Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > The Early Generations
Google
Thread Tools Rate Thread Display Modes
Old 11-04-2009, 02:46 PM
sonnyk88 sonnyk88 is offline
96 Accord 4Cyl. hard to start sometimes
My 96 Accord somtimes is very hard to start, but once it started, the car run smoothly. Is the problem with the distributor? Also, I got CYP check engine, but it can be reseted if the car lucky started without hestitate. I already changed the new spark plugs and wires.
Anyone have any idea what wrong with it.
Thanks,
Drive Accord
Old 11-05-2009, 08:53 AM
wardenr's Avatar
wardenr wardenr is offline
Robert Warden
Thanks,
You don't state the MILEAGE on the car...or what other work you've had done to it.
While it MIGHT be an electrical issue...such as a defective distributor or faulty MSR (Main System Relay), I think your problem(s) are otherwise.
Condition of the FUEL system? Injectors? Fuel pump? Has the fuel FILTER ever been changed?
Eternal Keeper of the HONDA Faith...
1986 Accord Hatchback, LX-i, 5-speed, Misty Beige Metallic over Silky Red (216K miles)
2002 Accord Coupe, LX, V6, Satin Silver Metallic over Charcoal (83K miles)
Registered member with the American Honda Owners' Association
Old 11-13-2009, 02:14 PM
The car has 245k, I have not change the fuel filter. If the car run fine once it has started, can I assume the distributor is good ?
Thanks,
Old 11-15-2009, 08:38 AM
rafael73's Avatar
rafael73 rafael73 is offline
Too old to tolarate
long shot question. i will try with a simple tune-up: change the distributor and the plugs. Then go for the fuel filter. Maybe that will help.
Current:
09 Pilot EX-L w/ RES Sterling Grey Metallic 2WD
06 Accord EX-L V6 6MT 4DR Alabaster Silver, OEM Fog Lamps w Nokya Yellow 2500K bulbs, OEM Splash Guards, OEM Multimedia Player, TL Switchblade Key, 9006 Phillips Crystal Vision, 9005 Nokya Yellow 2500K bulbs
Gone, not forgotten...
04 Odyssey EX-L w/ RES
03 Accord EX AT
04 Odyssey LX
04 Accord LX
97 Accord LX
94 Civic DX 5MT (Head swapped for Z6)
92 Acura RS
79 Accord Hondamatic Tranny (P-R-N-2-1)
Thread Tools
  Friends of Drive Accord
Throwdown Performance
Retro-Solutions
TV and NAV 2 Go
Diode Dynamics
Accord Mania
XenonDepot Lunarpages.com Web Hosting
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© Copyright 2002-2009 Wardsweb, LLC. All Rights Reserved.
