At what mileage should I expect MM to show its time to change CVT fluid? - Drive Accord Honda Forums
 12Likes
post #1 of 35 Old 12-31-2016, 04:30 AM Thread Starter
I have a 2014 Accord with the CVT. No harsh driving. It has 33k miles on it now and I basically follow the maintenance minder. At 16k miles..the Honda service tech recommended that I change the transmission fluid. I declined since the maintenance minder only asked for an oil change. At 30k miles..said thing. Now the dealership is sending me a notice indicating that they are recommending that I change the transmission fluid. It's not that expensive. I think $100 or so and I dont want to be too late. At what mileage should I expect the maintenance minder to show that its time for me to change the transmission fluid? Should I just have them change it now?
elastin is offline
The Following User Says Thank You to elastin For This Useful Post:
versedispersed (12-31-2016)
post #2 of 35 Old 12-31-2016, 05:11 AM
I changed mine at around 50k and it didn't show up on the MM until 60k
-2014 Accord Sport
notfast is offline
The Following User Says Thank You to notfast For This Useful Post:
post #3 of 35 Old 12-31-2016, 05:31 AM
mine at 40k... Looked like maple syrup at that point. Dont know if that means anything really, though.
It is easier than the oil, since there is no filter. Just drain and fill....
But $100 isnt too bad, I think 4 quarts runs $40 or so ...
Justanotherguy is offline
The Following User Says Thank You to Justanotherguy For This Useful Post:
post #4 of 35 Old 12-31-2016, 07:34 AM
Cruisin'
versedispersed's Avatar
I was wondering when the MM came on for the trans as well.
Thanksguys!
'15 EX Sedan 2.4 CVT
Performance:
aFe TBS, InJen CAI, RV6 PCD
Flowmaster HP2 Res, Custom AxleBack w/ 2x Magnaflow 11225
Wheels
TSW Interlagos 17x8 35mm
LQQKs/Protection:
HID 8K, Int/Ext LED's
Tint: F 35% | R 25%
Audio:
Metra 99-7804B Rev.2, Kenwood DDX9902s
JL Audio HD1200, Hertz HCP4
Audio Control LCQ-1 w/ Sub Level
Scosche Wiring, Pioneer TS-D1730C (Tweets & Comps)
2 Pioneer 6x9, 2 Phoenix Gold SX12D4
Ghetto Fab:
Foam between the rear deck & back window = Bye Rattle!
versedispersed is offline
post #5 of 35 Old 12-31-2016, 09:32 AM
I'm almost at 50,000 miles on my LX, still not popped up on MM, yet! Not going to change it early, as I have a "Lifetime warranty" on the transmission...thought it was prudent to have since it's a relatively new transmission setup. And, Honda hasn't exactly had a great reputation for transmissions the past 15 years. I had one they had to replace at 2500 miles back in the late 90's, and they've had some other glitches with certain gears needing more cooling spray (Odyssey, maybe others?).
"Synthetic" is a marketing term, not a scientifically significant definition.
Blackheart is offline
post #6 of 35 Old 12-31-2016, 09:40 AM
ШОС Лукашенко!
ThatsABigOne's Avatar
I did 3x drain and fill at 89k miles with Castrol CVT fluid. 12 quarts of fluid for roughly 75 bucks. Castrol CVT fluid meets and exceeds Honda specs for a third of a price of a Honda fluid. The transmission is silky smooth after 3x drain and fill.
MackDaddy likes this.
2013 Accord Sport BRP
-V6 front sway bar, Progress 22mm rear sway bar
-TEIN Street Advance coilovers + EDFC
-Acura 4G TL HID retrofit with Morimoto XB35 5500k bulbs
-Evo X GSR wheels, Continental DW tires (245/40R18)
-RV6 Downipe, Magnaflow 10436 resonator
-Ralco RZ under drive pulley
-Turbogixxer e-tune
-Polk Audio db651/db6501 speakers and Rockford Fosgate P300-10 sub.
-Full upper grille block
ThatsABigOne is offline
The Following User Says Thank You to ThatsABigOne For This Useful Post:
Blackheart (12-31-2016)
post #7 of 35 Old 01-04-2017, 10:33 AM
NesOne's Avatar
45K, is when I got mine, and you can check my signature to see the pattern of when else it will come up.
