Coolant change for 04 LX, 4 cylinder - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Maintenance & Detailing
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 12-20-2010, 01:40 PM
freeflight freeflight is offline
Hi there,
I am about to change coolant on my 04 Accord LX, 4 cylinder. How many gallons of Honda type 2 coolant do i need?
Thanks,
Kevin
Old 12-20-2010, 01:49 PM
CYANiDE CYANiDE is offline
VTAKKKK
Send a message via AIM to CYANiDE
Capacity is 7.5 quarts according to the Haynes Manual. You should be good with 2 gallons of Honda Coolant.
2006 Accord EX i4 Sedan - 5AT - Graphite Pearl - [89,0xx miles]
FF Type II Coilovers || Skunk2 Front Camber Arms || Ingalls Rear Camber Kit || Acura TL-S 27mm Front/20mm Rear Sway Bars || K&N SRI
Old 12-20-2010, 01:51 PM
Thanks. This is my first DIY project, wish me luck.
Old 12-20-2010, 07:01 PM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
You've got the good wishes. I do hope that is the correct coolant , I assume you have checked that out.....in all honesty I don't know.
Old 12-20-2010, 07:03 PM
CarlR33's Avatar
CarlR33 CarlR33 is offline
Two gallons of type 2. Hopefully your manual is like mine and has the DIY. Drain, fill and run to remove air with cap loose/off, etc. I would have done this in the summer when the engine can get warmer faster and not take as long to do this.
03 Accord LX I4 5spd, 230k miles.
with 19 HFP Wheels and Eibach pro spring kit (second set as the first set of rear springs rusted apart).
Previous car: 98 Civic EX 5sp. with 155K, RIP
Old 12-21-2010, 10:12 AM
VTAKKKK
Correct. Haynes manual has the DIY as well, I wasn't sure if the OP would've needed it. but it says 7.5 quarts which is just under 2 gallons of Type 2.
Old 12-22-2010, 04:43 PM
Thanks. I think the coolant is kind of dark blue color (type 2), but I will ask parts dept when I pick the coolant up.
Old 12-22-2010, 04:44 PM
I downloaded the instruction from this site. Looks fairly simple to me. It doesn't get very cold in So Cal, but I will do it around noon on a warm day.
Old 12-22-2010, 04:46 PM
I am thinking about picking up Haynes manual. As the car ages, more and more DIY opportunities come along.
Old 12-23-2010, 06:49 AM
nehonda's Avatar
nehonda nehonda is offline
In reality you only need 1 gallon of new coolant because thats all that will drain out of the radiator. The block drain plug is nearly impossible to remove to get the remaining 3.5 quarts out and is not really necessary. Mixing 1 gallon of new coolant with the old is good enough.
You could change 1 gallon then drive a day or two then change out another gallon resulting in about 80% new in your system, but you waste about half a gallon of new coolant that way.
2000 Accord SE I4 F23A1 Auto - Sold @174k miles & 10 years ownership
1998 Accord LX I4 F23A1 5 speed - sons DD in DC
1987 Accord LX 5 spd Owned for 17 years sold @155k
1986 Accord LX Auto Totaled @137k miles
1983 Accord LX 5 spd My Second Accord traded in
1978 Accord LX 5 spd My First Accord sold @ 100k
Old 12-23-2010, 07:03 AM
VTAKKKK
I figured that it would be something like that, similar to the automatic transmission fluid. Well, you would definitely pour in and check the levels before you started the car either way.
Old 01-03-2011, 06:11 PM
coolcat's Avatar
coolcat coolcat is offline
The coolant in my Accord is green color, can the new dark blue color mixes with green color?
2003 Honda accord LX-G Stock
Old 01-03-2011, 06:44 PM
Toshbar's Avatar
Toshbar Toshbar is online now
<= Jeep differential LOL.
blue can mix with green. Green can mix with green. Orange CANNOT mix with anything. It will form a sludge.
I replaced my coolant at 105k a few months ago in my 2004 4cylinder. It had green in it and I just went with the Prestone non-diluted green coolant and mixed it 50/50 with some distilled water. I just drained and filled the radiator per the manual and it took about a gallon and a half. My manual said to use low silicate stuff if Honda coolant is not available. I read on the Prestone bottle that it is non-silicate and is okay for aluminum block engines.
2004 4Cyl/5MT Sedan
Save the Manuals!
1 3 5
2 4 R
Old 01-05-2011, 12:16 PM
Hi Nehonda,
I slacked off during the holiday breaks. I am at the dealership right now to pickup the coolant and see your message. I will just pick one gallon up.
Thanks,
Kevin
Old 01-25-2011, 10:45 AM
sodaks2k sodaks2k is offline
Make sure you change it every 2 years/24 months then. Honda type 2 is good for 5 years....
2014 MSM Accord Sport Sedan 6M
Title goes here
close
video goes here
description goes here. Read Full Story
