![]() Both my Accords run without screws now. I don't even waste my time with impact drivers trying to remove, Those puppys are blown out of there with a left handed drill. This procedure only happens once . But that is my opinion![]() I1
08 EXL V6 W/Nav PMM @ 35K miles My daily driver 08 Pilot EX-L Dark Cherry Pearl @ 10K miles The Mrs. daily driver 02 EXV6 Naples Gold @197K (Trans replacement @156K) The snow mobile(waiting for that next snow) DA RULES ! |
Being the anal-retentive, perfectionist "Inga-Neer," I use OEM Honda rotors, WITH their screws. #2 Phillips bit on my impact driver facilitates ease of removal/reinstallation.
Eternal Keeper of the HONDA Faith... ************************************************** ************** 1986 Accord Hatchback, LX-i, 5-speed, Misty Beige Metallic over Silky Red (216K miles) 2002 Accord Coupe, LX, V6, Satin Silver Metallic over Charcoal (83K miles) Registered member with the American Honda Owners' Association |
< ---- hand tightened, hand loosend. both work just as well and have for over 50k miles already.
2000 2dr. v6 Accord | Limo Tint | R1 Concept slotted/ventilated rotors - Front | Eibach Pro Springs | KYB-GR2 Shocks | Eibach Sway Bars | Pioneer DEH-P6000UB | Pioneer component speakers | Kenwood 4ch. 800w Amp | 2x 10" Sony Xplod 800w subs | Sony 1200w Class D Amp
I replaced all four wheels pads and had the rotors turned at a local repair shop when the car had about 40,000 miles. The after market pads were quiet, smooth and lasted until I replaced the front pads from the Honda dealer at about 93,000 miles. Those pads have been quiet, smooth and also work well. The cost between the two per wheel was within a couple of dollars of each other. The next time I need brakes I will take them to the dealer because the cost was about the same and it's easier to complain to Honda when something doesn't go right.
2000 Accord Coupe V6 Milano Red 118,000 miles and still counting! |
I got the shipment. The rotors have the hole for the screw...
Now I get to wait till I ware down what I have...
Bruce - AC6DN: Honda Accord, 2001, 2.3L (L4), F23A4, 4D EX - My main car… Ford Taurus, 1992, 3.8L V6, - Trany prob's Toyota 4x4 Extra Cab Truck, 2.4L SR5, 22RTE (Turbo) 1987, I still have. Honda Accord, 1984, 1800cc? L4, Plymouth Arrow, 1978?, 1800cc?, L4 (POS) Chevy, Monza, 1976, 350cu, V8, My funnest car, think muscle car, poorly made... Olds Starfire? 1975, 231cu odd fire, V6, My first car, 1965 Chevy Impala 283cu V8, (I got during the mid 1980) |
You're both right!
There are two schools of thought here. One says that OEMs spend millions to optimize the corners of a car for NVH, feel, performance, and durability. School One says don't mess with that optimization and stick with OEM. School Two says, "Yeah, but what if their optimization isn't MY optimization? What if I'll take a little more noise and dust if I can get a lot more fade resistance?" If you weigh the performance factors differently, aftermarket makes a good case for itself.
"Communication isn't what you say. It's what they hear." - Red Auerbach When everyone's home: 2007 SE I4 5AT, Cool Blue, 28k 2007 Civic EX-Navi, Galaxy Gray, 30k 2006 Acura TL 6MT-Navi, 32k 2004 EX I4 5MT, Desert Mist, 75k 1993 Volvo 940 Turbo Wagon, Blue Green, 227k Gone but not forgotten: 2001 Accord EX I4 5MT, Satin Silver, oil slick at 86K 1999 EX-LV, Heather Mist, sold at 146,567 1994 Accord LX I4 5 MT ABS, Malachite Green, traded at 285k |
The pad I'm using are the latest design, FM1000. The rotors are black e-coated to prevent rust; Possibly radiating more heat, from being black, and from not being rusted. Their not the longest lasting (necessary), nor the lower cost best choose (likely what Honda would have chosen). I'm looking for better than OEM, but not crazy expensive. This time I'm replacing in even more hardware, than last time (boots, slider-bolts, clips, etc). So hopefully their be even more quieter that the GS-6 pads were (normally herd noises, was pads shifting around sometimes)... FM-1000: http://www.brembo.com/US/Performance...05sportpad.htm
I assume it's like the GS-6 pads I currently have. Their (both) about the same as OEM at cold, and slightly better once worm. And get even better when HOT. FG is what the GS-6 pad were, as well as these are. I suspect that the OEM is EE. I asked TR, if they were good cold, they said they were. They seem to have more brass looking strips, and looks more black (the pads), while the GS-6 has more of a shinny metal (blackish) look. Both are a composite pads, Semi- metallic, and Carbon or Carbon-Ceramic...
GS-6 (0.38-0.42 at 700F): http://www.tirerack.com/brakes/brake...ar=&perfCode=S Brembo Sport (0.45-0.55 at 600F): http://www.tirerack.com/brakes/brake...ar=&perfCode=A SAE Practice J661 and J688 testing procedure (FF, FG etc) Above temperature's are rounding typo's, as it's really 650F): http://www.brakeandfrontend.com/Arti...dge_codes.aspx
Bruce - AC6DN: Honda Accord, 2001, 2.3L (L4), F23A4, 4D EX - My main car… Ford Taurus, 1992, 3.8L V6, - Trany prob's Toyota 4x4 Extra Cab Truck, 2.4L SR5, 22RTE (Turbo) 1987, I still have. Honda Accord, 1984, 1800cc? L4, Plymouth Arrow, 1978?, 1800cc?, L4 (POS) Chevy, Monza, 1976, 350cu, V8, My funnest car, think muscle car, poorly made... Olds Starfire? 1975, 231cu odd fire, V6, My first car, 1965 Chevy Impala 283cu V8, (I got during the mid 1980) Last edited by Bruce Hawkins; 11-10-2009 at 08:43 PM. Reason: More info, brakes likely are EE.. |
The GS-6's didn't make any noises usually (Some minor "brake grunt" (low frequency noise, at less-than 2 MPH, sometimes) - a non issue), no vibrations, or Harshness - Not sure what harshness means...
| Thread Tools | |
