96 Accord speedometer sticking - Drive Accord Honda Forums
post #1 of 11 Old 08-27-2009, 04:15 AM Thread Starter
Unhappy 96 Accord speedometer sticking
My 1996 Accord's speedometer occasionally sticks around the 20 mph location, and causes the odometer and trip meter to stop working. Other than replacing the whole cluster, is there a way to repair this? Also, if I replace it, is it possible to adjust the mileage to match my existing odometer?
ccparch57 is offline
post #2 of 11 Old 08-27-2009, 04:17 AM
A&Fbro28's Avatar
Send a message via AIM to A&Fbro28 Send a message via Yahoo to A&Fbro28
Time for a new speed sensor. It isnt much money that i can remember.
Desmond,
2013 Honda FIT Sport w/ Navigation
5000k HID's, Leather seats, Full Harmon Kardon System System, Cusco Mid-Brace. 10mm rear spacers, Tanabe Medallion Exhaust, HPS short ram intake and Tein S-Tech springs with race header and more to come
08 Acura TL w/Technology Pkg
08 Taffeta White Honda Accord EX-L w/Navi Coupe (traded-in)
http://www.cardomain.com/ride/3093726
A&Fbro28 is offline
post #3 of 11 Old 08-28-2009, 11:21 AM
CCParch57:
Is your speedo solid-state (electronic)? Or old-style (mechanical) with cable drive?
12153 is offline
post #4 of 11 Old 08-30-2009, 03:28 PM
ItsaHonda's Avatar
The 5th gen gauge cluster is electronic, not cable-driven... ditto for the 4th gen. The VSS (vehicle speed sensor) is a common problem on the older Accords, so it is certainly a possibility... but my experience with a VSS failure has been an entirely non-functioning speedometer, not just an intermittent pause. I would say to check the cruise control when the speedometer sticks, but I'm not certain that it even engages at 20 mph. If the VSS has failed or is failing, the cruise control will be inop.
1990 Honda Accord LX coupe
130,XXX miles
1989 Honda Accord LX sedan
186,XXX miles
1998 Lexus GS400
170,XXX miles
1992 Cadillac Allante
70,XXX miles
2013 Kia Optima LX
8,xxx miles
ItsaHonda is offline
post #5 of 11 Old 08-30-2009, 03:42 PM
ItsaHonda:
Thanks for the enlightenment. Were I not so lazy, I would look it up.
This represents a techno change from my 3rd Gen...which has a cable-driven, mechanical speedo. Its speed sensor unit governs (only) cruise control operation.
12153 is offline
post #6 of 11 Old 09-09-2009, 01:41 PM Thread Starter
I have determined pretty much that it is my speedometer, so I was able to obtain a used one (entire cluster) at a Honda salvage parts place. I have figured out how to replace it, but now my problem is I can't get the trim off the console in order to get at the cluster. I removed the two screws underneath in front of the cluster and I can get that side pulled out, but I can't get the side above where the radio sits out. I have removed the two HVAC knobs, but it appears to be attached on that side. Is there another screw or something that has to come out?
post #7 of 11 Old 09-15-2009, 11:10 AM
i was going to say the same thing
check speed sensor
h22accord is offline
post #8 of 11 Old 09-15-2009, 01:48 PM
Always in reverse
Shadow Works's Avatar
Where is this speed sensor located guys?
Shadow Works is offline
post #9 of 11 Old 09-25-2009, 11:42 PM
dont deviate
htekken's Avatar
the VSS is tough to spot. it sits on top of tranny but towards the back. even in daylight it can be hard to see since its deep in the bay, so a flashlight would help. hard to replace cuz its hard to reach, i know, i did this last month.
OP how exactly did you determine it was the cluster? i know this thread is kinda old but curious cuz it sounds like a vss problem to me. my symptoms were, speedo needle went crazy up and down while driving, then just stopped moving completely, trip odom stopped working, odometer stopped working, and got the occasional CEL.
/94EX CD7 G77M/DZ-D1/JDM S2K HID/18RH-C5/WW-T/(gone)
/07SE CM5 NH700M/17V6-6/OEM LIP/Decklid/Hybrid LED/TSX HID/
/02IS BD1 B01B 8N8/TRD/SD/
htekken is offline
post #10 of 11 Old 11-02-2009, 01:03 PM Thread Starter
Speedometer replacement
I determined it was the speedometer cluster based on what my normal mechanic told me. He had suggested I could replace it myself, so I found one at a Honda salvage yard near me. The problem I have had is getting the cover off so that I can remove the cluster. I can see that it is held in by clips, but for the life of me I cannot get it loose, especially around the heater vents above the radio. Is there a special tool for this?
post #11 of 11 Old 11-04-2009, 09:15 AM
dont deviate
htekken's Avatar
no. did you trying using a flathead to pry? its been a while since i removed the gauge cluster so i dont member whut i did.
htekken is offline
