What is the proper torque amount for the lugs?
2013 Honda Accord Sport |
^^^^^Double check the manual but people here report 80 ft lbs is listed in the manual. German cars I have owned call for 90-110.
Ex-L White Pearl/Ivory Honda factory LED Touring Headlight, 3M Di-NOC Bubinga wood vinyl dash trim, Horn Upgrade, LED interior, trunk, license, Splash Guards |
80 ftlbs
Honda does lower than most alloys.. maybe softer alloy? But its 80 Last edited by draken187; 01-29-2013 at 09:18 AM. Reason: added explanation |
I think because some German cars uses bolts rather than lug nuts. I know my sister's 3-series says 120 ft/lb of torque.
Just checked my cold tire pressures. All 4 were over, but not by much. 4 psi at the most. Adjusted and recalibrated the TPMS.
'13 Sport sedan w/ CVT Stock as F#%K!!! |
Does the LX have a TMPS button? I through it was done through the screen display.
in manual...left of steering wheel under dash near door...
'13 EX-L I4 COUPE STEEL/BLK Click here for pics New Accord? Click here for a good PDF detail procedure Other car: `13 Camaro 6.2L 2SS |
I made SURE THAT i GRABBED MY k&n AIR FILTER AND ALL WEATHER FLOR MATS. I also had splash guards but to my surprise, my new car had some on them.
Mine were at 35. I put them at 33/32 and I did not like the handling. I then decided to put them at 34. I might try 33 all (Sport).
Mine was spot on when I picked up my car, but I always check again after a few days of getting any tire servicing done since they don't always compensate for the cold weather when filling up the tires. On previous cars, I've always ran them 4-6 psi higher than the recommended pressure, but on this one, I won't go over 35 psi. The ride gets noticeably bouncier above that and it doesn't improve gas mileage or handling at higher pressures. OEM Goodyear
2013 Accord EX-L Navi 5,058 miles and counting... YTD avg mpg = 29.58 . . . . Last tank mpg = 30.30 2005 Accord EX-V6 Sedan (3/05-1/13) retired at 127,110 miles 1993 Accord 10th Anniversary Edition Sedan (5/08-7/10) Retired at 153,007 miles 2000 Civic Si (5/00-3/3/05) Retired at 59,500 miles |
Full tank gas
4 floor mats Tire pressure and lugnuts Inspect car, walk around look at paint for any blemishes, etc Open hood, trunk for inspection Check mileage (5-10 miles typ) Make sure VIN matches paperwork (I've had them mismatch before!) Check glove box for unusual items (someone here reported drain plugs in their's) |
Excellent advice. I also check after I take her in to the the dealership. We have some old school mechanics here that stick every tire for every car at 32psi. Drives me nuts.
2013 'Hemie' Accord Touring V6 - Canadian |
Grabbed my filtermagnet off the oil filter too. Been using the same one for years.
New owners check your tire pressure?
To all new owners check your tire pressure found 40 PSI in mine. FYI V6 coupe is 33 front 32 rear. Then recalibrate TPMS car rides better now. Drove it a 100 miles then I decided to check the pressure. You would think the dealer would check this?
