92 Accord - Erratic rpms, missing/sputtering, stalling - Drive Accord Honda Forums
post #1 of 2 Old 09-19-2011, 11:36 AM Thread Starter
Ok..so I'm having some serious issues with my car. It's a 92 Accord 2.2 AT. I was having the infamous didn't want to start problem when it's hot out. After some research found out about the problems with the Main Relays on these cars. Then one day all of a sudden it started sputtering and stalled out shortly after I started driving (almost acted like it ran out of gas). It continued to do this sporadically on hot days. I thought the main relay must be getting pretty bad and finally went and picked one up and switched it out last week hoping perhaps that would fix both problems. No longer have the hot start issues but still having the sputtering/stalling issues.
I can usually tell when it's going to start sputtering/stalling because my tach usually starts jumping 300-400 rpm and the rpms will bounce sometimes with no accompanying missing/sputtering sometimes with. Then sometimes the tach will just go haywire and jump all over the place and finally will just drop to zero. When it drops to zero the car acts like it has stalled but no lights come on in the dash and if you pump the gas several times all of a sudden it'll usually (not always) sputter back to life and keep going. Occasionally pumping the gas doesn't work and after a moment it is completely stalled or it will sputter and stall completely. If it stalls completely sometimes it will restart right away and sometimes it will take 5 minutes or so before it will start again and when it restarts it usually sputters/misses at first and you have to really keep on the gas pedal to keep it running. Then I can usually finish driving to where I was going or it'll start the same cycle again immediately or within minutes. Also, there's a strong odor (fuel?) after sputtering and trying to keep it running. Figure I must be flooding it a bit when trying to keep it going.
Also, I've now noticed that at an idle at stoplights my rpms now drop to only 500 rpm - I keep thinking the car's going to die.
Has anyone had similar problems? I'm kind of at a loss. From searching on the internet it sounds like these cars are known for distributor issues. I've also read that erratic rpms could mean the ignitor? Perhaps the coil? Could it be a fuel filter or god forbid fuel pump issue?
Thanks in advance for any advice!
bluesyvox is offline
post #2 of 2 Old 09-27-2011, 07:02 PM
here are some checks...
Fuel pump: turn the key to acc..if you can hear the pump click on then the pump is good. you should hear it kick on.
Ignitor & coil: Get a helms and test the voltage for each. Usually ignitors don't slowly die they just stop working. Its almost all or nothing for them.
Fuel Filter: Easy...if you cant remember or don't know when it was last done then just replace it. That is cheap maintenance.
As for the low idle clean out your IACV with some brake cleaner and a rag to make sure it isn't gummed up. Also check the flux thermo valve on the fIACV.
Below the throttle body you will see the FIACV. It will have two coolant hoses attached, disconnect them and remove the FIACV. On the back of the valve there will be a copper/brass cover. Take that cover off and that will expose the fluxthermo valve. screw it down clockwise. You should be able to see an entrance hole...you dont want that covered.
Let us know how it goes
07 Sedan
94 N/A H22, ported head, s2p1 cams, s2vt, flat valves, blacktrax intake mani, euro R tb ported 70-65mm taper, hyptech rep header, Enkei Evo 5, Ground control, tokico struts.
accordh22a is offline
erratic rpm, missing, sputtering, stalling
