Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Fluid Dynamics
Google
Thread Tools Rate Thread Display Modes
Old 10-03-2009, 07:23 PM
berg's Avatar
berg berg is offline
Send a message via Yahoo to berg
Anybody ever use this product???
I saw it and looks pretty good what do you guys think anybody ever use it before???
http://www.skymall.com/shopping/deta...d=102716746&c=
2007 Accord Coupe EX Graphite Pearl aka"Bonita"
28,xxx Miles
Mobil 1 (5w20)
30% Tint
Fujita CAI
TSX Intake Manifold
TL 17mm Rear Sway Bar
Scanguage II
Diode Dynamics stage 2(white)
2008 Element SC
8,xxx miles
Retro Solutions 6000k HID
Drive Accord
Old 10-03-2009, 07:31 PM
Furple's Avatar
Furple Furple is offline
I was looking at one of these buy decided against it. It's not hard to lift the car and drain through the pan. Sure it saves on the mess but I'm not sure how effective it would be at sucking out any particles that are settled in your pan. Using the drain bolt I feel as if anything sitting down there will just flow out, but I could be wrong.
Old 10-03-2009, 07:35 PM
Aviography Aviography is online now
I guess the question is going to be how does anyone know if the dipstick tube allows the pick-up tube from this device to extend all the way down to the bottom of the crankcase of *their* car?
You won't be able to drain, or rather pull, all the old oil out of the crankcase otherwise.
And how does it "save you money" or to ensure that you "know the job is done right"?
It's more like you are making them money by buying it.
I like the concept, but seems there's more marketing hype than the actual value.
4,300K DDM slim-line HID conversion, TL shift knob, Hidden Hitch,
2007 Acura TL-S front/rear sway bars.
Acura TL 5-spoke rims and 235/45-17 Bridgestone Pole Position RE960 tires for summer
Honda steel rims and 225/55-16 Michelin Alpin PA2 tires for winter
Old 10-03-2009, 07:38 PM
berg's Avatar
I'm sure these oil places don't actually wait till last drop of oil comes out do they?
28,xxx Miles
Mobil 1 (5w20)
30% Tint
Fujita CAI
TSX Intake Manifold
Scanguage II
2008 Element SC
8,xxx miles
Old 10-03-2009, 08:01 PM
___ ___ is offline
_____
I highly doubt it. Oil can drain for hours haha; they wouldn't profit as much if they did wait for the last drop. I often don't even wait that long because it just takes too damn long and I need to get going
Old 10-03-2009, 08:03 PM
ry05coupe's Avatar
ry05coupe ry05coupe is offline
snacks on snacks
Aparently all of the mercedes techs use these, or devices similar to these. My stepdad had an 03 slk32 AMG, and he spent forever trying to change his oil before he found that out.
Latest mod: CCFL Trunk Lights.
Old 10-03-2009, 08:07 PM
berg's Avatar
So he uses this item?
28,xxx Miles
Mobil 1 (5w20)
30% Tint
Fujita CAI
TSX Intake Manifold
Scanguage II
2008 Element SC
8,xxx miles
Old 10-03-2009, 08:15 PM
ry05coupe's Avatar
snacks on snacks
He did until he sold the Mercedes.
I've just stuck with the good old fashioned method. It is probably all in my head, but it's nice to know that I'm getting as much oil out as I can.
Old 10-03-2009, 08:22 PM
rszappa1 rszappa1 is offline
it is just too easy to change the oil the old fashion way.....Plus you get a chance to look underneath the car...
Old 11-06-2009, 08:10 PM
dan442 dan442 is offline
It looks like it just connects to the dipstick tube and has nothing actually going to the pan. I know for a fact not all dipstick tubes go to the bottom of the oil pan. How would this get all of the oil out? Maybe this is the way Mercedes does it because the engines were designed to have the oil changed this way.
Old 11-07-2009, 01:11 PM
Why would you want one..... You have to change the oil filter anyway....
Old 11-07-2009, 02:36 PM
Cleankill's Avatar
Cleankill Cleankill is offline
This item is kind of useless for our accord's oil change (debris should sink to the bottom and we should take the advantage of the drain plug)...
but if we can somehow insert the tube into the torque coverter, then i would buy it...!
07' J30A5 Auto 4Dr, 20mm TL-S rear sway bar, Neuspeed front tower bar, Debadged "SE"
Old 11-07-2009, 06:19 PM
berg's Avatar
I agree I changed mine oil the other day the old fashioned way
28,xxx Miles
Mobil 1 (5w20)
30% Tint
Fujita CAI
TSX Intake Manifold
Scanguage II
2008 Element SC
8,xxx miles
Thread Tools
  Friends of Drive Accord
Throwdown Performance
Retro-Solutions
TV and NAV 2 Go
Diode Dynamics
Accord Mania
XenonDepot Lunarpages.com Web Hosting
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© Copyright 2002-2009 Wardsweb, LLC. All Rights Reserved.