'13 Accord EX-L Sedan I4 CVT - 170,000 miles so far
Oil Change - 10K, 19.8K, 29K, 39.8K, 50.6K, 61.3K, 72.1K, 83.7K, 95.3K, 107K
Transmission Fluid - 51.1K, 107K, 151K
Headlights - Left; 98K Right; 102K
Alternator Belt - 150K
Auto Tensioner Assembly - 120K
FOB Battery - 2.5 years
Car Battery - 123K (went from 51R to Walmart 35S)
Coolant Drain and Flush - 140K
Alternator (pulley went bad) - 162K
NesOne is offline
post #8 of 35 Old 01-04-2017, 07:34 PM
Don't change it until MM, the dealer will not override the system to reset. Therefore the light will come on shortly after, because car doesn't know it was serviced. Honda corporate was the one who had told me not to, and if dealer recommend ask them why. It's on their website, about being OK with color, and scent.
SHADOWofDEATHx3 is offline
post #9 of 35 Old 01-05-2017, 06:04 AM
2015 Accord Touring I4
08EX-L's Avatar
Honda was notorious for having an extended amount of time within transmission changes.... for those of us who remember replacing the Z1 ATF fluid we did it VERY often... why? Cause Honda auto trannies can be time bombs.
I have already changed my CVT fluid and I have 25k on the car.. I plan on doing it every 40-50k.. cheap insurance on the CVT.
mobiless2 likes this.
2015 Honda Accord Sedan Touring NAVI I4 CVT White Orchard Pearl
2011 Toyota Venza Premium V6 AWD 6AT Blizzard Pearl
2008 Honda Accord Sedan EX-L I4 5MT Nighthawk Black Pearl (Traded)
2005 Acura TSX I4 5AT Premium White Pearl (Sold)
2002 Honda Civic Coupe SiG Veloz I4 5MT Nighthawk Black Pearl (Traded)
08EX-L is offline
post #10 of 35 Old 01-05-2017, 04:43 PM
Hi, For those who have changed the CVT transmission fluid on your Honda Accord I4 CVT Automatic, I would like to know what did you do to reset the Maintenance Minder (code 03) after replacing the CVT transmission fluid. I have tried but could not reset the Maintenance Minder after I changed the CVT fluid on my 2013 Accord I4 EX-L. Please advise and thank you.
vnguyen is offline
post #11 of 35 Old 01-05-2017, 06:31 PM
BRWNFLSH now
I'm sure there will be different opinions, but if you are going to change the transmission fluid, before the Maintenance Minder code comes up, do not reset it. You cannot reset the MM just for transmission fluid change, so you would be resetting it for everything that next code would include.
I will see how it goes, but at this point I don't plan to follow the MM for oil changes or transmission fluid, so I will keep track of those in some other way.
92 EX Sedan auto (RWB) - sold after 12 years (140k miles)
16 EX I4 CVT (KCM) with sensing - 4500 miles so far
BLCKFLSH is offline
post #12 of 35 Old 01-06-2017, 04:23 AM
08EX-L's Avatar
Took the dealer 5 mins to reset it using the Honda diagnostic tool. We can't reset specific maintenance our self only the dealer can.
08EX-L is offline
post #13 of 35 Old 01-06-2017, 08:06 AM
ypsibird's Avatar
I'm sure everyone is understanding that you're changing the fluid before the code 03 comes up on the maintenance miner display.
If the code is showing on the MM it can be easily reset with the standard reset procedure in the owner's manual. Of course for people that change the CVT fluid before the code 03 shows they'll just have to make note of their mileage for the fluid changes and when the 03 naturally occurs the standard reset in the manual will apply to them. Seems pretty simple.
2006 Accord Coupe silver V6 6-speed
2003 Accord Coupe silver V6 auto
ypsibird is offline
post #14 of 35 Old 01-06-2017, 01:12 PM
Hi ypsibird, The code 03 was displayed on my car Maintenance Minder when it's odometer shown 46,xxx miles and before I changed the CVT transmission fluid. However, I could not reset the MM. I looked through the car manual but could not find the procedure on how to reset it. I hope that you don't mind to share with me on how to reset it or where can I find the reset procedure in the owner's manual. Your help or suggestions would be much appreciated!
vnguyen is offline
post #15 of 35 Old 01-06-2017, 01:23 PM
BRWNFLSH now
I suggest signing up on Honda owner's link, so you can access the owner's manual on the website. It has a lot more information than the paper owner's manual. The instructions for resetting the maintenance minder are on page 136, in my 2016 Accord (paper) owner's manual.
BLCKFLSH is offline
