K&N 33-2499 stock air filter replacement gas consumtion - Drive Accord Honda Forums
 9Likes
post #1 of 31 Old 04-19-2017, 02:08 AM Thread Starter
raheel's Avatar
Red face K&N 33-2499 stock air filter replacement gas consumtion
good day
i recently installed the K&N 33-2499 air filter for my accord v6, it was a straight replacement
performance wise there was a bit quick reaction on throttle in sports mode but i had the opportunity to test it on highway on a 3500 km drive
earlier i had some long drives on stock filter and i got to a point where i was getting 6.5 litre per 100 km, it got as low as 6.2 litres per 100 km at the speed of 120km/h. Miles per gallon 37,94
after K&N filter install the gas consumption increased, during my first part of drive on K&N filter i got 8.2 litres per 100 km at the speed of 120km/h, i tried different speed for every hour ranging from 110 km/h to 125 km/h and i cant get below 8.2 litres per 100 km on K&N. Miles per gallon 28,68
when i switched back to stock original filter the mileage turns back to as low as 6.2 litre per 100 km. Miles per gallon 36,19
right now i am using the stock filter due to better mileage but the whole 3500 km trip was completed in 4 gas tanks with a maximum fill of 58 litres once
its a pretty good mileage for most of people here for a v6 engine and all this was done without the economy mode, but now within city i'm using the stock filter, i have seen people saying this filter increase mileage but i didn't find it so, but it definitely change the car pick and sound a little on sports mode
so for better mileage in city and highway i am back to the stock air filter
Accord Coupe 2016 V6 AT - Navigation and Honda Sense
Accord Sedan 2007 V6 AT
raheel is offline
post #2 of 31 Old 04-19-2017, 03:01 AM
What brand is your stock filter? If it's a cheapo from ebay, it could be resisting air flow. I had that issue. Once I bought a good paper filter, I could tell that the engine is breathing with ease. K&N made no difference. It's currently laying on the shelf waiting to be thrown out.
2005 Honda Accord V6 LX - 168k
salcuta is online now
post #3 of 31 Old 04-19-2017, 03:08 AM Thread Starter
raheel's Avatar
stock filter is OEM filter 17220-5G0-A00
but the K&N air filter is very light and thin compared to OEM, and what do you mean by resisting airflow , is this mpg not good on highway
raheel is offline
post #4 of 31 Old 04-19-2017, 03:17 AM
I mean the engine didn't have the same amount of power at low speeds. When going home and turning towards a small incline, I could always tell that something's off. You know that feeling, breathing through a straw? After I replaced it, all was good again and the engine was happy.
You know K&N lets in more dirt, right?
The Following User Says Thank You to salcuta For This Useful Post:
raheel (04-19-2017)
post #5 of 31 Old 04-19-2017, 03:21 AM Thread Starter
raheel's Avatar
yes i found that because i had a sandstorm on my way, that was the main reason i immediately swapped back
they cant hold back tiny dirt and sand , i did the oil change after that asap
thanks for confirming this, i was curious that this was my feeling only
raheel is offline
post #6 of 31 Old 04-19-2017, 03:50 AM
Baldeagle's Avatar
Originally Posted by raheel View Post
good day
Im sorry, but there is absolutely no way possible an air filter will change highway fuel economy from 38 mpg to 29 mpg, all else equal. Something else is at work.
The science behind this regards pumping losses how much work does it take for the engine to suck air into the engine/cylinder. As you routinely accelerate around town, a mesh filter might improve fuel economy by a tiny fraction because the engine breathes easier. On the highway there should be zero difference. Running with a dirty air filter or a no air filter, highway fuel economy should be essentially the same. The computer and it sensors will equal everything out.
Baldeagle is offline
post #7 of 31 Old 04-19-2017, 03:56 AM Thread Starter
raheel's Avatar
The science behind this ............
if i knew the science i wouldn't be posting here, this all calculation was done on highway, i used k&N for first 1500 km and later switched back to OEM Element all at the speed ranging between 110 km/h to 125 km/h
raheel is offline
post #8 of 31 Old 04-19-2017, 04:28 AM
Baldeagle's Avatar
I'm not arguing that your mileage did not change. If your calculations show they did, I'm sure they did. I'm just saying that much of change was not the result of any air filter. Something other than the air filter caused that change.
raheel and calgary_6_6 like this.
post #9 of 31 Old 04-19-2017, 04:33 AM Thread Starter
raheel's Avatar
I'm not arguing that your mileage did not change......
Dude chill, i'm not saying you are arguing, i dont know but this is what happened and i m trying to know why, all other constraints were same except the filter
raheel is offline
post #10 of 31 Old 04-19-2017, 05:04 AM
You are correct. Interesting reading:
http://www.fueleconomy.gov/feg/pdfs/...02_26_2009.pdf
2013 Sedan EX-L V6 with Nav, 6 speed Auto trans.
cookieman214 is offline
post #11 of 31 Old 04-19-2017, 05:33 AM
V6 6MT CBP
200366HFP's Avatar
So you are saying the wind direction and speed were exactly the same? I see a 3-5mpg difference with a tail wind vs. head wind.
So you are saying the temperature was exactly the same? I see as much as 5mpg difference with temperature changes.
So you are saying you drove at exactly the same speed? I see a 3-4mpg difference depending on how fast I drive.
2003 I4-AT LX Sedan (Girls car)
2003 V6-6MT HFP Coupe (Now the boys car)
2015 V6-6MT Coupe
200366HFP is offline
post #12 of 31 Old 04-19-2017, 05:39 AM
Baldeagle's Avatar
LOL. We may have a language difference. “Arguing” not as in angry. “Arguing” as in to state the rational that supports my point of view. A line of logic or evidence, like in a debate. Trust me, I’m not angry. I'm just trying to help you. With 100% certainty, I can tell you the other constraints were not the same. Something other than the air-filter changed your fuel economy. "What" is the question.
raheel likes this.
post #13 of 31 Old 04-19-2017, 05:43 AM
As long as you two don't start arguing in caps
SimplyStevo likes this.
post #14 of 31 Old 04-19-2017, 05:54 AM
Your Maintenance Minder
I'd just settle for simple English that I- a graduate of the public school system, can understand!
OP, I do not understand your method of fuel consumption calculation. HOW EXACTLY are you calculating mpg? (or kilometers per gallon)
Side note: When my brother first joined the US Air Force he was a Navigator/EWO in a B-52 bomber. The bomber had nukes (Strategic Air Command base in Minot, ND) and they would need 2x the runway length to take off in hot Guam as they would in Minot during wintertime. That is how cold air can affect nuking every living thing on earth.
RickBlaine is offline
post #15 of 31 Old 04-19-2017, 06:11 AM
Is this the K&N filter that must be oiled before use? The oiling part of this can be tricky: too little and the filter's efficiency is compromised, too much and excess oil can contaminate the air flow monitor and other things downstream. I agree it seems unlikely a filter by itself changed fuel economy that much, but excess oil deposited in engine management sensors can do all kind of odd things.
HondaBob likes this.
Dans15 is offline
