Old 11-07-2009, 04:50 AM
mazdahead mazdahead is offline
I have a buzz
Quick back ground, I have an 04 LX sedan, 2.4l, 5MT with ~133k miles. I noticed a couple of weeks ago that as I start off in first gear, I hear a buzz. I am having a hard time determining exactly where it's coming from, but if I had to guess I would say it is either under the driver seat area or under the dash. I initially thought exhaust as I know Honda's in general atleast used to have a buzzing problem and offered exhaust buzz kits, but I am not toatally convinced that my issue is exhaust related.
Driving around a little last night, I noticed it's not just at starting from a stop, but it occurred as rpms increased and was most noticable at about 1200 or 1300 rpms. In any gear if I coasted down to 1.2 or 1.3k I hear it in any gear. I plan to get under the car today to see if there is anything obviouslly loose, but I wanted to see if anyone else has had this issue or if anyone had any ideas where to start looking. Could this be motor or tranny mount related?
Thanks for your help.
Old 11-07-2009, 07:15 AM
ATR ATR is offline
does it happen from 1200-1300rpm ALL the time or only when the car is warm?
Old 11-07-2009, 07:49 AM
At the mileage, age of the car, and location you are at, it's possible one of the heatshield attachment/bolt point maybe causing this.
Unless you are sure it comes from inside of the car, then disregard above.
4,300K DDM slim-line HID conversion, TL shift knob, Hidden Hitch,
2007 Acura TL-S front/rear sway bars.
Acura TL 5-spoke rims and 235/45-17 Bridgestone Pole Position RE960 tires for summer
Honda steel rims and 225/55-16 Michelin Alpin PA2 tires for winter
Old 11-07-2009, 07:53 AM
namegoeshere's Avatar
namegoeshere namegoeshere is offline
psychic
I have a buzz too
2006 Accord SE Sedan - I4 - auto - Alabastard Silver
Best MPG (so far) = 35.67
Please read --> Forum Rules - Classified Rules
Old 11-07-2009, 10:26 AM
the grey quincy's Avatar
the grey quincy the grey quincy is offline
Prim and Proper
This is what I was thinking
Old 11-07-2009, 11:01 AM
Originally Posted by namegoeshere View Post
I have a buzz too
Going to get a stiff drink so I can have one too.
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
