95 Honda Accord Key Will Not Turn - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Main Forums > The Early Generations
Old 02-09-2010, 07:41 PM
ou_chot ou_chot is offline
Greetings,
My 95 4 Door Accord key will not turn when it is in the ignition. Key will not turn to the I position. Other keys have the same problem. Any suggestions?
Thanks!
Old 02-10-2010, 10:02 PM
DSeng13 DSeng13 is offline
98 Accord EX Coupe
First make sure your car is in park. Sounds crazy, but I've seen it happen to people before.
Next, try turning the key and the wheel at the same time. If that doesn't work then I'm not sure. GL
Old 02-11-2010, 08:06 PM
Yep - its in park. I will try turning the wheel and key at the same time.
Old 02-12-2010, 09:51 AM
Dennis's Avatar
Dennis Dennis is offline
banned
uuh steering wheel locked?
Old 04-23-2010, 08:15 PM
ackman's Avatar
ackman ackman is offline
Cruising da Garden State
This happened to me last month. Turns out after I dropped the igition switch on my wife' s car took it to a locksmith and it turn out the keys were worn. You probably need a new set of keys done.
2008 Honda Accord Coupe 6sp EX-L/Nav
OEM HFP Lip Kit
20 x 10.5 Vossen VVS086
Megen Coilovers
AEM Cold Air Intake
HID Headlights & HID Yellow Fogs
Yellow DRL
30% Tints
OEM All Season Mats & Trunk Tray
OEM Door Sills
Comptech Short Shifter
LED Interior Lights & Trunk Lamp
Debadge Trunk
M3 Lip Spoiler
Magnaflow Mufflers
Odessey Grille
Weather Tech Visors
Coming Soon:
Air Ride
http://www.cardomain.com/id/Ackman
Old 05-11-2010, 03:13 PM
Own 2 Accords Own 2 Accords is offline
Or it could be the ignition key column got worn out after many years of use that needs to be replaced.
Old 05-16-2010, 09:52 PM
Jimmyboi808's Avatar
Jimmyboi808 Jimmyboi808 is offline
'85 Accord
um to be technical turn the wheel leftwards while you turn the key because of this wheel locking mechanism. but yeah like ackman said could be the keys..
'85 Honda Accord
4speed Automatic
ES2 85hp
3 Barrel Carburetor
original interior except for CD player
New Silvania Halogens...cant put HIDs...
Want:
New Paint...Interior still Nice
HELLAFLUSH..Deep Dish!
Brakes Fixed...
Rust Removed..
new radiator
AC Swap
Exhaust
Sounds
Old 06-10-2010, 03:32 PM
andrewa82's Avatar
andrewa82 andrewa82 is offline
how many miles u pushin on the 85 accord??? my aunt had a blue 84 LX. i remeber when she bought it
1995 EX 5 speed 221k
2006 TL 6 speed comptech supercharged 69k
Old 06-30-2010, 11:00 PM
*infamous* *infamous* is offline
From my experience at the dealership, the most common reasons were the Interlock mechanism failed (you have ruled this out already), The keys are worn, or the key tumblers inside have worn. Get a new key as suggested already, and if that doesn't work, you may need to have the tumbler assembly either rebuilt or replaced.
Old 07-02-2010, 02:23 AM
HappyGilmoreX HappyGilmoreX is offline
1HGCB7 - 92 H22A Accord
IF your keys are worn you can get new ones by VIN at your local Honda dealership, I ran into this issue with my 92 accord its only 10 bucks!!!
Old 07-17-2010, 05:28 AM
gtaylor318 gtaylor318 is offline
I had the same problem took the car to a locksmith got new keys and haven't had a problem since
