Whats the best tire size for 20" rims - Drive Accord Honda Forums
post #1 of 14 Old 03-12-2009, 09:20 PM Thread Starter
I currently have 20 x 8.5 rims on my 2008 Honda Accord EXL Sedan with 225/35/R20 tires. I wanted to know if this low of a tire isnt good for my rims? Should I get a tire with more sidewall? If so whats the best tire size for my set up, Im lowered on H&R springs. Any advice is appreciated.
mystick6 is offline
post #2 of 14 Old 03-12-2009, 09:33 PM
morcheez's Avatar
Send a message via AIM to morcheez
245/35 would be better imo...thats what i have and the sidewall is pretty decent
08 ASM Coupe i4/ tint / lip spoiler / 6k hids / 20" verde chaos 45mm offset 255/35 nitto nt555 / eibach pro kit / autozone grille mod / weathertech floor liners / clarion touchscreen / tsx key / trunk liner/ dual exhaust, v-leds white&amber turn bulbs/ fog lights w nokya 2500 bulbs/ odyssey lower grill/ custom wall in trunk/ 35&20 tint/black roof/ color matched grill and rear "H"
morcheez is offline
post #3 of 14 Old 03-13-2009, 11:10 AM
lebomb's Avatar
The 35 is the sidewall height...........your 245 is the width......so your tires are wider than his, but have the same sidewall height.
2014 Accord Sport CVT
Champagne Frost Pearl
Kicker 300watt Amp
Kicker CompR 12/ Ported Box
SON OF THUNDER
lebomb is offline
post #4 of 14 Old 03-13-2009, 01:22 PM
xJoeMama78's Avatar
Send a message via AIM to xJoeMama78 Send a message via MSN to xJoeMama78 Send a message via Yahoo to xJoeMama78
The 225 is the width of the tire in mm. The 35 is not the sidewall height but the aspect ratio. For this tire the sidewall height is 35% of the width, so it is 78.75 mm or ~3.1 in. For the 245/35 tire the sidewall height is 85.75 mm or ~3.38 in, so it is just over a 3/4 inch wider and has a bit over a 1/4 inch taller sidewall.
2008 Accord Coupe EX-L L4 Auto ASM
Clear bra | Tint | T-rex | Injen | Weapon R | Eibach | Enkei | Goodyear | SPC | H9/HIR | Hoen | LEDs | Clarion | JL | Focal | Python
1997 F-250 Crew Cab Diesel 4x4
Tymar | Diamond Eye | Bilstein | Clarion | Fosgate | JL
xJoeMama78 is offline
post #5 of 14 Old 03-13-2009, 06:40 PM
lebomb's Avatar
That may be true, but he has to go up TWO tire widths to go up just 1/4 in side wall height. Is that what he wants to do? At the same width the 40s or 45s would have taller side wall for sure.
Kicker 300watt Amp
SON OF THUNDER
lebomb is offline
post #6 of 14 Old 03-13-2009, 10:50 PM
morcheez's Avatar
wow completely wrong...do your homework next time bud ....the narrower the tire the more its going to have to stretch to fit so its not going to be as tall either
morcheez is offline
post #7 of 14 Old 03-13-2009, 11:00 PM
Going to run 245/35/20
You need a little meat on the sidewall or you'll be sorry, plus these Accords have HUGE wheel wells
SOLD
NO MORE Accord
Strippers4Me is offline
post #8 of 14 Old 03-14-2009, 06:17 AM
He wouldn't have any troubles with rubbing if he got a bigger sidewall like a 245/40 or 245/45?
anth6ny is offline
post #9 of 14 Old 03-14-2009, 06:23 AM
lebomb's Avatar
Ahhhhhhhhh............homework done!!!
Sidewall Aspect Ratio
Typically following the three digits identifying the tire's Section Width in millimeters is a two-digit number that identifies the tire's profile or aspect ratio.
P225/50R16 91S
The 50 indicates that this tire size's sidewall height (from rim to tread) is 50% of its section width. The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. We know that this tire size's section width is 225mm and that its section height is 50% of 225mm. By converting the 225mm to inches (225 / 25.4 = 8.86") and multiplying it by 50% (.50) we confirm that this tire size results in a tire section height of 4.43". If this tire were a P225/70R16 size, our calculation would confirm that the size would result in a section height of 6.20", approximately a 1.8-inch taller sidewall.
Kicker 300watt Amp
SON OF THUNDER
lebomb is offline
post #10 of 14 Old 03-14-2009, 08:47 AM
xJoeMama78's Avatar
It probably wouldn't rub, but 245/40 would be two inches taller than stock and 245/45 would be three inches taller. His speedometer would be significantly off, about 7.2% with the 40 series and 10.7% with the 45 series.
post #11 of 14 Old 03-14-2009, 01:08 PM
lebomb's Avatar
Hey.......up sizers..........be sure to check your tire pressure. I found mine to be at 30psi all the way around. With low profile tires.............you need to be 40-45 psi or your sidewall will be on the pavement when driving. You will wear out your tires with the quickness. My tires say 51 psi max., so Im running 42psi all the way around.
Kicker 300watt Amp
SON OF THUNDER
lebomb is offline
post #12 of 14 Old 03-19-2009, 12:39 PM
Plug this formula into an Excel spreadsheet:
=(A1*A2)*2/25.4+A3
I use it all the time it will give you a real good idea on how big or small you can go.
As far as the 40 or 45 series, that would be a big ass monster truck tire on your Accord. You also may want to head over to www.1010tires.com and use their calculator.
http://www.1010tires.com/TireSizeCalculator.asp
SOLD
NO MORE Accord
post #13 of 14 Old 03-19-2009, 12:53 PM
lebomb's Avatar
................. I think Im gonna have to disagree with this one.
Kicker 300watt Amp
SON OF THUNDER
lebomb is offline
post #14 of 14 Old 03-19-2009, 02:05 PM
I was being funny but here are the specs:
25.86 I4
26.33 V6
25.79 245/30/20 Tire Rack Reccomended
26.75 245/35/20 Discount Tire Reccomended
27.03 255/35/20
27.72 245/40/20
28.68 245/45/20 HUGE
SOLD
NO MORE Accord
