Thread Tools | Rate Thread | Display Modes |
the white wire is 12v and red wire is to turn on the light of ur switch, tap to cigarette...
2009 Honda Accord EX-L I4 Coupe Current List of Modiification * OEM Fog Lights * OEM V6 Deck Lip Spoiler * OEM Painted Splash Guard * OEM Trunk Tray * Painted Front Lower Grille * (2)10"&(2)6x9" Neon Lights * 15" neon light trunk * No DRLs * 35% Tint Window * H&R Springs F 1.5/ R 1.3 * 20x8 SSC 45 offset (need tires) Alaska Ocean http://www.youtube.com/watch?v=UuFlNIU2TeE www.cardomain.com/id/noypi_21_neon |
I was able to hook up ebay fogs just fine. I hooked em up oem style and everything worked. I did one trick for the engine bay fuse box. It had 3 wires connected: wht, red, and red/blue wire. I hooked up the red/blue wire to the + battery terminal on the fuse box, left the wht wire alone(in other words wrapped it with tape so its not used), and hooked up the red wire to an open slot in my fuse box in the drivers side cabin fuse box and put in a 15amp fuse. Now my fogs turn on without needing the headlights on. They also turn off when the car is off. Also switch still works. Love the mod and even did it for a friends accord as well.
So just out of curiousity, does the aftermarket harness have to be fished through the firewall? Or does one end hook up to the interior OEM plug that feeds through already, and you just plug the other one into the oem plug that is already in the engine bay?
Thanks
2006 Accord EXL-V6 Auto 4dr + Desert Mist + MODS: Nokya Hyper Yellow drl/highs, JBL GTO 6x9's and tweeters, splash guards, Honda all-weather floormats, trunk tray, hood bra.... More to come = Sexy |
that's probably gonna be my next problem lol |
sorry for my ignorance |
u need this one ...
I rewired mine but it was a Pain ** it took me forever to figure-out how it was supposed to be wired. I basically connected straight from the battery and split the wires more than twice and connect them to the relay and the inside switch ( by the way that is a cheap looking switch, is not even a month since I installed this and is already pealing off) but one thing that is good about the aftermarket foglights is that they illuminate whiter and better
2006 Honda Accord EX-L V6 mods done: -white interior lights, stage II wishlist: -tint 35% all around -18" rims (verde protocol) -rear lip any other suggestions are open |
2006 Accord EX-L V6 Black on Black Tints 17" FAST Rims Smoked tail lights Coming soon........ Halo Projecter Headlights(black) GrillCraft® Sport Mesh Grille(black) Interior LED's in red USA SPEC i-pod interface Decklip spoiler |
Just wanna seriously thanks coolblue07 here.
he helped me out so much |
| Thread Tools | |
