Honda Accord Engine vs. VTEC - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > General Drive
Old 04-20-2009, 09:30 AM
UGCRiDeR's Avatar
UGCRiDeR UGCRiDeR is offline
i have a 2001 Honda Accord DX. and i was wondering what is the difference between a regular engine and the VTEC engine???
2001 Honda Accord, 4dr Sedan 2.3 DX
Old 04-20-2009, 03:11 PM
Accordriver's Avatar
Accordriver Accordriver is offline
Variable valve timing.. aka VTEC, lol
http://www.youtube.com/watch?v=AcT_ZyY3F0k
-03 Honda Accord EX V6
-Debadged-17mm sway bar-UR crank pulley-AEM CAI
Old 04-20-2009, 04:35 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Roughly 15hp.
Different cylinder heads to be sure, not sure if the blocks are different. Could be, as the B series without vtec vs ones with are different with special oil feeds in the block to get to the vtec solenoid on the head.
Sapphire blue '04 V6 6 speed w/ full HFP, comptech ss, momo shadow, TL-S 27.2h/20 bars, intake spacer, retro chrome MH1 HIR2 highs, hella DE fogs, EBC Ultimax, subwoofer/amp, infinity rears, HD Radio, aux adapter, navi conversion.
Vermilion 1999 SVT F150 Lightning, Sylvania/Visteon Xenarc HID headlamps, '01 L turn/marker lamps, PIAA fogs, '01 up Bilstein shocks, all Pioneer speakers, Clarion subwoofer. All Redline fluids.
Silverstone 2003 Honda S2000, bone stock
Old 04-20-2009, 04:54 PM
Aarmin's Avatar
Aarmin Aarmin is offline
I believe your '01 Accord has VTEC?
As multi-valve technology has became the standard in modern engines, so will/has variable valve timing. VTEC is Honda's very own type of system. Just about every manufacture has there version these days.
With the timing of the intake/exhaust valves power and torque can be optimized accross the rev range.
One of the most notable is Fiat's Barchetta coupe, some 90% of its peak torque is available from approximately 2,000rpm to 6,000rpm, and this is on a naturally aspired (not turbod or supercharged) 1.8- liter engine! It also makes a noticeably interesting sound when it fails
Old 04-20-2009, 09:55 PM
Tuolumne Tuolumne is offline
banned
1) I believe the DX model did not come with variable valve timing
2) peak torque on the V6 is at nearly 5,000RPM - Honda makes screamers
Old 04-20-2009, 10:09 PM
Accordlover's Avatar
Accordlover Accordlover is offline
banned
Send a message via AIM to Accordlover
The DX and VP did not come with VTEC engines.
To be honest with you, the non VTEC 2.3 feels more powerful around town at lower speeds than the VTEC variant. I believe this is due the the VTEC motor requiring more RPM to do it's magic, where the non VTEC has more Tq lower in the RPM range.
I could be wrong. I am going off of comparing my 99 Accord (VTEC) to my 96 Accord (F22B2 Non VTEC) and a 01 Accord VP (non VTEC) that I have driven back to back.
Old 04-21-2009, 09:45 AM
UGCRiDeR's Avatar
ah thanks cause one of my buddies asked me and i wasn't sure.. but thanks andrew
Old 04-21-2009, 12:53 PM
foamypirate foamypirate is offline
Sounds like nothing a K20/K24 can't do to me...
They both make 90% of peak torque in about that same range.
Old 04-23-2009, 08:24 PM
Aarmin's Avatar
I've never heard of a Honda valvetrain system failing before
I guess it can be with Honda's expertise and cam phasing.
Old 04-23-2009, 08:46 PM
Well, I was more or less referring to just to 90% of peak torque-blah-blah-blah...
But I have seen some interesting Honda motor failures in my time.
Title goes here
close
video goes here
description goes here. Read Full Story
