Navi screen issue - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > the 9th Generation
Old 01-16-2013, 10:46 AM
Maxamus1975 Maxamus1975 is offline
Navi screen issue
I brought my 2013 EX-L V6 Accord in November 2012. I love the car but recently I noticed a white hazy strip on the top of the screen. If I change to audio or phone the entire screen is clear. I will post pics from home. It should be covered under the warranty but I was curious if anyone has seen this happen yet.
Regards,
Max
Old 01-16-2013, 12:56 PM
ssmtsx ssmtsx is offline
Send a message via AIM to ssmtsx
Do you have it on 3D view? I switched mine to 3D last night and noticed the same thing. It looks like it supposed to be clouds in the sky. I have seen it on Mercedes before. I switched back to the heading up display.
Old 01-16-2013, 02:25 PM
WDMaccord WDMaccord is online now
Yes, if you are in 3D mode, you can tilt the screen down a little further and you will see blue sky with the clouds. I think I have mine set on 6 and I get about 1 inch of blue sky and clouds.
Current:
2013 EX-L V6 w/ Navi Sedan Black/Ivory
2003 EX-L V6 Sedan Black/Tan
2008 CRV EX AWD Black/Black
Previous:
1999 EX-L 4 Cyl. Sedan
1997 EX-L V6
Old 01-17-2013, 08:14 AM
I think I do have it set for 3D view. That sounds like my problem. I will switch it back at lunch and report back. Thank you for replying.
Regards,
Max
Old 01-17-2013, 10:08 AM
When I change it to the heads up display the "clouds" went away. I changed it back to the 3D view and tilted the angle a little and the "clouds" are gone as well. Again, thank you for your help.
Max
Old 01-17-2013, 10:15 AM
Dreamacre's Avatar
Dreamacre Dreamacre is offline
7th Gear
I hope they aren't rain clouds. Your interior will get wet.
- It is just a car -
2005 Accord Sedan EX-L AT
2009 Accord Coupe 6/6 Black
Old 01-17-2013, 10:40 AM
Ha. That wouldn't be good for the leather. So it turned out to be a "feature" and not a problem. Thanks Honda
Max
