after that I turn the key to start the car and the green flashing key appears on my dashboard and the car will start again. Does anyone know why it does that? Is there anyway that this problem can be fixed? I am scared to jump on the freeway and this incident occurs, so please if you know anything about this problem please post on how to fix. Thank you.
zombo is offline
post #2 of 12 Old 01-11-2012, 03:46 PM
nehonda's Avatar
I think your immobilizer key is working correctly. The green light only comes on for a couple seconds initially then stays off until you switch the key OFF. If the green key light keeps blinking then the system does not recognize the key chip. You need to switch the ignition to OFF which should cause the green light to bink several times then to ON to start the sequence again.
Do you get any warning lights on the dash when the engine quits or does everything go off? If all the dash lights go off then your ignition switch (not the key) is likely worn out and needs replaced.
Also listen for the fuel pump priming when you first switch the key ON. If you dont hear it for a couple of seconds then its not getting power.
nehonda is offline
post #3 of 12 Old 01-11-2012, 05:48 PM
namegoeshere's Avatar
namegoeshere is offline
post #4 of 12 Old 01-11-2012, 11:03 PM
03LXV6's Avatar
When you try to restart the car is it completely dead or does it turn over? I think the 6th gens had ignition switch problems.
2007 EX-L 4DR
03LXV6 is offline
post #5 of 12 Old 01-13-2012, 09:38 AM
Zzzz
Was the ignition recall taken care of for that car?
2010 EX-L V6 NAVI SEDAN
1999 EX V6 COUPE
2006 Si
Viper 5901 DIY
3rd Brake Light LED Conversion
I unlock iPhones! 3G 3GS 4 4S 5
dorkiedoode is offline
post #6 of 12 Old 01-13-2012, 11:40 AM Thread Starter
Ya your right the green light turns on for a few seconds then it goes away,until I turn the key off. And no, I do not get any warning lights on my dash. It just turns off and when it turns off, almost instantly all the lights on my dash turn on EXCEPT the green key. That is when I know that the car will not start for awhile. There have been times where I have been lucky, the car stops but I instantly put the gear on park and turn the key on and the car turns on again. (When I am in a red light or stop sign.)
I do not know what that is haha.
When I try to re-start the car, you can hear the engine so its not completely dead. I'm not really sure what turn over means, but I can hear the engine. And when I see that green key blink I know the car will start.
zombo is offline
post #7 of 12 Old 01-13-2012, 05:01 PM
nehonda's Avatar
Some 98-99 Accords had a factory recall to replace the ignition switch for problems just like you describe. A dealer can check your VIN number and tell you if it was replaced, but even if it was, it sounds like it needs it a again.
You can also enter your VIN on-line and it should tell you if that recall was done, but they only replace the switch once under warranty. If you search you should find the site for the Honda Owners to register.
nehonda is offline
post #8 of 12 Old 01-14-2012, 07:19 PM
one wheel drive
DonutLimo's Avatar
Do you have another key to try just for fun?
Hah that zombo site is ridiculous
99 EXV6 Coupe 211k 6spd swap
95 F250 supercab 7.3 4x4 5spd
90 Donut Limo- RIP, for you have served us well
DonutLimo is offline
post #9 of 12 Old 01-15-2012, 07:34 PM
Flyboy's Avatar
I had the same kind of issue with my car about a year and a half ago.
Mine would never stop running, but it would not start after being shout off for a while. The green key light would not illuminate when the key was inserted which made me think that the chip in the key was bad. The problem was the main relay needed to be replaced. The relay has a circuit board attached to it that controls various functions such as the immobilizer. The circuit board developed a hairline crack that would expand when warm. The expansion would break a solder joint to one of the components on the circuit board. A few weeks later a friend was telling me that he was having the same issue with his Accord and it was the main relay that had to be replaced. If my memory serves me correctly the part was about $175 from the dealer and he charged me about another $100 to trouble shoot the problem, it took about an hour and a half, and replace the part.
2013 Accord Coupe EX-L San Marino Red
2015 CR-V EX Urban Titanium Metallic
2007 Fit Sport Silver 65,000 miles and going strong.
Previous Honda: 2000 Accord Coupe, 1994 Accord Wagon Red, 1988 Prelude White 5 speed manual, 1981 Accord 4 Door Ivory 5 speed manual
Previous Cars before Honda: 73 Mazda RX2 manual, 63 VW Bug manual, 63 Alfa Romeo 2600 Spyder manual, 70 Toyota Crown manual, 59 Vauxhall Victor manual (worst car ever produced, a pre Yugo, Yugo)
Flyboy is offline
post #10 of 12 Old 01-20-2012, 11:00 AM Thread Starter
Well I took it to a Honda Dealer where they do repairs, and they said the idle adjustment was all dirty inside. My RPM was also pretty low, when i put it on park the RPM would be fine but when i was driving and stopped at a stop sign or red light the RPM was all low and sometimes the car would just die. Well they cleaned it out and the RPM was normal for that day, the next day I went to go start the car and it wouldnt start. The starter wouldnt kick in. So now i have to replace the starter.
zombo is offline
post #11 of 12 Old 03-23-2015, 05:19 PM
I Have A 1998 honda accord it always cranks but sometimes don't start when it doesn't start the check engine light on the dash that's normally there isn't at the same time with the key on and brake pedal pushed down the shifter won't pull back to neutral I also noticed that the brake light warning and open doors and trunk warning light are all lit up on the right hand side of my dash I am a mechanic but not very firmiliar with Hondas and dont have a ton of money to throw a bunch of parts at it any help would be greatly appreciated thanx
NickG1982 is offline
post #12 of 12 Old 11-04-2015, 09:26 AM
2002 accord sedan ex v6 was in a accedent hit on the pass front door and fender the door is off and fender is also off the car wont start it turns over and the fuel pump is running and it wont start the green key is flashing on in the dash honda told me i had to bring the car in to reset the key or is it posible something elts if so let me know
john johnson is offline
