1988 Honda Accord issues - Drive Accord Honda Forums
  • 1 Post By greg1c
  • 1 Post By UnknownJinX
post #1 of 5 Old 01-02-2017, 06:01 PM Thread Starter
Hello all , within the last week I have had my fuel pump replaced and a week before that I had my distributor replaced. The honda worked just fine after the fuel pump was replaced but I just went out to start it up now and everything seems fine the engine starter clicks and I can smell gas going in unlike when the fuel pump was dead but it just won't turn over all the way. The gas pedal seems kind of lite to the touch and the brake pedal is a little hard to press also the steering wheel is hard to turn even when the key in the the on position. Any ideas what else it could possibly be or if a novice mechanic like myself could possibly fix something?
Honda4ckr is offline
post #2 of 5 Old 01-03-2017, 07:19 AM
Uptown Rooter
A 29-yr old car will have issues that only an older tech can find. For example, I'm wondering if changing the whole distributor was necessary; it may have just needed points. Your starter issue may be only the solenoid. If you're serious about restoring this Accord, don't do squat without reading or finding an owners manual, finding a good tech who's worked on Accords of that vintage, and locating a reliable parts supplier.
________________
2009 EXL V6 Sedan
Royal Blue
35% tint
OEM fogs / 22mm Progress RSB / Ultra Racing FSB / Koni FSDs / Modulo grille / debadged trunk /
Previous cars: 2003 EXL V6 Accord Coupe
1995 Accord EX Sedan
1985 Mercedes 300 Turbodiesel
1989 Volvo S90 Turbo
slimm1469 is offline
post #3 of 5 Old 01-03-2017, 07:39 AM
greg1c's Avatar
So I assume that the engine is not turning over, but the starter just makes a clicking noise? This sounds like a bad battery or a bad starter. First thing to do is make sure the battery cables are tight and clean. If you have a set of jumper cables try to jump your car and see if it is just a weak battery. How old is the battery? Is it still under warranty? I would take the battery to the place that sold it or a big parts store and have it checked. If the battery checks out and the cables are clean and tight you probably have a bad starter.
enne likes this.
Current Honda vehicles
Former Honda Vehicles
2001 Acura MDX Totaled t223k
1995 GSR sold @220k miles
greg1c is online now
post #4 of 5 Old 01-03-2017, 08:53 AM
Runnin' in the 90s
enne's Avatar
^ +1
Sent from my SM-G920V using Tapatalk
Selene, 1999 Honda Accord LX Sedan, 2.3L ULEV-VTEC, 134K, liquid wrapped jet black
Harlock, 1998 Chevy Camaro Coupe, 3.8L V6, 120K, sebring silver
Dana, 2002 Chevy Cavalier LS Sedan, 2.2 L, 134K, sandrift metallic
enne is online now
post #5 of 5 Old 01-03-2017, 09:41 AM
又一位第八代雅阁双门车主
UnknownJinX's Avatar
The hard-to-push brake pedal and hard-to-turn steering wheel are normal to a newer Accord when the engine is not started. Not sure about an old Accord, though.
Now, I would first suspect a bad battery. The easiest thing to check is the battery. Turn on your exterior lights. Are they really dim? If so, then the battery is low. You could also check with a standard multimeter. If the voltage reading is below 12.3 V, your battery is low. How old is the battery? If it's 5+ years old, then you should change it.
If the battery is good, then I would suspect the starter. If it is the starter, then a question I have is, "is it worth it?" Even a rebuilt starter(+installation, too) can be pricey, and good luck finding them for an old Accord like this...
Miker likes this.
My first car!
2008 Honda Accord Coupé EX-L V6 w/Navi 5AT PMM
Mods and such things:
AFE Pro Dry S drop-in filter
VCMuzzler II
HFP body kit
RGR-16D HFP Alloy Wheels
i-VTEC & 3.5 stickers
High and Low beams - Philips CrystalVision Ultra
Front turn signals - HV 6000K white/amber switchback
Rear lights - Philips Vision LEDs
Interior LEDs
Crosstour shift knob
OEM footwell lights
and more!
1999 Toyota Corolla CE 5MT
And a manual DD I will reveal later... ;)
UnknownJinX is online now
